Results 1 to 12 of 12
    Need to build a system for work.
    Hello Everyone.. I have a SGD$600-700 budget to build a system for work..
    I just need the motherboard, cpu and ram (512 should be good right?
    The rest has been handled..
    Please give me suggestions for the system.. Thanks..
    p.s. Intel should be better for heat management since its a system for work right?
    Oh I forgot.. I need the casing and powersupply as well.. That would take SGD$100-150?
    Please help me asap.. Thanks.. Its an emergency.
    hamsterboy
    Intel p4 2.4C, abit IS7-E, 2X256MB PC3200 ram...wadever...just get any case...chieftec is good...just tt i hate the blue led...its driving me nuts...get one with a not-so-powerful LED..juz jokin...
    but...u might as well get a 2Ghz Celeron...abit bh7 and get 2XPC2700 256MB ram...althoe 256 would be enuff for word processing...
    PS wad work???
    Um, Typical Office Work? But maybe sometimes for gaming too..
    Btw, why Abit and not Asus?
    :P josh's Avatar
    May 2003
    Terra, Sol III
    7,403
    it is obvious... since your using it for work... then get a amd setup
    its cheap too..
    abit nf7-s S$197
    athlon xp 1700 tbred b / or barton 2500 S$110/S$178 (level 5) check all the shops find for green chip(1700)
    geforce 4 ti4200 $150++
    2x256mb twisterx twinmos ddr 400 $156
    segate barrcuda 80gb S$121
    floppy disk abt $16
    dvd-cdrw tdk cyclone $105
    buy a cheap casing wif side panel = $60
    as for heat magment... as long as ur not overclocking dun worry...
    heck my com is running on a 400mhz overclock and still i am using the orginal heatsink...no problems here...
    you can get a better graphic card with the spare money... say a ati radeon 9500 to softmod to a 9700pro... or get a 9500pro???
    if you get this then you can do much more then work...
    hamsterboy
    erm sorry...im biased towards abit ...many ppl like it..
    AMD is cheaper and better if u want...get a 1700+or 1800+ whichever cpu is cheapest...then get either a nf7-s or an a78nx or sumthin..then get pc2100
    I am the Omega
    its cheap too..
    abit nf7-s S$197
    floppy disk abt $16
    You better be talking singapore dollars... or else you're siteing tremendously high prices.
    Would someone please give me the exchange rate of SPD:USD?
    :P josh's Avatar
    May 2003
    Terra, Sol III
    7,403
    yes singapore dollars... us:sg 1:1.7
    p4's rock
    2.4c or 2.6c
    asus p4p800 dx or non dx depending if u need the extras.
    2x256mb pc3200 or higher brands like twinmoss, corsair, kingston, ocz ect....
    good powersupply! i can not stress that enough.
    grafix card, will u be playing games? if not get the ti4200 if u r playing games get the 9600pro or 9500pro if u can find one.
    80gig western digital 8mb( those come with 3 year warrenty)
    i am omega currency converter here
    http://www.oanda.com/convert/classic
    Drug Dealer cccp's Avatar
    Jun 2003
    9,541
    maybe vrforums shd have an inbuilt currency autoconverting script :p
    One of the most addictive web-based game
    www.goldentowns.com
    Playing this web game which claims that the in-game gold is backed by real gold. Quite a vibrant community out there. Seems like the whole bitcoin thingie is spreading to the online gaming world. They are coming up with their own crypto-currency as well. Look for me, i am cccp1979lcw inside!
    I am the Omega
    ....actually that's a pretty good idea...
    Daredevil
    lolx
    i am omega < ---
    i recall you fuming about my qoute of prices before
    hehee
    cHeErs
