For any better deal, kindly refer to the below link for latest Promotion
https://littlemart.wordpress.com/promotion/
One Stop Audio E-storz
Portable/Desktop Amplifier, Pre-Amp,DAC, Bluetooth/Wifi Streamer DAP, Conditioner, Headphone, Cable, Accessories etc
Promotion items: https://littlemart.wordpress.com/promotion/
Ordering info:
a) Website: http://littlemart.wordpress.com (Follow my E-Store to get latest update on Group Buy Deal)
b) Contact mobile:+6597223884 <Whatapps / SMS>
c) Email: [email protected]
d) By Normal Mail /Registered Mail /Ta Q bin / AMK Pickup in evening in Weekday (timing to be arrange)
Miu Audio
Miu Audio iH2 - Tube Portable Amplifier
The circuitry is carefully design the in order to make the smallest casing but still provide an audiophile quality tube headphone amplifier for the market.Very very small in size and Elegant looking Tube Portable amplifier. A decent Tube portable amplifier easily cost over $1000. Nice sounding especially it comes with a Jan Philips JAN6111WA Tube. This is the improve version 2.0 from the previous version 1
- Vacuum Tube: Philips JAN6111WA
- Compact size with built-in re-chargable 2200MHA Lithium battery.
- Super silent circuitry
- Audiophile-graded parts and components
- Sound field selector for different music enjoyment
- Pack inside a Elegant Piano Finish Wooden Box
Selling at $699
Currently available in Blue / Red
Do not be deceive by the look of this little tube amp. You will not believe it is SO POWERFUL that will Blown you Away ! Easily can drive speaker the like of Dynaudio which has 86DB !
Fun to Play as it supports two major tube series:
(1) 6DJ8, 6922, 6N11, 6H23n, ECC88, E88CC, etc., and
(2) 12AU7, 5963, 5814, ECC82, etc
Miu Audio MKTP-2 - cute little mini tube amplifier/ pre-amp / power amp with 15Wx2
Spectacular audio performance which a open sounding with good separation.
-TA2024 Tripath Class T Amp
-2*15W output power
-Tube use – 6922EH (Electro Harmonix Russia Tube)
- Can use as tube integrated amplifier/PreAmp/PowerAmp and it has headphone amp
- Front panel jacks for headphones and iPod/iPhone/MP3 input, rear panel connection for line level input
- An ideal match for quality loudspeakers with efficiencies of 84-88 dB or more
-Very mini in size – Only 65mm x 60mm x 98mm
Selling at $260
Currently available in Black / Orange / Silver-Blue
Miu Audio MKTP-2 MKII - cute little mini tube amplifier/ pre-amp / power amp with 25Wx2
Spectacular audio performance which give warm sweet, silky sound throughout the mid and high frequencies.
-TPA3106D2 Class D Amp
-2*25W output power
-With Gold plated speaker binding pole
-Can use as tube integrated amplifier/PreAmp/PowerAmp and it has headphone amp
-Front panel jacks for headphones and iPod/iPhone/MP3 input, rear panel connection for line level input
-High Power an ideal match for for wide variety of quality loudspeakers
Selling at $295
Currently available in Black / Gold / Orange / Silver-Blue
Miu Audio MKUP-2 – Hybrid 6922 Tube Amplifier 2*25W with MM Phono (New Arrival)
Tube integrated amplifier with Phono preamplifier. The tube preamplifier section is completely separate from the power amplifier section, Phono preamplifier MM—1 input Line and 1 input Phono. Chassis slightly bigger then MKTP2
- TPA3106D2 Class D Amp
- 25wpc + 25wpc @ 4 Ohms, 18wpc + 18wpc @ 6 Ohms, • 12wpc + 12wpc @ 8 Ohms.
- Front panel jacks for headphones and iPod/iPhoneMP3 inputs, input to line level input.l Selector Line/Phono.
- Rear panel connections for LINE input, PHONO input and speaker outputs
- High power allows for use with a wide variety of quality loudspeakers
- Spectacular audio performance!
- Very compact in size – only 75mm x 70mm x 110mm.
*Supports two major tube series:
Selling at $399
Currently available in Orange
Miu Audio MKUP-2 - mini tube amp with USB DAC / pre-amp / power amp with 25W X2
-2*25W output power
-Built in usb dac which support up to 24bit /96Khz sample rate
-The tube preamplifier section is completely separate from the power amplifier section
-Very compact in size - only 75mm x 70mm x 110mm.
