Page 1 of 12 12311 ... LastLast
Results 1 to 15 of 174
    Talking Project Log: Kanade
    Overview
    This will be my first major build in 6 years.
    Kanade will be replacing Nami, a dual Opteron 290, Tyan Thunder K8WE based rig who is credited for near 24x7 operations with absolutely no serious hardware faults since her conception.
    Big shoes to fill. Incidentally, Nami was born when BF2 first came out. Now BF3 is round the corner, and Kanade will rise up to the ocassion.
    Edit: On the name... This will be a detraction from my tradition of naming all my machines with a female name starting with N.
    Her precedessors were Noriko, Natasha, Netanya, Norumi, Nikita, and Nami.
    "Kanade" translates to the action of playing an instrument. With her inception, she will be the first major rig I will have built that will actually be able to run almost silent (by my standards).
    Nami had a dual volted fan system with toggle switches for the subsystems. That didn't work too well though as some fans were not happy with the reduced voltage and would stall.
    Kanade will have PWM control for high pressure fan subsystems which will allow me to balance energy consumption, performance, and noise generation.
    That will also give me impetus to replace that 12 year old audio system I have plugged into my rig with a nice set of Dynaudio MC15s and external DAC.
    Preliminary components.
    Motherboard/CPU: Asus ROG Gene Z v3/Intel i7 2600k
    Gonna sit in place until Sandy E has been in the market for a few months and stabilized. Will be replaced by a dual socket 2011 if/when the technology and product matures. Had enough of bleeding edge/bleeding wallet.
    This might just be cute. A micro ATX board in a chassis as large as this one
    RAM: ?
    Brand not determinate yet. Probably GSkills kit.
    GPU: Asus HD6990
    Got one first to see if it will drive 7680x1440 reliabily. I am not an FPS nut so I might be able to get by on a single unit.
    PSU: Corsair AX1200 x2
    One unit will be unused until the next Gen GPUs are released, or I decide to get another 6990.
    Radiators: HWLabs Black Ice GTX 480 x2 + HWLabs Black Ice GTX/SR1 560 x2
    Topology (Single Loop): // Reservoir -> Dual MCP 655 -> 560 stack -> [Peltier?] -> CPUs/mobo -> 480 set -> GPUs -> Reservoir
    Overkill? Definitely. The peltier is something to look at for the future. I came upon a surplus AIO 120mm rad. It might be just the thing to suck heat from a 100W peltier TEC. It should be able to bring the coolant down a few degrees. I could sandwich the TEC between CPU and WB... but then failed TEC would mean instant CPU roast. If the TEC fails when it's in an auxillary role, it won't hurt anything.
    Pumps: 2x MCP655 + EK Dual Top + EK 400mm X2 integrated reservoir
    Two pumps should be enough to handle the loop. I think. 400mm x 60mm rad wil be directly attached to the pump. I should have bought pumps with tach instead of speed control. Gotta figure out a way to check for pump failure.
    Blocks: ?
    Undetermined at this time. Leaning towards EK kit for the bling though XSPC's latest got my eye.
    I will not be water cooling the 6990 for now until the next gen cards are released. Seems a waste for a card rapidly reaching EOL.
    Fans: San Ace 9CR1212P1G03 and Scythe (Nidec Japan Servo) Gentle Typhoon AP15s
    Being nearly silent, the GT AP15s will be set to always on.
    The massive San Aces will be toggled, and will be managed with PWM speed control.
    These are twin motor fans, and each bank of 4 will be controlled via a physical DPST switch.
    Topology:
    Top: // Outside Air -> Scythe -> 480 radiator -> San Ace -> Chassis -> Outside
    Pedestal: // Outside Air -> 560 radiator -> Scythe -> San Ace -> 560 radiator -> Outside
    Fan intakes are positioned to suck cold air. Heated air will exit away from the intakes to avoid reducing radiator efficiency.
    Case: CaseLabs TH10 + Pedestal
    Big is beautiful. Nuff said See the pics.
    DF
    Durian Dragon Dranyago! See this Dragon Meow!
    Views expressed are my own and are not representative of that of VR-Zone.
    Posts made when executing moderator duties after 20150301 will be in bold purple
    Note that Friend requests will be declined without exception. Do not send me any.
    CaseLabs TH10 + Extended Pedestal Unboxing
    FedEx had a present for me.
    Packed very well. Not a scratch.
    Did I mentioned they pack their kit real well?
    Radiator mounts for 2x size 560s.
    The front end. Plenty of front bays. Who needs a seperate NAS with this beast?
