Results 1 to 12 of 12
    Registered User AndyS's Avatar
    Ubi Ave 1
    1,153
    After a REBOOT, 400GB hard-disk went from NTFS to RAW. Downloaded ptedit32 NEED HELP!
    Did a search and found that many people have this problem, when the file system of the hard-disk corrupted, went from NTFS to RAW and thus unable to access the data & files in the hard-disk.
    Tried to use scan disk and others, but UNABLE to proceed due the file system as RAW.
    Downloaded ptedit32.exe application as advised by other websites, change "TYPE" to 07 as NTFS back again, NEED to set/configure "BOOT RECORD" as some people mentioned but do NOT know how to... sigh...
    ANYONE have used ptedit32 application before??? PLEASE HELP/SAVE me...
    SOLVED!
    Quote Originally Posted by AndyS View Post
    Thanks all and jowy_ham who also SMSed me!
    I have found an application: TestDisk - CGSecurity
    downloaded it and it worked! ... only after I CAN do a windows scan-disk on the drive FINALLY scanning for damaged file system and bad sectors... BUT before that CANNOT even scan-disk because of RAW status...
    NOTE: This is the solution for damaged file system of a hard-disk which can happen quite often as researched on many other forums, BUT you still CANNOT save hard-disks which are damaged PHYSICALLY, especially bad sectors...
    Mods - please put STICKY as this solution do NOT require any recovery programs and CAN RECOVER from NTFS -> RAW and back to NTFS !!!
    Intel i7-3770k | ASUS P8Z77-V-DELUXE | Kingston Hyper-X 2000MHz DDR3 8GB Kit Dual Channel | EIZO FORIS FS2333 IPS LED-LCD | MSI R7970 Lightning Twin Frozr IV 3GB single card | Samsung 20x SATA DVD-RW Drive | WD VelociRaptor(DHTZ) 1TB 10kRPM SATA HDD | Samsung SpinPoint F1 750GB SATA-II HDD | Creative SoundBlaster Z | Creative MegaWorks 550THX | Silverstone Strider 850W Modular PSU | Windows 7 Professional 64 bit
    Intel Core2Duo E8400 (3Ghz) | Asus P5B-E Plus | Kingston 4x 1GB DDR2-667 Rams Dual Channel | Philips 220CW 22" Wide LCD| MSI Radeon HD7870 2GB OC | LG 22x SATA DVD-RW Drive | Western Digital VelociRaptor(HLFS) 150GB 10kRPM SATA HDD 16MB | Samsung 80GB SATA HDD | Samsung 400GB IDE HDD | Creative Audigy 2 ZS | 2.1 speakers/subwoofer | iCute 627 & Seasonic S12II 520W PSU
    Registered User jowy_ham's Avatar
    May 2005
    Extreme NE
    3,654
    Try using EASEUS, choose 1 that meets ur needs. Their software is quite good, so far I have managed to recover files that were deleted, file system that is corrupted.
    I'm using Data Recovery Wizard Professional 5.0.1
    Ubi Ave 1
    1,153
    Thanks, noted.
    But ptedit32 known to be able to turn back corrupted file system from RAW back to NTFS again... ANY brothers have experience with this application???
    Newbie of Now and Forever wwenze's Avatar
    Jan 2005
    10,098
    I dun use that, but the ultimate boot CD has a few software that can do what you mentioned.
    Ubi Ave 1
    1,153
    You are my saviour. Literally.
    Thank you
    Ubi Ave 1
    1,153
    Quote Originally Posted by tengjj2000 View Post
    Thank you
    What happened in your case?
    My ext hdd suddenly became RAW format. my gf's FYProject was in it. You saved me. I tried ZAR, but it was limited to only 4 Files. using the testdisk, i've just extracted everything i needed out Thank you.
    Hmm.. only 1 of my folder is corrupted.. luckily the rest can be saved... Thank god.. Thank you
    Ubi Ave 1
    1,153
    You're welcome... (lucky for me nothing is corrupted at all!)
    Hope this thread can SAVE more people... this save ME more than 80GB of family/kids photos and videos since 2004 in this 400GB hard-disk!
    TestDisk saved my a** some yrs back when my 1TB partition crashed & I couldn't access my data.
    But I know my data was still intact, so used it to restore the NTFS partition info. 1TB back in action after the long hours of deep scanning.
  1. [CLOSED] closed
    By ncs1778 in forum Storage
    Last Post: Dec 8th, 10, 08:09 PM
  2. [CLOSED] 2 x 400GB Western Digital Hard disk. 3.5inch
    By yeast in forum Storage
    Last Post: Jun 21st, 10, 06:45 AM
  3. WTS: EXT hard disk Seagate 500GB & 750GB internal hard disk SATA
    By cheap4sale in forum Singapore Marketplace / Garage Sales
    Last Post: Nov 13th, 09, 10:36 PM
  4. WTS: Seagate SATA 3.5" 400GB Hard Disk
    By chan888 in forum Singapore Marketplace / Garage Sales
    Last Post: Sep 23rd, 09, 12:02 PM
  5. Want to buy 500GB, 400GB IDE hard disk drives!
    By harddiskppl in forum Singapore Marketplace / Garage Sales
    Last Post: Aug 13th, 06, 05:12 PM
