Page 7 of 39 FirstFirst ... 5678917 ... LastLast
Results 91 to 105 of 573
  1. #91
    Was busy the whole weekend, and looking forward for my Caselabs STH10 arrival.
    It finally arrives yesterday evening.
    Rushed home like a young boy to open his present. When got home, I saw the package lying at the doorstep. Freaking huge package.
    Opened the package and found out something amiss....
    Some of the parts that I had ordered separately are all in white instead of black.
    I had custom the black and white colors, Exterior all white except for flexbays are all black.
    Interior wise, all black.
    The parts that I ordered all came in white,
    - HDD Cage
    - Short 5.25 Adjustable mounts X 3
    - 480 Radiator Stand X 2
    Even the 4 sets of 5.25 mounts are white too....
    Worst case is, the HDD cage is bent!
    I had yet to fix them up and yet so many issues. So discouraging.....
    So I sent them email notifying them about this issue and hope they could give me a solution...
    As I need to drill some holes for reservoir mounting, I cannot fix up the whole case yet.
    So visually, I see no errors or faults on the casing so I am hoping nothing goes wrong with the panels.
    |Processor: Intel i7 3930K,|Mainboard: Asus Rampage IV Extreme, |Memory: Corsair 8 x 4 GB DDR3 1600, |Graphics: 3 X Gigabyte 780TI Tri SLI, |Storage: Seagate 3TB Baracuda, 128GB ADATA PXG SX900, 2 X Kingston HyperX 3K 120GB |Audio: Aktimate Maxi, Matrix Mini I DAC, |Fan Controllers: Aquaero 6 Pro, Aquaero 5 Pro, Poweradjusts 2 Ultra, USBPower Supply: Seasonic X1250, |Casing: Caselabs STH10, |Monitor: Samsung S27A850D, |Keyboard & Mouse: Ducky Shine White, Razer Ouroboros, Cyborg RAT 7|System Fans: 8 X AP15 Gentle Typhoon, 7 X Enermax Magma|
    Custom Watercooling Parts: Bitspower Summit Plexi, AQC Acrylic Glass 780TI X3, Koolance MB-ASR4E Rampage 4 Extreme Block, 2 X Bitspower Universal Nickel Clear Plexi 4DIMM, Swiftech MCP655 X 3, EK Multioption X2 250, 480 Monsta, 360 Monsta, 360 Phobya G Changer
    Portable Audio Rig:
    Sony ZX2, Whiplash V3 IC, UM Miracles, Whiplash TWAG V2 Ecilpse
  2. #92
    In order to be able to fix up the case, I will need to get the Chassis Divider holes to be done. I had no confidence in getting it done without scratches onto the case so I had to send it down to MOPC today.
    At MOPC, all thanks to Kenclass he had helped to give me more ideas in my built include the mounting of holes.
    Instead of just drilling 2 X M3 Holes for the reservoir clips, Kenclass suggested me to drill G 1/4 holes instead.
    In total 3 X G1/4 holes were drilled which I will further explain the use of them later.
    As for now, I am waiting for the replies of Caselabs and hope they can help to resolve the issue by replacing the parts...
    I am expecting a few shipments in the upcoming weeks when includes,
    - 2 - 3 Koolance QDC,
    - 40m of Red Sleeves
    - 20m of Grey Sleeves
    - 30m of White Sleeves
    - 20m of Orange Sleeves
    - PCI E Connectors (Red)
    - Cable management clips
    - PCI E Extension cables (80CM) X 4
    - 1M LED Strips (White) X 2
    - 3PIN Fan Cable (80CM) X 2
    - Enermax Magmas X 4
    - Heat Shrinks (Red/Black/White)
    - ATX Modding Tools
    - 3 Pin Male Connectors (Black)
    - Bitspower Fittings (close to $800 of fittings combined with Hianyiaw)
    - Demciflex Filters (For Caselabs STH10)
    I had also bought additional fans recently.
