Results 1 to 15 of 26
    [Mini Review] Jonsbo V3+ ITX Case
    jonsbo乔思伯
    Measuring 200 mm (W) x 240 mm (H) x 210 mm (D), the Jonsbo V3+ is made with 1.5mm brushed anodized aluminum. It supports ITX boards, ATX PSU, 2 storage drives and a dual slot GPU (up to 19cm long).
    The unit is protected by foam and comes with a simple instruction sheet.
    We suggest using the plastic cover (or any other smooth surface) to as a base when installing the system to prevent scratching on the brushed finish.
    Rear of the unit. Pretty compact unit.
    Perforated side panel to allow fresh air intake for components. Remove 4 screws here to access the insides of the case.
    Bottom of the unit also allows air intake to HDD/SSD and other components.
    Mount up to 2*2.5" or 1*2.5" + 1*3.5" drives here. Remove 6 screws to gain access to this plate.
    Superspeed USB 3.0/2.0, HD audio supported on this chassis.
    First steps: get motherboard in and prepare SATA cables to route under GPU.
    SSD and HDD in. Face sata connectors inwards.
    Prepare a GPU under 190mm in length. Palit and Leadtek GTX650Ti models seem to fit well among the locally available models. (Any has better cards to recommend?)
    GPU into the case. PSU to go in last.
    We're using the FSP300-50HMN for this unit. Fan facing inwards to draw hot air our from CPU. With some cable management, you should get plenty of room for decent airflow. We suggest non sleeved wires on the PSUs as there's less bulk to deal with.
    (FSP Hexa 300, 400, 500 are good choices)
    During gaming, CPU (2500K, 95w) doesn't exceed 60'C and GPU (Palit GTX 650Ti 2GB) stays under 55'C. Very reasonable temps for a tiny gaming rig.
    Recommended rig: (Configured at PC Themes,1st March 2013)
    Jonsbo V3+ with FSP 300w $109
    Intel i3 3210 (3.2ghz) + Asrock B75-ITX $266
    8GB Gskill DDR3-1333 $59
    Leadtek GTX 650Ti 1GB OC $185
    1TB Toshiba HDD $79
    Total: 698
    Add SSD if required.
    If you'd like something even smaller with onboard GPU, take a look at our review of the Jonsbo V2.
    http://forums.vr-zone.com/tech-dynam...v2-silver.html
    Tech Dynamic Pte Ltd
    514 Chai Chee Lane #04-11
    Singapore 469 029
    6717 3000
    www.tech-dynamic.com
    www.facebook.com/techdynamic.sg
    NEVER GIVE UP! shaoz2388's Avatar
    Jun 2009
    Bishan/Toa Payoh
    3,224
    wonder hows the temp like for the gfx looks a little tight between the hdd and the gfx
    Register User spyboy48's Avatar
    Dec 2005
    Pasir Ris
    14,739
    Sata cable can route under the board for cAble management. Saw somebody did it before, just sharing.
    Blacklist: Biff73
    Often criticism is experienced as a narcissistic injury(Narcissistic personality disorder), low self esteem, cannot except but take offence.
    ~~~ A good name is rather to be chosen than great riches!!! ~~~
    i7 980X OC with Ex58 UD3R thread.
    http://forums.vr-zone.com/overclocke...processor.html
    My MystiQue CM case : http://forums.vr-zone.com/showthread.php?t=262828
    System Specs 1 & 2: (SNiper3/3770K/G.Skill 4GBx4 2400MHzCL9/AmD6870/SevenTeam1400W/Open Rig (M5G/3770K/Samsung4Gbx4 2400MHz/470GTX/320Gb/Acebel 550w/Samsung2333sw)
    My New world record:
    http://www.futuremark.com/pressreleases/60363
    My Past & present Toys : Intel 630/830/940/4300/E6300/E6600/Using2140/6750/8400/E3110/E2160/E7200/E8400 Q816A275/E8400Eo Q827A429/E8500Eo Q820A713/E8500Eo Q822a720/Q6600Go/i920Co/i920Do3848/i980x 3003A957/i750/3960X/3930K/3770K x 3/3570K
    thanks for the advice! it'll definitely be neater to route the cables under the motherboard.
    here are the temps during gaming. should be well within acceptable range.
