Thread: Projek D
Page 1 of 12 12311 ... LastLast
Results 1 to 15 of 175
    Projek D
    so i got myself a Danger Den Double Wide Tower 21 - clear acryllic
    its a simple casing, able to mount 2x480 and a 1x360 internally. the casing separates into 2 bays, one for the motherboard and other pcbs' and the other for the watercooling components.
    i have decided to have 3 phases for my projek.
    1st Phase
    • to replace all critical watercooling pumps - tubings, pump, reservoir, fittings
    • to streamline wirings and what not
    2nd Phase
    • to improve the overall outlook of the rig - led fans, extension cables etc
    3rd Phase
    • upgrading components - 990fx motherboard, crossfire, rams
    Phase 1
    since it is a clear casing, i have opt for Feser 1/2" white tubings, with Bitspower compression fittings.
    i have gotten myself a new reservoir, FrozenQ Liquid Fusion 250mm Blue, its a one chio reservoir albeit pricing on the high end.
    i have replaced my 355 to a 655 for my CPU loop. and for my GPU loop, i decided it to remain the same, XSPC res/pump combo.
    Front View
    Side View
    Fan View
    After taking like half a day (rest in btween, watch Korean shows), i finally get it fixed but its cums with a hiccup. will eleborate after this flood of photos
    Feser white 1/2 tubing
    Koolance drain plugs which i cant use cos of smaller OD..sianz..will sell it at marketplace soon
    Bucket Check !! Empty space check !! Remove parts from my NZXT Tempest
    still looks as new even though the psu is few years old oredi
    good thing abt this is that i can remove the mobo 'tray' and fix everything outside and put it back
    inside oredi
    one of the cockup - my cooltek screw holes r not aligned against the casing screw holes..haiz..
    yay..all inside oredi..left the tubings..cables all over...
    top view of the dd
    yay..tubing in..the support for the 51/4" bay cums wif the top cover, so i have to slant my xspc combo for the running in
    view from the front. its kinda empty now. will be filled during phase 2
    top view with when running in
    leak test !!
    yay !! abit neater - will be even neater in phase 2
    under my table...will stress load later to see whether got any improvement/reduction in temp
    Tada !!! paiseh..the top cover paper-sticker is not cleared properly...hehe..will put some solution later to make it soft.
    Phase 1 end product
    Cockups
    The Double wide is excellent case to work with. ample space and everything. everything's good.
    the cockup r the stuffs that i put it in
    1. my cooltek radiator. the fan spacing is all over. it is not aligned against the casing fan mounts. its not DD fault though. the casing are made to standard specs
    2. my feser radiator - the screws are smaller. ive forgotten to get shorter screws for that. im doing a push with my Yate loons so the fans would be in the casing. as such the radiator have to be mounted on the casing. the screws giving although thicker but shorter. the radiator screws r longer and thinner. so now ive and get shorter and thinner screws.
    3. my xspc combo r not aligned in the bay. again its xspc fault. the holes at the side r higher than the holes at the casing. ive checked using my dvd drive. the bay is perfectly for 2 double bay slots.
    So basically the gripe is on my parts' manufacturer thumbs up for DD on their perfectly designed casings !!
    When firstly running in. bloody noisy from the pump.
    abt 30 mins later...silence
    2nd Phase
    Parts needed
    1. bitspower uv spiral wrap - to wrap cables in one
    2. bitfenix pci-e 2 extension cables white - 2x
    3. bitfenix EPS extension cable white - 1pc
    4. bitspower power extension 2 - neater power outlet - otw. cuming end mth
    5. 3 UV Blue fans - for the casing intake fans
    6. Soft blue led at the main section - to provide nice 'ambient' to the main area
    7. External dvd player
    All those shld be able to complete end dec
    H20 sil96verman's Avatar
    May 2005
    Admiralty mrt
    7,896
    love your casing
    I think is the only one in Singapore!
    Intel i7 920 / WC
    Gigabyte X58-UD3R
    MSI HD 5770 HAWK OC
    Corsair Dom DDR3 6G
    Antec P182
    WD Velociraptor / Seasonic Gold Series X-650
    Noctua P12 / Aercool Panel3
    Quote Originally Posted by sil96verman View Post
    love your casing
    no lah..got another guy getting his in jan
    May 2005
    Admiralty mrt
    7,896
    pls take more pic
    project log must have lots of pics
    Intel i7 920 / WC
    Gigabyte X58-UD3R
    MSI HD 5770 HAWK OC
    Corsair Dom DDR3 6G
    Antec P182
    lol..haben even fix...so this is like a teaser...tease u here and there...lol..
    May 2005
    Admiralty mrt
    7,896
    Quote Originally Posted by enrell View Post
    GAY!!!!!!!!!!!!!!
    Intel i7 920 / WC
    Gigabyte X58-UD3R
    MSI HD 5770 HAWK OC
    Corsair Dom DDR3 6G
    Antec P182
    damn swee!
    NOT Soon to be modder lee-turbo's Avatar
    Mar 2010
    JB SG
    3,192
    Finally
    Do i lost my passion for HW?
    4770K+M.Impact +780 + Intel 730 480G, M4 256G,WD SE 2TB +Seasonic P-1000
    With Filco Ninja brown(PBT and red engraved mod) + Ducky wrist rest+ Razer Black edition Death Adder/ MX Performance + Logitech G27+ 2713HM + Edifier S530D
    Turbo Mod T-01
    2x480 + 1x360 for starters? ^^
    Mar 2010
    JB SG
    3,192
    Quote Originally Posted by K-Dash View Post
    minimum ba
    Turbo Mod T-01
    hehehe..was thinking about that..
    2 feser 480, 1 gtx 360..imagine the fans noise..lol..
    pro setup ^^ more pics
    get the new ek xtx 480 & 360?
    so much cooling power, use GT 1850rpm @ single shroud pull also can give great delta. watercooling at such capacity/volume is mainly for acoustic. i can do 2x XT 360 with low rpm fan & yield result that are acceptable. yours will definitely work.
    go for 1/2" ID tubes & 2 pumps. total tube length layout in this monster will decrease your flow rate.
    low rpm fans with ample cfm & pressure like GT 1850rpm can be connected 2 fans to a single channel of lamptron fan controller. server fans like san ace & delta, max is prolly 1 on single channel or overheating on fan controller chipset.
    to summarise my opinion:
    EK XTX proven to work with GT 1850rpm. do a single shroud pull or push which sums up to 12fans. 2 fans to a channel will just requires a single lamptron 6 channel. just make sure the cable supplying power to the controller doesn't have other hardwares taxing on it.
  1. Replies: 7
    Last Post: Dec 11th, 09, 09:11 PM
