Page 9 of 16 FirstFirst ... 7891011 ... LastLast
Results 121 to 135 of 233
  1. #121
    NPA - No Perm Address eminus's Avatar
    Jul 2011
    5,115
    Quote Originally Posted by simways View Post
    stock clock... my cpu is 2500 "missing K"
    compared to d14:
    0~2 deg when idle
    0~3 deg when load
    oh yeah did not notice it is missing a K...but superb work bro!!!
  2. #122
    Club VR Member simways's Avatar
    Dec 2009
    Yishun Chong Pang
    4,274
    getting ready to change my mobo this morning.
    drained my loop and disconnected all connections.
    fixing up the "new" mobo... bought from the forum early this week.
    fix up the tube for refilling.
  3. #123
    Dec 2009
    Yishun Chong Pang
    4,274
    funnel my wife bought for me
    powering up - bubbles!
    the kids luv it!
    mission accomplished!
  4. #124
    lol.. should let your kids do the filling up instead. nice one
  5. #125
    Dec 2009
    Yishun Chong Pang
    4,274
    "watercooled" my second rig today with a gift from Antec Facebook event.
    Now then I realized it does look like burning hot inside... with the red LED strip.
  6. #126
    So cute your kids! B for "Bubble" .. Nice Bro!
  7. #127
    Dec 2009
    Yishun Chong Pang
    4,274
    bought this from Uvnium yesterday, support Gary before his shop "relocate" next friday.
  8. #128
    Dec 2009
    Yishun Chong Pang
    4,274
    bezel for my second rig in the room.
    Matching with the speaker system in the room.
    installed 2 blue led fans to counter the heat (red led strip)
  9. #129
    Dec 2009
    Yishun Chong Pang
    4,274
    did cable sleeving for the 7 GT fans in my main rig.
  10. #130
    Nice. Spray paint the blades! They sure look better haha
    |Processor: Intel i7 3930K,|Mainboard: Asus Rampage IV Extreme, |Memory: Corsair 8 x 4 GB DDR3 1600, |Graphics: 3 X Gigabyte 780TI Tri SLI, |Storage: Seagate 3TB Baracuda, 128GB ADATA PXG SX900, 2 X Kingston HyperX 3K 120GB |Audio: Aktimate Maxi, Matrix Mini I DAC, |Fan Controllers: Aquaero 6 Pro, Aquaero 5 Pro, Poweradjusts 2 Ultra, USBPower Supply: Seasonic X1250, |Casing: Caselabs STH10, |Monitor: Samsung S27A850D, |Keyboard & Mouse: Ducky Shine White, Razer Ouroboros, Cyborg RAT 7|System Fans: 8 X AP15 Gentle Typhoon, 7 X Enermax Magma|
    Custom Watercooling Parts: Bitspower Summit Plexi, AQC Acrylic Glass 780TI X3, Koolance MB-ASR4E Rampage 4 Extreme Block, 2 X Bitspower Universal Nickel Clear Plexi 4DIMM, Swiftech MCP655 X 3, EK Multioption X2 250, 480 Monsta, 360 Monsta, 360 Phobya G Changer
    Portable Audio Rig:
    Sony ZX2, Whiplash V3 IC, UM Miracles, Whiplash TWAG V2 Ecilpse
  11. #131
    Dec 2009
    Yishun Chong Pang
    4,274
  12. #132
    very nice sleeving of fans. it gets addictive de o. how about the rest neh?
  13. #133
    Dec 2009
    Yishun Chong Pang
    4,274
    Quote Originally Posted by K-Dash View Post
    Done with the sleeving for all the fans and fan controller...
    molex connectors are a bit tougher...
    dun have so much sleeves to play with... quite ex too
  14. #134
    Dec 2009
    Yishun Chong Pang
    4,274
    make adjustment for the change of gfx from 560ti to 6950 (ref).
    the current setup allow gfx of max 27cm (due to the giant res inside )
    draining
    sleeved the pump
    fix up the pump bracket to the back of the casing (using cable tie!)
  15. #135
    Dec 2009
    Yishun Chong Pang
    4,274
    fixed up the cylinder and holder (also secured using cable tie).
    pump is linked to the res using mini-d-plug.
    2x res holders bought from sabe secured using cable tie and small piece of tubing.
    phase one setup done (just cpu loop while pending deal for the gpu loop next week.
    fixed up the gfx and fill up the res.
    space available after the res relocated outside the casing = setup of a second loop
  1. [Project Log] Phantom White
    By oakenfoldsg in forum Case Modding & Project Logs
    Last Post: Aug 2nd, 09, 10:02 AM
  2. My humble watercooling project
    By exxtreme in forum Hardware Depot
    Last Post: Mar 1st, 08, 01:23 AM
  3. Project MysticalX - TJ-07 Dual-watercooling inside.
    By enegizer in forum Case Modding & Project Logs
    Last Post: Mar 17th, 07, 01:20 AM
  4. Xbox 360 WaterCooling Project
    By rascal in forum Hardware Depot
    Last Post: Mar 4th, 06, 08:46 AM
  5. Watercooling project!
    By screambitch in forum Case Modding & Project Logs
    Last Post: Dec 14th, 05, 07:36 PM