    Slots for two power supply units. Reverse ATX option was selected. The removable back plate has 10 PCI slots for the most massive boards including the gargantuan HPTX SR-2 by EVGA.
    Motherboard compartment open and pedestal side panel removed. The fan holes below are 140mm cutout. A size 560 radiator goes down there. The San Ace 300 cfm monsters are put in for show
    Angle shot of the power supply side. Motherboard tray is removed. The horizontal accessory beams are optional. I have mounted a pair of 120mm fan mounts on the bottom beam. These line up perfectly with the side panel vents.
    Straight on photo of the power supply side.
    Shot showing the removable motherboard tray. Rubber feet are included in case you want to operate the tray naked on your table for long periods. Baseplate is removable for heatsink mounting plate access. Yes those are spring mounted thumbscrews
    I might run these... If I were a deaf man.
    DF
    <Reserved 1>
    <Reserved 2>
    <Reserved 3>
    <Reserved 4>
    <Reserved 5>
    NOT Soon to be modder lee-turbo's Avatar
    Mar 2010
    JB SG
    3,192
    Great case u have there, look forward for ur hardware to come, waiting for lga 2011?
    Do i lost my passion for HW?
    4770K+M.Impact +780 + Intel 730 480G, M4 256G,WD SE 2TB +Seasonic P-1000
    With Filco Ninja brown(PBT and red engraved mod) + Ducky wrist rest+ Razer Black edition Death Adder/ MX Performance + Logitech G27+ 2713HM + Edifier S530D
    Turbo Mod T-01
    LGA2011 will be an eventuality. Going for matured hardware in the meantime.
    DF
    still reserving or we can start showing suppork leh?
    gonna be massive one
    finally! really looking forward to this epic build. gene-z in that freaking MONSTER of a casing, why this particular choice of mobo for the time being? what about atx boards like maximus IV extreme, asrock e4g3 etc?
    i5-750 4GHz
    Corsair H50 + Scythe Gentle Typhoon Push Pull
    EVGA P55 Classified 200
    Team Xtreem 1600 CL8
    MSI 5870 Lightning
    Corsair HX750
    HAF 932
    Dell U2311H
    Razer Deathadder 3.5G
    Razer Goliathus
    Noppoo Choc Mini Brown Switch with Black on Orange KBC 37 Keys
    The Gene Z will be moved to a HTPC role when LGA2011 matures. It's all planned out. (I hope)
    DF
    DF, for scaling purpose, put a coke can beside it.
    meowz N3w_Typ3's Avatar
    Oct 2007
    Tiny Red Dot @ South East Asia on the World Map
    3,581
    Boss DF nice start... another project log to look forward.
    Intel Core i7-2600K + NH-D14, Z77 G1 Sniper3, Zotac GTX 770 4GB, Crucial M500, Toshiba HDDs, 24GB KVR, LianLi PC-8FI, SS X-560, DELL P2714H & U2311H, Cherry G8000, LT M705 + SS mousepad ,Win 7, Hifiman EF100 > Audio Engine A5 Passive
    HiFiMan 901 + IEM Card -> Flare Audio R2A/Simple IEM
    iPhone 7+, X1 Carbon G3 - T400, FujiFilm X-T2, EF-X500, 16mm F1.4, 50-140 F2.8, PS Vita Project Diva LE, God Eater LE, New 3DS XL Blue & LL Manaka Love Plus, PS3 FF-XIII, FF-XIII-II LE & TOX LE, PS4 - 480GB Intel 530, Sena Asus Meno Pad
    QNAP-TS219P 6TB
    Zen Watch
    ♥ Lightning ♥ 9VARZ's Avatar
    Mar 2007
    Singapore, Singapore
    15,203
    Aggro! I Like!
    Views expressed are my own.
    WTS: Garage sales!! Pre-loved items sold for cheap!!
    URGENT DOSE OF VITAMIN M REQUIRED.
    Can you help?
  1. [Project Log] ???
    By sabe in forum Case Modding & Project Logs
    Last Post: Jul 12th, 10, 01:33 AM
  2. Project Log: Codename: 69
    By masbuskado in forum Case Modding & Project Logs
    Last Post: Jan 3rd, 10, 12:36 AM
  3. [Project Log] The Phoenix Within
    By eventidephoenix in forum Case Modding & Project Logs
    Last Post: Dec 17th, 09, 01:07 PM
  4. [Project Log] RedSin
    By alboytham in forum Case Modding & Project Logs
    Last Post: Sep 8th, 09, 12:40 AM
  5. [Project Log]***PROJECT KURO***
