Results 1 to 15 of 19
    [vRz] InSex
    Jun 2005
    Woodlands
    7,734
    How to reduce noise from PSU?
    i'm using the FSP 300W... and it seems to be giving the most noise from my comp....
    CPU fan: TTsilentcat
    Exhaust fan: 80mm case fan that comes with my 3R alu casing
    Intake fan: 80mm $3 fan from Bell, but well encased so very little noise..
    but the PSU fan... argh..
    open up the psu, and unscrew the noisy fan, and replace it with another quieter fan lor....
    E6600 | P5K Premium Black Pearl Edition | 4870x2 | 2x4GB OCZ Reaper | Seasonic S12 | Silverstone TJ-03 Black | Samsung 24" 245B+
    Mac Mini | Samsung 27" SA550 | 2.66GHz Core 2 Duo | 2x2GB DDR3 | 750GB
    iMac | 24" | 2.66GHz Core 2 Duo | 2x4GB DDR3 | 1TB
    [vRz] InSex
    Jun 2005
    Woodlands
    7,734
    ok, thats a gd one.... haha any other way?
    Niatsi
    Quote Originally Posted by SkyCheong
    Jam a screwdriver into the fan at the back of the PSU.
    [vRz] InSex
    Jun 2005
    Woodlands
    7,734
    Quote Originally Posted by Niatsi
    wud only do that if its intel inside....
    where is the lep? wan_lep's Avatar
    Eunos
    662
    y dun u juz try those psu noise killer set...dunno if its available at sls or nt but anyway its available at sgxtreme.com
    here's the link http://www.sgxtreme.org/shop/default...da932d27a67e63
    <---------------------------Project:Salamander-------------------------->
    | CPU: amd anthlon64 3200+ @ 2.6Ghz | Mainboard: ASUS A8N-SLI |
    | Memory: 2x512 kingston pc3200 ddr400 | HDD: maxtor 120gb SATA |
    | Optical: sony dvd r/rw | Case: some cheap casing | Display: philips 107s6 |
    true, can jam something to stop the fan from spinning...
    umm although stopping the fan from spinning will remove the noise created by the fan...you'll damage your PSU in the long run as the heatsinks inside cannot dissapate the heat out efficiently without forced air...
    [vRz] InSex
    Jun 2005
    Woodlands
    7,734
    Quote Originally Posted by wan_lep
    dun think it reduce a lot of noise.... prolly jus the noise due to the vibration of the psu with casing.... i think it works better for normal case fans
    Jan 2005
    Bukit Batok
    10,361
    Put earplugs in ur ears...confirm silent.
    Macbook Lion | X32 Crunchbang Linux | EeePC 900 Ubuntu | Core i5-3450 Desktop Win7 | iPad 2 | iPod Touch 4G | Samsung Galaxy S2
    Newbie of Past & Present yantronic's Avatar
    Nov 2004
    Paid Accomodation
    22,893
    Change out the fan, set the fan to lower speed, or just use a fan controller on it.
    The opinions expressed above do not represent those of VR-Zone (VR Media PTE LTD Singapore) or any of their affiliates.
    changing fan or the speed is the cheapest and best way. u stop the fan completely, the psu gonna go kaboom when u start using it for long periods. and the noisekiller kit only helps to dampen vibration like u said. its just a piece of silicon
    if you're using the $29 FSP 300w, you can forget about changing out the fan. I tried it.
    There is noise from electronic components inside the psu as well.
    ★STX★ Static-X's Avatar
    Nov 2004
    Ubi
    20,167
    change to an higher quality's PSU ?
    Static-X
    | Intel C2D E6400 | AsusTEK P5K Pro | Leadtek 7600GT TDH 256mb | GeiL DDR2 PC 6400 1GB x 2 Ultra|
    |1 x Hitachi 80GB PATA 1x Hitachi 160GB SATAII| Audiotrak Prodigy 7.1 | Seasonic S12 430W PSU |
    Dun on your com. 100% silent!
