Page 1 of 12 12311 ... LastLast
Results 1 to 15 of 176
    Ah Lian Act 1 revamp log
    Need some opinions on this loop design;
    CPU -> NB -> GPU -> RAD1 -> RAD2 -> T-line -> PUMP -> CPU
    Doubts;
    1. Will mounting the pump high degrades performance by trapping air bubbles and etc.
    2. Is the T-line effective at this height and does it matters if there's basically very little buffer for coolant?
    3. Will evaporation means I will need to top up the coolant regularly?
    Chips to tame
    - Opty 170 o/c to 2.5GHz
    - 8800GTS 320MB stock
    - NF4-Ultra chipset stock
    Watercooling parts
    - Swiftech Apogee GT
    - Swiftech MCW30
    - Swiftech MCW60
    - Swiftech MCP350 + EK X-Top
    - Swiftech MCR120
    - BlackIce GTX120
    - DD Fillport
    - 3/8" Tygon
    Feel free to suggest other placements, but I prefer to minimize clutter and hide components.
    Phil
    i7 4GHz ♦ Asus R2G ♦ OCZ Intel XMP ♦ Asus 5870 ♦ Crucial M4 ♦ Swiftech ♦ Koolance
    x4 3.5GHz ♦ Biostar 890GXE ♦ OCZ AMD BE ♦ Asus 8800 ♦ WD Veloci ♦ Swiftech ♦ XSPC
    Clearing watercooling and misc parts!
    Quote Originally Posted by Gollum View Post
    is ns really that hard???
    answer for your doubt..
    1. mounting your pump high is alright since u are using t line.. usually people mount pump low because they are using reservior and res need to be able to supply the pump with water.. thus res at mid of chasis and pump at below..
    2. i dont think the t line placement is a problem too.. just make sure you fully bleed the loop before you close the fillport..(because if there are air in ur loop your cooling will not be effective.. and also it might kill ur pump.. i killed 1 of my dtek this way.. )
    3. yes but since you have two radiator.. i dont think you will need to refill ur loop often unless ur loop is leaking if not it dont usually drop that fast if u fully bleed the loop le then top it up to the max you could..
    just my 2cents..hope it helps.. feel free to correct me if i'm wrong for any of the above..
    time to mod, budget style!.
    Phil
    Projects Underway Nashaz's Avatar
    10,239
    nice rad!...
    That's it for now.
    Phil
    Sleeved the loose wires.
    Phil
    nice rad =)
    The red radiator looks awesome! Great job bro!
    Thanks guys!
    Gonna spray a MCR220 in transit red too!
    Phil
    Mar 2008
    In Singapore, on a Land.
    5,176
    Looking great!
    Am trying on spraying too
    Home Entertainment: Xtreamer NMT | Hotway Probox 4 Bay Enclosure| WD Green 808.88GB x2 Seagate 750GB
    Currently using: Samsung Galaxy Note II
    Cowon J3 + FischerAudio DBA-02 + Fiio E11
    Some updates.
    Phil
    Leak test and bleeding
    Phil
    Super Meanarator
    Sep 2004
    Upper Serangoon
    15,781
    Looks like a pretty sharp bend for your GPU in! Pretty awesome if you manage that without kinks.
    Quote Originally Posted by sabe View Post
    The tubes are measured and cut with the components installed. That particular run did kink a bit but I managed to keep it in shape via the Coolsleeves.
    Phil
    did you manage to find those radgrillz bro ?
  1. Replies: 2
    Last Post: May 31st, 09, 10:18 PM
  2. (News) Dream Son
    By MinMin in forum Chit Chatting
    Last Post: Jan 1st, 09, 01:43 AM
  3. Chao Ah Lian Blogger.......WE LOVE YOU
    By booest in forum Chit Chatting
    Last Post: Nov 25th, 05, 11:28 AM
  4. My Ah Lian mod cum A64 w/c rig
    By Philip in forum Case Modding & Project Logs
    Last Post: Jul 18th, 05, 09:51 PM