    5 X Enermax Magmas
    1 X Corsair Airflow Ram Cooler
    The ram cooler is to be used with my row of 3 Aquacomputer PowerAdjust 2 USBs. As there are no aircooling solution for the Poweradjusts so I intend to use the ram cooler to cool them.
    In total now which includes my incoming orders of 4 X Enermax Magmas, I have the following number of fans.
    - 12 X Enermax Magmas
    - 11 X Gentle Typhoons.
    - 01 X Corsair Airflow
    I am intending to do Push and Pull for my 360 Front Flex Bay radiator, and Pull config for both rads at the bottom.
    Fans Config
    6 Magmas - 360 XTX Radiator (Flexbay - Push and Pull)
    4 GTs - 480 Monsta (Btm Chamber - Pull)
    3 GTs - 360 Monsta (Btm Chamber - Pull)
    1 GT - Rear Exhaust
    3 GTs/ Magmas Top Intake
    I will have a total of 6 spare fans GTs/ Magmas which I will decide again when I gotten hold of the Monsta Rads. I am still hoping I could do a push and pull config for both the Monstas.
    Portable Audio Rig:
  3. #93
    Spent a total on 3.5 hours just to fix up the STH10. Took my time as I dont wish the screw driver to go flying and scratch the case.
    Fixed up the Main Frame of the STH10, Its MASSIVE
    After fixing it up, I started to plan for the relocation and placement of the HDD cage and 5.25 inch bays.
    Completed STH10
    Portable Audio Rig:
  4. #94
    Been buying all the stuffs required by this Project Rampage II for the past 3 weeks.
    My orders from Demciflex had finally arrive today, and expecting for my Bitspower fittings to arrive today as well.
    Been lurking at Tao Bao and hooting lots of modding stuffs there. It is modder's heaven there as they have lots and lots of items over there for modders.
    I am just hoping that the quality of the sleeves to be on par with MDPC.
    I had decided to hoot another Aquaero 5. I bought this off from a bro in VR Forum which he said he had no use for his Aquaero 5 XT. So I gladly told him I could have made full use of it.
    Collected from him and found out that it came with black faceplate and also waterblock which is very sweet deal for me.
    I also bought 1 X Poweradjust 2 USB, 1 X Aquaero 5 Waterblock and also some additional cheap phobya stop fittings and dual G1/4 transfer adapters which collected from Bro Inoran.
    Right now I have dual Aquaero 5 with 3 X Poweradjust (Might hoot two more Poweradjust)
    Some might comment that AQ6 is coming soon in Oct. But since I had bought AQ5 Pro and 3 X Poweradjust and their accessories, I dont wish to waste my time and money to puchase the AQ6 which I think will easily hit $300 for the highest end model.
    I might be running both if the AQ5 Pro and AQ5 XT independently since I wont be utilizing the USB 2 ports anyway. I am not sure if its possible but I will tryout soon to test the working condition of the newly bought AQ5 XT.
    I might be customizing the Triple Bay flex bay panels in order to hold the 5 X Poweradjusts (if I were to buy over the 2 X Poweradjusts) as the color of the mounting bay for Poweradjusts seems to have a ligher shade of black comparing to the rest of the faceplate of my STH10 and the Aquaero 5.
    Portable Audio Rig:
  5. #95
    Sneak peak at what arrive today at my door step.
    Bitspower Fittings
    My Haul
    Jayson's Loot
    My Platoon of Fittings (more in my current rig)
    I guess I am more or less ready for the migration really soon.
    Portable Audio Rig:
  6. #96
    Club VR Member simways's Avatar
    Dec 2009
    Yishun Chong Pang
    4,276
    wah... nice parade of fittings!
  7. #97
    Haha when I collect my fittings time for my platoon then
  8. #98
    Platoon or battalion? U got nights out inform me!
    Portable Audio Rig:
  9. #99
    Night out I also cannot make it to Chinatown too far Liao haha
  10. #100
    wow.... nice platoon/company level fittings....
    wonder how the whole division level will look like.... hmm.....
