Page 2 of 20 FirstFirst 123412 ... LastLast
Results 16 to 30 of 290
    Quote Originally Posted by Philip View Post
    Oooo... what is the rpm of the San Ace at lowest speed?
    Phil
    SANYO DENKI Web CATALOGE
    Min 1650rpm @30db, 0.09inH2O
    Max 5100rpm @58db, 0.90inH2O
    It may be noisier but there be flexibility. Just crank up the speed if you aren't getting enough cooling until you reach that sweetspot.
    DF
    Durian Dragon Dranyago! See this Dragon Meow!
    Views expressed are my own and are not representative of that of VR-Zone.
    Posts made when executing moderator duties after 20150301 will be in bold purple
    Note that Friend requests will be declined without exception. Do not send me any.
    Quote Originally Posted by DragonFire View Post
    DF
    5.1K rpm!! !!!
    Phil
    i7 4GHz ♦ Asus R2G ♦ OCZ Intel XMP ♦ Asus 5870 ♦ Crucial M4 ♦ Swiftech ♦ Koolance
    x4 3.5GHz ♦ Biostar 890GXE ♦ OCZ AMD BE ♦ Asus 8800 ♦ WD Veloci ♦ Swiftech ♦ XSPC
    Clearing watercooling and misc parts!
    Quote Originally Posted by Gollum View Post
    is ns really that hard???
    Actually, I'm not sure whether the GT1850 fans are suitable for the BI GTX rads.
    Phil
    BI GTX needs fairly beefy fans which the 1850s are not. The 1850s will be great for BI SR1s tho.
    DF
    Quote Originally Posted by mambo500 View Post
    Agree on the use of GT1850 on the BI GTX rads. Might get better cooling performance if u went for the XSPC rads instead. Just my 2 cents.
    Thanks for all the helpful comments.
    I saw this before I decided on the GTs + GTX combo.
    And it seemed to me that the GTX could perform slightly better than the RX @ 1800rpm.
    But then, of course, in the test it's a D12SH12 and not a GT.
    Anyway I still have the chance to get 1x RX360/SR-1 for my other rad as I've only gotten 1x GTX360 right now.
    Maybe I can run a GTX360 + SR-1/RX360 with the SR-1/RX360 on the side of the casing that is nearer to the user, in this case, me. Silent fans nearer, louder fans further.
    Any comments on this?
    Quote Originally Posted by Ar3s View Post
    Is 120GB enough for everything for you personally ? Formatted its less.
    Yea it's not really enough but due to the current insane HDD prices, I've decided to use one of my old drives as a temporarily stand-in.
    Didn't put it in the list either.
    DF
    Wow looks interesting.
    Where did you get it? SLT?
    My first WC Project!
    Please support!
    element14.
    DF
    Quote Originally Posted by ChaoticOrb View Post
    Just remember these figures are strictly for reference purpose and the test is probably conducted in open air versus an enclosed casing for example.
    The crux of the matter is GTX uses high FPI and you'll need faster fans for it to perform optimally. Otherwise, you might be better off with thinner and cheaper rads to achieve similar cooling results. In fact, my cheapo Swiftech MCR320 is less than 1d delta compared with your GTX at 1.8k rpm based on the chart.
    A simple solution is to get 2K+ rpm fans to pair with your existing GTX if low noise is not a key consideration for you.
    Phil
    I've learn my lesson after using a variety of slow fans such as Yate Loon SL and AC F12 with BI GTS. My new Swiftech MCR rads and F12s delivered much better cooling performance even though the new rad surface has only increased slightly. From 480mm to 600mm.
    Phil
    Just chose the fan u like cos even u use the best fan base on review, u still need to factor in room temp and surround airflow. So afterall just turn on your aircon
    I am changing the 1850s I bought out for San Ace PWM fans that at lowest setting are just slightly noisier than the 1850s.
    Edit: And welcome to the VRZ CaseLabs club. I should start a CaseLabs thread
    DF
    it is so big....
    Quote Originally Posted by r104_for View Post
    I think the TX10 is made for 2 systems in a single case.
    Please support!
    Another Caselabs supporter
    Intel i7-3960X C2|Custom Watercooling
    Asus Rampage IV Extreme|4GBx4 Corsair Dominator Platinum DDR3-1866
    Samsung 840 PRO 256GB|WD Black WD2002 2TB|LG DVDRW DL
    Gigabyte GeForce GTX 690 4GBx2 4-way SLI
    Dell U2412Mx3 Surround 3x1|XFX Triple Display Monitor Stand
    Sound Blaster X-Fi Titanium HD|Yamaha YAS-101
    Thermaltake Tt eSPORT Challenger Ultimate & Black Element
    Case Labs TH10|Corsair AX1200|Win7 Ult 64bit
    LOL. I was forced to do that when I use F12 with BI GTS.
    Phil
    super big case, another monster in the making.
    happy to see more & more wc project logs.
    maybe we can form a club soon. lol
    Hardware SoftSpot illusi0n's Avatar
    Jun 2007
    Hougang
    8,131
    seems like the trend is white and black now adays ..
    Conditions:
    1. I Reserve The Right To Deal With Whoever I Want
    2. Any Withdrawal Of Deal Will Lead To A Neg Rep From Me
    3. Dealing Location Will Be Agreed Before Deal
    If You Are Unable To Agree To My T&C Kindly Please Do not Bid Thanks
    NOT Soon to be modder lee-turbo's Avatar
    Mar 2010
    JB SG
    3,192
    Using bi gtx 480, pair with gtap15, magma , appolish Vegas
    Noise is not an issue, but dun really check there is how much diff in between those fan
    Slip stream 1900rpm also, a bit louder that others
    Considering to get lower fin per inch since my fan is all below 2k speed
    Review is compare the noise with a few db and a few c,
    Low noise with a few db diff nothing much
    But the few c, is good to gain if possible
    I did some testing with the rad for the suction of the fan
    Coz I want to stack dual rad together
    From the monster case that u have there, might need to consider the air flow inside the case?
    The sequence of the flow wil determine which rad is hoter
    And best is cooler rad at front case/ intake aide the hot rad at exhaust
    Just my 2cents opinion
    Btw gt bi, is dual pass rad, for gtx480, not sure is it the same as other size bi rad
    Take note, the inlet and outlet which wol make some minor impact on that too
    Cheer for wc rig
    We should have wc club now????
    Do i lost my passion for HW?
    4770K+M.Impact +780 + Intel 730 480G, M4 256G,WD SE 2TB +Seasonic P-1000
    With Filco Ninja brown(PBT and red engraved mod) + Ducky wrist rest+ Razer Black edition Death Adder/ MX Performance + Logitech G27+ 2713HM + Edifier S530D
    Turbo Mod T-01
    Yeah it makes my TH10+Pedestal looks small.
    DF
    Mar 2010
    JB SG
    3,192
    DF
    Stil monster case there
    Turbo Mod T-01
    Saw this from overclock.net ....
    Phil
    Haha
    [Project Log] Fiery Black Ki7ight [Trilogy] << best idea
  1. [Build Log] Project Lazy(TJ-07) Complete
    By akerue in forum Case Modding & Project Logs
    Last Post: Aug 28th, 13, 07:26 PM
  2. Project Log: Water Cooled White CaseLabs SM8
    By kiwi_kczt in forum Case Modding & Project Logs
    Last Post: Aug 25th, 13, 11:18 PM
  3. Replies: 10
    Last Post: Jun 6th, 13, 06:57 PM
  4. [Project Log]***PROJECT KURO***