Selling at (No Stock)
Miu Audio MKTP-1 - Tube Pre-amp with headphone Amp
Tubed preamplifier with headphone amplifier. With its fashionable iridescent color design and very small dimensions, the MKTP-1 is one of the world’s smallest and most beautiful preamplifier! It a prefect match with the mini power amp Miu Audio MKP-1
- Only 65mm x 25mm x 98mm.
- Front panel jacks for headphones and iPod/iPhone/MP3 inputs.
- Rear panel connections for power amplifiers, as well as rear panel line level input for CD.
- Ideal complement for headphones, iPods, MP3 players and more. Can be used with powered speakers for a complete
system. Perfect for obtaining better sound from your PC.
- using 6922EH Pre-amp Tube
Selling at $160
Currently available in Orange / Black
Miu Audio MKP-1 - mini power amp 2 x 15W output power
Stereo power amplifier. To be used by connecting it to good quality speakers whose efficiency is at least 86/88 db. Perfect match with the mini Pre-Amp the like of Racoon SG-300 / Miu tech MKTP-1
- TA2024 Tripath Class T Amp
- 2 x 15W output power
- Dimensions 67mm x 27mm x 118mm (very mini in size)
- High performance audio performance
Selling at $135
Currently available in Silver
Miu Audio MKAU-1 - mini MM/MC Phono Pre-Amp
MKAU-1 is one of the world’s smallest and most beautiful MM/MC phono preamplifier!
Only 65mm x 25mm x 98mm. Very mini in size.
Front panel selector for MM or MC, and rear panel connections for PHONO and LINE outputs
Ideal for high-performance turntables. Prefers amplification of high quality
Selling at $150
Available in Silver / Black
Ordering info:
Gustard
GUSTARD DAC-X22 ES9038PRO(Latest Flagship model)
Description
X22 ES9038PRO decoding chip based,tie-in da separation matrix power supply circuit,digital part is domestic first USES the adaptive master clock technology,analog part specifically for debugging a class division lines, 9038 can perfect the audio playback.Has feeling and simple sense is low frequency and intermediate frequency stable and accurate,high frequency fully,elegant,and has deep broad sound field with excellent analytical and have a very good musicality.
Features
Using a piece of ESS company flagship chip ES9038PRO decoding,completely independent power supply,grounding,obtain the best performance;
Using adaptive technology of master clock and asynchronous master clock,two kinds of working mode choice,perfect for different source;
CPLD programmable logic chip,to construct the logical function of digital integrated circuit,clock management,2nd PLL digital plastic,DOP demodulation,PCM/DSD depop exclusive technology such as switch,laid a solid foundation for good quality;
Used special ring transformer 2 only high quality sound for digital and analog power supply respectively,realize fully independent supply each other;
Full balance Discrete components Analog Line.Balance / RCA output simultaneously.
Analog LPF circuit adopts independent development division line,carefully adjust the parameters of each level,in order to achieve the best working condition;
Support 0dB ~ -90dB file digital volume,cooperate with the attached with the high quality of the remote control is convenient to adjust the volume;
All interface support DSD hard solution:
IIS support DSD64,DSD128,DSD256,DSD512 hard solution;
SPDIF,Optical,AES/support the EBU DSD64 hard solution (DOP);
USB support DSD64,DSD128,DSD256 hard solution;
Extensive digital filtering
PCM:M-SHARP /M-SLOW / L-SHARP / L-SLOW / HYBRID / APODIZING /BRICKWALL,
DSD: 47K/50K/60K/70K;
USB XMOS company USBAUDIO use special chip U8 (XU208 and U8 kernel is the same), support PCM384 DSD256
Screen brightness is adjustable,no operation automatic memory after 10 seconds,the next boot keep last time Settings,humanized operation control;
Take note online Retail @USD1099 which is around $1500 exclude GST.
Here selling at: $1450
Gustard DAC A20H – Dual AK4497 (New Flagship model)
GUSTARD recently announced a new DAC– A20H, It is the successor of X20 DAC, Gustard have researched DAC for years and developed some good products in very good reputation. A20H is based on dual AK4497 DAC chips which is the latest flagship product from AKM, The DAC is specially optimized for better performance and sound presentation. LPF section is constructed with discrete components at class A working status,It is the biggest advantage than the other DACs on market,The transistors in LPF are matched for original sound.
Features
– Dual AK4497 latest DAC chip from AKM, One for each channel to get better dynamic and pure sound.
