Page 1 of 3 123 LastLast
Results 1 to 15 of 37
    Mar 2008
    In Singapore, on a Land.
    5,178
    Project Scarlet Cardinal
    Short Intro
    Actually, this project was started, or should I say, plans were drafted for this project bout 2months back. But things had taken a change, hence this new thread.
    Old Thread
    Not much physical work was being carried out though....
    Was actually more on the planning and thinking, and experimenting.
    Actual work started bout 2 weeks back, and now, seems to have taken shape for me to start posting!
    posting when i'm hungry....dun mind
    Starters
    Current config:
    AMD P2 940BE
    DFI 790FXB M2RSH
    Team Xtreem Dark GB 1066
    PC HD4670 PCS
    Seagate 500GB .12 + WD 320GB
    Seasonic M12 430Watts
    Lian Li PC7-FW
    Will be focusing on these 4 points.
    • Addition of new Hardware
    • Sleeving
    • New Color Scheme
    • Lighting
    With an unconfirmed 5th point, Custom Panels
    Aesthetics is the goal for this project.
    Before continuing to the main course, would like to thank the "Kitchen"
    In no particular order,
    Froze
    Kozato
    Bianco
    Sulphur
    Gary from Uvnium
    Colin from Convergent
    XS forums
    and a bunch of them for guidance and help.
    Next on the menu, Main Course!
    Home Entertainment: Xtreamer NMT | Hotway Probox 4 Bay Enclosure| WD Green 808.88GB x2 Seagate 750GB
    Currently using: Samsung Galaxy Note II
    Cowon J3 + FischerAudio DBA-02 + Fiio E11
    Mar 2008
    5,178
    Main Course---Addition of New Hardware
    Lite-On 24x DVDRW, been waiting quite a while for them, decide to hoot 1 more for this rig.
    Scythe Kaze Q
    , recently announced only, simple and does its job
    Special thanks to goenitz33 from HWZ, got the above 2nd hand at rather good pricing
    Mar 2008
    5,178
    Main Course--Sleeving Part 1
    TechFlex PET Sleeves
    Seasonic M12II 430Watts
    Can be said my first time sleeving a PSU.
    Big credit goes to Kozato for helping me remove some darn connectors
    Will attempt to uni-sleeve as much has I can
    Outcome
    24pin mobo
    8pin +12V
    SATA Cables
    SATA Connector
    SATA Connector
    trance mixer pgross's Avatar
    dover
    10,735
    nice..looking forward to see the completed rig
    <<my main rig>>
    cpu>intel i7 6700K , mb>asrock Z270M-ITX , rams>2 x 8gb kingston hyperx fury ddr4 ,gpu>nvidia gtx titan x on dell ultrasharp U2713HM, psu>evga p2 750w case>fractal design nano s
    hd>samsung 850 pro 512gb + 1tb western digital blue
    inputs>cm quickfire tk + logitech g100s + steelseries qck
    dfi lanparty fan
    dfi nf4 ultra >dfi dk p35 >dfi lt x48 >dfi ut x48>dfi ut x58 >now - dfi nf4 sli-dr ..
    Jan 2007
    4,916
    hmm i think the heatshrink is not really good?
    Mar 2008
    5,178
    Sleeving Part 2
    Sleeved Fan Controller wires
    (those I need only)
    3x Zalman F3 Sleeved
    That's bout it for sleeving i guess.
    50ft of 1/8 definitely not enough , could only sleeved what was essential. Probably will order some more if possible
    *Some of the pics dun match, but they are the same, just messed around with the contrast for some *
    Quote Originally Posted by pgross View Post
    Thanks! Will provide daily updates! Stay tuned!
    Quote Originally Posted by larrylaw View Post
    They were alright I guess, just need a longer time to heat
    was here. bianco's Avatar
    Dec 2007
    1 22 N, 103 48 E
    3,463
    looks good bro. i was thinking of doing the mixture of red and black sleeving also... too bad i dun have red sleeves though. and definitely 50ft of sleeve is not enough. haha.
    Mar 2008
    5,178
    Quote Originally Posted by bianco View Post
    Yea hahas should have factor in the need for excessive sleeving!
    Registered User jesmen's Avatar
    Sep 2005
    West Coast
    1,817
    Cool, nice Red and Black sleeving.
    Mar 2008
    5,178
    Main Course--Hardware, Fan Controller
    Scythe Kaze Q
    Simple but well protected packaging.
    Come's in a foam box, with the Controller wrapped in plastic
    Simple Outlook
    As always, I removed the Female Molex for less clutter, and sleeved only the fan cables I need.
    Tested it, everything's working well.
    I believe this can be DIY, but the time and skills needed, materials too, makes this SGD$22 FC worth to get.
    Mar 2008
    5,178
    Installed into my 3.5" Drive Bay
    Image is intentionally soften, as the drive bay is yet to be ready.
    Dec 2007
    1 22 N, 103 48 E
    3,463
    if you managed to change display to red... i will be bugging you in to teach me! haha. looks nice bro.
    Mar 2008
    5,178
    140mm Fan Mod
    For my Front Intake.
    Simple, but would be brighter if had redone the whole wiring
    Mar 2008
    5,178
    New Color Scheme
    That's all I have to show for now.
    Nvr powdercoat nor anodize
    Mar 2008
    5,178
    Pictures fixed and updated
  1. Desire @ The Scarlet
    By hisfoodblog in forum Chit Chatting
    Last Post: Mar 27th, 09, 05:57 PM
  2. MWTS>LG Scarlet FULL HD 42"
    By illusi0n in forum Singapore Marketplace / Garage Sales
    Last Post: Oct 15th, 08, 07:49 PM
  3. RED delivers new rendering of Scarlet 3K camera
    By bigfoot in forum Lights, Cameras, Action!
    Last Post: Jul 12th, 08, 08:35 PM
  4. Wts: Lunch For 2 At The Scarlet Hotel.
    By stan. in forum Singapore Marketplace / Garage Sales
    Last Post: Sep 16th, 07, 08:21 PM