    Singapore 469 029
    6717 3000
    Thanks!
    can check out our review of the V2 too!
    [Mini Review] Jonsbo V2 Silver
    Singapore 469 029
    6717 3000
    Dec 2005
    Pasir Ris
    14,739
    Nice pricing
    Blacklist: Biff73
    Nice pricing. How much is the Jonsbo V3+ alone?
    WTS:Biostar A880G+ matx board for amd phenom ii cpu
    http://forums.vr-zone.com/motherboar...-ii-cpu-2.html
    Registered User rigourous's Avatar
    Dec 2011
    Pasir Ris
    140
    Quote Originally Posted by coyote2 View Post
    PCT Selling $79..
    https://fbcdn-sphotos-b-a.akamaihd.n...77675983_o.jpg
    i5-3570K + MSI Z77 MPower|Corsair Vengenance 4 X4GB DDR3-1866 CL9|Crucial M4 128GB |Samsung SpinPoint F3 1TB|HP 24x DVD RW|FSP Aurum CM Series 650 W 80+ Gold|NZXT Phantom 630 Gunmetal|Samsung S23A550H|SteelSeries Sensei Raw|SteelSeries QCK Mass|Ducky Shine 2 White LED Cherry MX Red Switch |Logitech Gamepad F310|HiVi Swans M10|Creative Sound Blaster Z
    Quote Originally Posted by rigourous View Post
    Very good.price! Even cheaper than the cm elite 120 advance. Lets hope this gives a run for the money for overpriced itx chasis.
    Dec 2005
    Pasir Ris
    14,739
    looks good n elegant in brush anodised alu...Kiv on my list.
    Blacklist: Biff73
    Retired Hardware Player colonelsoh's Avatar
    May 2010
    Segar Road
    6,725
    nice! i was looking at the jonsbo site.. they state support standard ATX psu and GPU?
    super tempting to go ITX.
    oh wait.. no fan support on this but still KIV
    Intel Core i5 4460 + Hyper 212X | ASUS B85-Pro Gamer | Palit GTX 1070 Super Jetstream 8GB | Low Profile Kingston Value Rams 2x4GB DDR3| Plextor M5 Pro Xtreme 128GB + Western Digital Blue 1TB | Dell U2312HM LED Ultrasharp 23" |Creative Gigaworks T40 Series II | FSP Aurum 650Watts Modular Gold | Lian Li T60-B | Windows 7 Ultimate 64bit
    LG G3 32GB Gold | Fiio X1 + 16GB microSD | FiiO E11K | Shure SE215 LTD with NocturnaL Audio Calyx 4-conductor Copper Custom Cable | Comply T100
    this one supports 3x 40mm fans but its not easy to get a good one locally and jonsbo doesn't bundle them with the chassis.
    for PSU, its limited to 14cm ATX (FSP Hexa, Raider) and
    for GPU its limited to 18.5cm
    - Palit GTX650Ti 2GB,
    - Leadtek GTX650Ti 1GB,
    - Asus GTX670 DirectCU Mini when its out
    Singapore 469 029
    6717 3000
    Dec 2005
    Pasir Ris
    14,739
    Quote Originally Posted by Tech-Dynamic View Post
    40mm fans available at SLT.
    Blacklist: Biff73
    Hi
    What is the tallest heat sink that I can put into this casing of I use pico psu?
    Assembled a htpc using i3 processor but want to swap psu and fully utilize the space and improve cooling. Appreciate your inputs.
    Thanks
  1. [Mini Review] Jonsbo V2 Silver
    By Tech-Dynamic in forum Tech Dynamic Virtual Service Center
    Last Post: Mar 28th, 13, 09:54 AM