– Using CPLD programmable logic chip,Burned with self-own code to manager clock, 2nd PLL digital shapping, DOP decoding, PCM/DSD dop switch etc, It is the foundation of amazing sound presentation
– Headphone amplifier is constructed with discrete components,It works at class A,With balanced and unbalanced output to cover all needs of head-fi
– Original fully balanced circuit from DA to amplifier without any conversion.
– DAC section and headphone section use two 50W toroidal audio power transformer
– LPF section is constructed with discrete components at class A working status,Each stage is carefully optimized.
– A20H can be used as pre-amplifier, Gain is selectable between high and low, Support up to 60 steps analog volume adjustment,With remote control user can turn-off the pre amp function.
– Support DSD high definition audio
– I2S: DSD64/DSD128/DSD256/DSD512
– Spdif/Optical/AES/EBU: DSD64(DOP mode)
– USB: DSD64/DSD128/DSD256 Multiple digital filter for different taste, DSD support Wide BW/Narrow BW, PCM support Short Delay Sharp/Short Delay Slow/Sharp/Slow/Low-dispersion Short Delay Filter/Super Slow.
– USB input is powered with XMOS U8 asynchronous receiver, Support PCM384Khz DSD256
– Adjustable brightness of screen,Low preset setting if no operation after 30 seconds, Auto memory if no operation after 10 seonds, Will load the latest setting when power on next time.
– Fully aluminum enclosure/chassis, Optional sliver and black color
Selling at: $1300
(Note: the DAC/U12 default does not come with any standard USB cable due to the Gustard mentioning that standard usb cable cannot match well their products so they have decide not to give out standard USB cable.
Gustard DAC-X20 - Dual ES9018 Sabre - Flagship model
- Dual ESS Technology Sabre Reference 32bit ES9018 DAC chip,R and L sound Chanel one on each side
- Automatic adaptation master clock technology and Asynchronous master clock technology Two clock mode can be freely selected.
- XMOS 32bit USB receiver chip which is best performance asynchronous USB audio solution.
- CPLD programmable logic device. Soft control ES9018.
- Three files gain, volume can be adjusted. Attenuation adjustable from 0 to -99DB.
- TFT LCD screen, adjustable contrast.
- Power supply with two O-type transformers, Digital and Analog independent power supply, and use Discrete Components regulation Voltage
stabilization.
- Full balance Discrete components Analog Line. Balance / RCA output simultaneously.
- Digital Input: balanced Spdif AES/EBU port, RCA, Toslink Optical input and USB,(Key switch)
- Come with Remote controller
Selling at: $1250
Gustard DAC-X12 - ES9018 Sabre
- Digital Input: balanced Spdif AES/EBU port, RCA, Toslink Optical input, USB and IIS support DOP decoding, can be accessed by the number of broadcast SACD listening to music.
- Analog Output: balanced analog output via XLR port, single ended output via RCA port
- EESS Technology ES9018 Sabre Reference 32bit chip
- USB 2.0 interface allows asynchronous playback 1BIT / 2.8224MHz or 5.6448MHz DSD digital signal sampling rate. That is
support DSD64 and DSD128. Coaxial Optical AES / EBU support DOP64, SACD playback can be accessed by the number of
broadcast music.
- Maximum support 384KHZ / 32Bit, DSD USB
- DAC Support sample 24bit 192k
- USB support: Windows, Mac OS, iOS (need purchase connector), Android4.0 or more (most models)
Selling at:
a) $735
Gustard DAC-X9 - Dual WM8741
- Dual WM8741
- USB 2.0 interface for asynchronous playback 1BIT / 2.8224MHz sampling rate of DSD digital signal also is DSD64
Selling at:
a) $525
Gustard H20 High End Class A Headphone Amplifier / Pre-Amplifier
A sequel to the popular H10, the Gustard H20 is a powerful class-A headphone amplifier with a variety of inputs and outputs. In fact, with an output of 12,000 mW at 32 ohms, it’s one of the most powerful we’ve ever sold. In addition to the 4-pin XLR output, it has a 6.35-millimeter low gain and a 6.35-millimeter high gain. There’s even an output for dual 3-pin XLR: a welcome sight for those who use this rarer balanced out with their headphones. Two XLR outputs function as a prestage and are ideal for sending out to high-end studio monitors. Each channel uses two independent amplifying units to form a symmetrical output line. The front class consists of a single 4-way amplifier circuit, using two LM49720 dual op amp. Have a separate pre-stage output,can be connected to active speakers or pure after the class. The use of matrix relay volume,effective to ensure that 4-way volume unanimous; The H20 has already garnered a lot of excitement from Head-Fi users.
