Results 1 to 13 of 13
    How much does the thermal grease help in cooling your sys ?
    I thought thermal grease brand is quite important and can probably affect a temperature difference of up to 10 degree. Probably a 20% importance in cooling your system , what do u think ?
    .Also can someone tell me the usual good brand of thermal compound that you use and how much u got it for and from where?
    vr-zone.com alpha1ma's Avatar
    Feb 2008
    17,371
    thermal paste is to aid in the conducting of heat from the heat source to the heat sink..coz there might be pockets of air which exist in the irregular surface of the contacts (invisible to the human eye) which is a poor conductor of heat..the purpose of this thermal paste is to fill in this gap to ensure a better transfer of heat..
    recommend getting tx2 or mx2...
    initialli i was quite a fan of arctic silver 5 but its messy to clean up..
    [Project Log] Fiery Black Ki7ight (Classified)
    Custom Watercooling System | Custom Radiator | Personalised Winnie the Pooh Box from edge2o.com
    hmm how about the ocz freeze compound ? where to find mx2 in slq ?
    Happy User cheesified's Avatar
    Nov 2008
    Hougang
    3,564
    pc theme @ 18 dollars, i nvr really searched or saw it anywhr else.. u cld try bargaining
    NZXT Tempest v1
    MSI p55a Fuzion | ci5-760 @ 2.8ghz, W/Hyper 212 & MX-2
    2x4GB Crucial Ballistix Tacticals DDR3-1600Mhz CL9
    MSI GTX660 Hawk | Samsung S24B350T
    SteelSeries 5Hv2/Altec Lansing 2.1
    Enermax Modu 82+ 625W Bronze
    Western Digital AALS 2x 640GB /EADS 1x 1TB
    SteelSeries Sensei W/ Destructor | G105
    Aerocool Modern-V
    4x Gelid UV Wing 120mm | 2x Xigmatech 140mm
    up to 10 degrees ? thats rare.
    mx-2 is on the higher end, if you aren't that picky you can get some star thermal paste for $1.50 or anabond for $3.50.
    i'm getting the gelid gc1 thermal compound from the MO of scythe and gelid products. from many reviews, it seems it's a pree good thermal compound and it even comes with an applicator.
    GO ORDER IT FROM THE MO SO I CAN ALSO ENJOY THE MO PRICE!
    Case: CoolerMaster CM690 CPU: Intel Core i7 3770K Motherboard: Asus Z77 Sabertooth Graphics Card: ASUS DirectCuII GTX 670 NON-TOP Memory: 2 x 4GB Corsair Vengeance LP Storage: Crucial M4 256GB (OS), OCZ RevoDrive 128GB, Hitachi Deskstar 7K3000 2TB, WD Caviar Black 1TB PSU: Corsair HX620 Case Cooling: 8 x Gelid Wing 12 UV Green Fans + 1 x Gelid Silent 12 PWM CPU Cooling: Thermalright Silver Arrow w/ IC Diamond 7 Thermal Compound w/ 2 x Gelid Wing 14 UV Blue Fans
    how often should one REapply the thermal paste?
    also VERY IMPORTANT Q: how to check whether the heat contact surfaces are totally flat? it's very hard to see once the gigantic heatsink is fitted on as it blocks the entire view of the contact surface.
    using graph paper and a big light source.
    all you have to do is spread a cheap white thermal paste on your gigantic heatsink, mounting it then notice where the paste doesn't spread to.
    Nov 2008
    Hougang
    3,564
    Quote Originally Posted by zacho_ View Post
    i am quite new to application of thermal paste but it seems that using an applicator wldnt be as good as using a 'drop of pea' that kind of thing.. not sure how to describe tho.. haha
    NZXT Tempest v1
    Aerocool Modern-V
    Super Meanarator
    Sep 2004
    Upper Serangoon
    15,781
    Just put your thermal paste around the size of a rice grain (GO KITCHEN FIND THE SIZE!) on the middle of your GPU/CPU. Once the pressure comes down, it will spread the thermalpaste evenly to the sites. Its better than spreading it anyhow and leaving air pockets in the middle.
    Finally, you don't need to re-apply your thermal paste if you're using a good one like MX-2 / Ceramique or AS-5
    Nov 2008
    Hougang
    3,564
    oh ok. thanks lots! oh btw, does the height of the rice grain matter? haha...
    NZXT Tempest v1
    Aerocool Modern-V
    Super Meanarator
    Sep 2004
    Upper Serangoon
    15,781
    Not art! No need so precise
    Quote Originally Posted by sirbljm View Post
    Based on experience I have never found a perfectly flat cpu or heatsink
    Lapping FTW