    CPU | i7-4790K | i7-4960X | i7-5960X | i7-6950X | i7-7700K
    Mobo | Asus VII Impact | Rampage IV Black Ed | Rampage V | Rampage V Ed 10 | Strix 270I
    GPU | AMD 295X2 | Titan (3-Way) | Titan X (3-Way) | Titan X Pascal | Titan Xp (2-Way)
    RAM | TridentZ (16GBx8) | Ripjaws4 (8GBx8) | TridentX (8GBx2) | Corsair Dom GT (4GBx8) | TridentZ (16GBx2)
    Display | Acer Predator XB321HK | Dell U2414H x3 | Samsung UE32F6400
    Storage | 840Pro/850Pro/840Evo | SM951 | 950Pro 512x2 | 960Evo 500x2 | 960Pro 1TB/2TB | Intel 750 400GB/1.2TB
    Case | CaseLabs S3 | Bullet BH2 | SM8 + Dual Peds | In Win D-Frame
    PSU | Corsair AX1200i x2 | AX1500i | Silverstone SX800-LTI
    Water Cool | Aqua Computer | Bitspower | EKWB | NZXT
    Audio | OPPO HA-1 | Asus E1 MUSES Ed (DSD Upg Kit) | Yamaha HS50M + HS10W / HD800 / JH16pro
  11. #101
    Show me how Jon drill the g1/4 holes leh
  12. #102
    MuhamMAD
    Dec 2012
    Irvine
    3,370
    Holy shiet that's alot of fittings..another awesome Singularity like build xP
    Top Gun Pilot:Quadra1978
  13. #103
    sth10 sure makes your glass coffee table looks small. lol
    realised your top chamber is not perforated. no intention to mount any rads there?
  14. #104
    Quote Originally Posted by K-Dash View Post
    Yes Bro, Top chamber is intended for PSU, HDD, SSD, 5.25 bay devices. and my Poweradjusts.
    Today just gotten two more Poweradjusts 2 Ultra. Now in total I have 5 Poweradjusts 2, 3 X Poweradjusts 2 USB amd 2 X Poweradjusts 2 Ultra.
    Aquacomputers Poweradjust 2 Ultra
    As the top chamber 5.25 bay I can only utilize 3 slots, I am planning two bays to be use for my Aquaero 5 XT and Pro, one bay will be using it either for my Poweradjusts Mounting Bays or my DVD drive.
    The Poweradjusts 2 Mounting Kit can only mount 3 X Poweradjusts, I will have to find ways to mount the other two Poweradjusts 2 Ultras.
    My options are as followed
    - Remove the PA Mounting Kit and drill 6 X 4 Holes onto the 2 Slot Flex Bay slots/ Fan hole plates to secure all of them onto the interior of the Top Chamber
    - Create a mounting plate for 2 X Poweradjust 2 using acrylic (Easier to create and cut) and mount them at Top Chamber.
    Portable Audio Rig:
  15. #105
    can use the long bay of caselab, the one for dvd rom usually to mount the 3x pa2 with bay then another 2x pa2 on the long bay's tail by drilling holes onto it since its gonna be in the top chamber away from sight.
  1. Project: Gran Máquina Roja (SR-2 in STH10)
    By bongholio in forum Case Modding & Project Logs
    Last Post: Sep 4th, 13, 12:06 AM
  2. Project Log: Water Cooled White CaseLabs SM8
    By kiwi_kczt in forum Case Modding & Project Logs
    Last Post: Aug 25th, 13, 11:18 PM
  3. Project Rampage: Corsair 800D (Upgrading)
    By kaiqi07 in forum Case Modding & Project Logs
    Last Post: Aug 18th, 13, 02:31 AM
  4. WTS: Caselabs STH10
    By donten in forum Other Hardware Components
    Last Post: Jul 24th, 13, 03:54 PM
  5. Project Log: I Must Stop?? Oh no! Caselabs M8.
    By zyphanox in forum Case Modding & Project Logs
    Last Post: Jun 24th, 13, 09:11 AM
