Results 1 to 15 of 26
    How to mount a 120mm fan on the cd drive bay?
    erm.... need help again, my friend's computer casing front does not support a 120mm fan, so im thinking of mounting a 120mm fan on the cd drive bay, size= 3 bay, heard that theres a extender to mount it on. is there selling the extender to support the fan on the cd drive bay?
    so that it can blow the air into the computer.
    URL: http://forums.vr-zone.com/showthread.php?t=267416
    I asked the same question about a week ago. But looks like no one knows....If you manage to find one, do inform me. The next best option I guess would be the lian-li hdd accessory off potterhouse.
    Quote Originally Posted by RaptorTan View Post
    PMed.
    H Two O Cooler Navanod's Avatar
    Dec 2005
    Queenstown
    2,241
    The easiest to find at SLS would be the CM HD bay
    http://www.coolermaster.com/products...ate=65&id=2542
    If no HD required, this may be good
    http://www.scythe-usa.com/product/ac...00_detail.html
    Current Watercooling with:
    TJ07, Dtek V2 CPU block, Dtek V2 GPU block, EK NB/SB 5 block on NB, Swiftech MCW30 block on SB, Koolance MVR-40 VReg blocks x 02, Swiftech Micro Reservoir, Thermochill PA120.3 Rad, Swiftech MCP655 Vario pump with EK D5 X-Top, Bitspower Temperature probe x 02, PrimoFlex Pro LRT Tubings, Primochill Anti-Kink Coils Black, PC ICE Coolant
    Rules of eQ.™ heartykid's Avatar
    Jan 2008
    yew tee!! / SP
    2,233
    if u fierce enough.. just zip tie the 4 holes to the hdd cage.. lol.. thats wad i did to my spare rig..
    thanks for the details...
    Quote Originally Posted by Navanod View Post
    This looks good. Any idea where can get locally?
    ya i agree that the 'KAMA BAY' look good! but 800rmp look slow de. not enough to push air in
    unless change the Fan lor.
    dunno how much it cost? i think around $29?
    i think we should find a bay which support a 120mm fan with the mess panel only, n buy a high speed 120mm fan to mount it on.
    i only know that the coolermaster 4in3 stacker cost $39.
    Dec 2005
    Queenstown
    2,241
    The local distro is Alev Trav, you can try there
    check already, no stock
    Dec 2005
    Queenstown
    2,241
    Quote Originally Posted by BBfifa07 View Post
    Why am I not surprised
    I just bought the coolermaster 4in3 module @ $38
    I just bolted the fan in. Like this.
    Quote Originally Posted by pantss View Post
    but no filter? at least that the dust wont pass thru into the system
    hmm, add a mess n a grill .
    anyway hows yr system look like? any photos?
    I did the exact same thing as the guy above me, simply bolt the fans on to the plates that occupy your empty drive bays, my case has foam in the front drive bay covers so no dust for me. It's pretty easy to make a filter too, the material from aquarium filters works quite well. Also, the zip tie idea would work just fine as long as they are extremely tight. You can also simply make your own mount, 4 little strips of aluminum, roughtly 1/2 inch by 1 1/2 inch, screw size hole in each end, bolt one end to the chassis and the other on the fan mount. Little bit more stability and comfort that way. To be 100% honest, with a little bit of thought and ingenuity there are countless ways to do this, some easier and more expensive, but over all better, and some less expensive but require more work and/or not as quality. Either way, good luck.
    Gigabyte MA790GPT Motherboard AMD790GX
    AMD Phenom II x4 995 3.2ghz OC ~ 3.8ghz.
    Patriot 4gb DDR3 PC1600
    ASUS ATI Radeon HD 4890 1gb GDDR5 OC ~850mhzGPU
    RealTEK HD Audio w/ Dolby 7.1/True HD Audio
    WD 80gb HDD x2 RAID 0 7200rpm
    WD 1tb Eco-drive 7200rpm 16mb cache
    CoolMAX 750 Watt PSU
    Pioneer 22x DVD-RW
    And a floppy drive...
    Vista Business x64
