Page 1 of 3 123 LastLast
Results 1 to 15 of 38
    Master of past & present Shamino's Avatar
    Feb 2001
    The Abyss
    13,447
    Basic Voltage modding guide for Beginners
    Detailed guide for beginners:
    http://www.vr-zone.com.sg/?i=757
    Newbie of Past & Present yantronic's Avatar
    Nov 2004
    Paid Accomodation
    22,893
    Sorry, not supposed to file the soldering iron tip one.
    To keep tip clean go get a piece of sea sponge (SLS Byteron 04-04/SLT) and damp it. Tin the tip by runing solder over it and wipe clean (on the sponge) after that. Wipe between handling, tin before/after use and your iron tip will not get "sooty" over time.
    But then only 25W maximum iron can be used for SMT. Too large wattage resistor tend to change value.
    The opinions expressed above do not represent those of VR-Zone (VR Media PTE LTD Singapore) or any of their affiliates.
    anoM
    Gonna give it a try
    rundymc
    Quote Originally Posted by yantronic
    you have to file when it gets sooty
    killer_939
    you have to file when it gets dry hard solder on it
    Bipolar Narcissistic Dreamslacker's Avatar
    In an idle mind
    7,755
    Quote Originally Posted by rundymc
    Quote Originally Posted by killer_939
    Wrong and wrong!
    You do not file the tip!! Never!! The tip is coated because rosins/ flux can be corrosive.. If you file the tip, the coating will come off and the rosin/ flux will eat the tip away...
    When the tip gets sooty or dull-looking, you need to use a tip refresher to clean off the oxidation.. Then clean the tip on a wet sponge and prime it with fresh solder..
    An Idle Mind Walks in Dark Places
    Certified Network n00b
    ★STX★ Static-X's Avatar
    Nov 2004
    Ubi
    20,167
    Quote Originally Posted by Dreamslacker
    Wrong and wrong!
    where to get tip refresher ? is it ex ?
    Static-X
    | Intel C2D E6400 | AsusTEK P5K Pro | Leadtek 7600GT TDH 256mb | GeiL DDR2 PC 6400 1GB x 2 Ultra|
    |1 x Hitachi 80GB PATA 1x Hitachi 160GB SATAII| Audiotrak Prodigy 7.1 | Seasonic S12 430W PSU |
    In an idle mind
    7,755
    Quote Originally Posted by Static-X
    Kaichin.. It's about $7 for a small tin...
    Thanks for the guide!
    I'm about to order me some variable resistors for that 6600gt vcore/vmem modding, I'm a bit confused though when reading the specs for the resistors:
    Resistance: 10 Ohm
    Turns: 20 x 360°
    Max voltage: 200 V
    Max CRV: 1 %
    Max effect: 0,75 W vid +70 °C
    Resistancetolerance: ±10 %
    Temperature-coefficient: ±100 ppm/°C
    Temperature-range: −55 till +125 °C
    will this do the job?
    ..if I have the wrong one could you please point me to a proper one?
    thanks
    Gigabyte GA-G33M-DS2R
    E6600 L629F (lapped flat naked core!)
    Mushkin EM2-6400 2x2GB @1070MHz! 5-5-5-18 1.9volts!
    mi11er
    voltage measure for 9npa+ sli
    Could U tell me please how (where) exactly to measure Vcore voltage (I suspect the info from BIOS is not correct) of EPoX 9NPA+ SLI ->http://www.epox.nl/images/products/m...20sli_full.jpg
    Feb 2001
    The Abyss
    13,447
    You should start a sperate thread for this, but here you go:
    measure the MOSFET legs with your multimeter and check which one reads 1.xxx v. thats ur vcore read.
    Be careful not to shoert out neighbouring legs....
    kiwi.fruit
    Pics are not working for me anymore
    Quote Originally Posted by kiwi.fruit
    http://forums.vr-zone.com/announcement.php?f=56
    Whatever floats your boat...
    kiwi.fruit
    Oh well, temporarily is a broad term then They are down for more than a month I think. I hope it gets sorted out
    DaLaLLeR
    i also dont see the pics of "VR-Zone > NVIDIA 7800 GS AGP Voltage Mods" and "VR-Zone > Voltage Modding Guide". and the pics are some kind of important in this case...
    i have a 7800gs and i would like to do a volt mod, so could someone send me an e-mail with the print version of the 2 articles?
    thx a lot