Description:
Line input: 1*RCA, 2*XLR
Line output: XLR * 1 (Preamp output)
Amp output: 1*6.35mm single-ended high resistance,
1*6.35mm single-ended low resistance
2*Three-core balanced Output, 1*four-core balance output
There is Pre-amp output,Gustard H20 could be used as Power amplifier and Pre Amp connecting Active Monitor.
Come in Black / Silver
Selling at: $1250
Gustard H10 High End Class A Headphone Amplifier
Class A headphone amplifier with high current current output. For each channel in the amp it has 2 independent amplification circuit. The H10 features two independent amplification circuits for the left and right channels, four gain switches, two RCA inputs, and two balanced XLR inputs.
There are 4 pre-buffer adjustment functions build in with the amplfier and that mean the amplifier using pre-stage buffer and main amplifier components. By using 4 paris audio power tube output circuit, the H10 could easily drive variety of different impedance headphones.
The Gustard H10 built in with 2pcs 25W transformer and they correspond left and right channels power supply and highly reduce the channel crosstalk.
Selling at:
a) $525
Gustard XMOS U12 USB Interface
USB Interfaces not only provide just the various interface for connection to DAC, it is also a high Performance device to reduce the jitter to the minimum. It is often encourage to go through them before to a DAC. Not even a Asyn DAC can reduce much jitter as much as an USB Interface does
- DSD support 128, PCM supports 384K
- wo 0.1PPM precision crystal 45.1584M 49.1520M
- International voltage AC115V-230V, the need to manually adjust
- XMOS-U8 chip, support 32BIT/500MIPS digital signal processing unit
- Input :USB input x1
- A total of four kinds of output: Coaxial (RCA), optical fiber, AES / EBU, IIS (HDMI port)
Coaxial fiber AES / EBU output formats IEC60958 and AES3-r2009 standard limits the maximum support 24Bit / 192kHz; IIS
can transmit 32B 384K
Selling at:
a) $225
XiangSheng
DAC
Xiang Sheng – DA-03A (Tube DAC)
-Using PCM1794 + CS8416+OPA2604
-USB, OPT, BNC, COA input
- USB - TE7022 or XMOS U8 (Asynchronous)
-Tube and Transistor output
-Tube use – GE5670
-Support 32kHz-192kHz
-Support 16bit-24bit
-Built in Power unit
Selling at
a) $300 (USB TE7022)
b) $320 (USB XMOS U8)
Available in Black / Silver
Popularity -![]()
Xiang Sheng DA-05A - Dual PCM1794 (This is not a Tube DAC)
- Using the famous TE8802L as USB chip (TE8802L is a upgrade version from TE7022) which can support 24bit/192K. It is an
Asynchronous
- USB part adopts IIS output signal from TE8802L, through PCM1794A decoding, not TE8802Ls Spdif signal, because the Spdif signal
should though CS8416 chip, then enter PCM1794A , thus will increase the jitter value, lose the advantage of asynchronous, also cannot
play out the advantage of TE8802L.
- PCM1794 as decoding part,and with the TI's Mono mode, can provide more dynamic and wider frequency response.
- Using 9 OPA2604 for op-amps which made by Korea,and with gold coated RCA connectors and coaxial connector.
- 5 digital signal input switching : AES balance output ,BNC, coaxial , fiber optic , USB
- 2 Output Level :balance output: 9V unbalance output:2V
- LED display on the sampling rate
- ALL resistors and capacitors are audiophile grade
Selling at:
a) $455
Ordering info:
Tisbury Audio
mini Passive Preamplifier
A simple line controller with audiophile acclaimed sound quality. Use it to switch between multiple sources, connect multiple amps, control active speakers or add outputs for a subwoofer, headphone amp or just about any line-level device.
Key feature:
- SMD Stepped Attenuator (1% tolerance thin film SMD resistors, ±0.25 dB channel balance at all levels, gold plated contacts)
- New Look, More Inputs and Outputs (3 inputs, 2 configurable outputs)
- Selectable Fixed Attenuation (0 dB, -10 dB, -20 dB. Set by switches on base)
- Configurable Outputs (Variable – level set by volume control and Variable or Loop. Set by switches on base)
- Input Impedance: 10 kOhms
- Output Impedance (at full volume): 0 Ohms
- Power Supply: None (it’s passive!)
- Handmade in UK (Handmade American black walnut facia and anodised aluminium body, laser engraved markings)
Selling at $299
See the Review here:
https://littlemart.wordpress.com/cat...view/pre-amps/
Tisbury Domino Phono Preamplifier
The Domino is a versatile, high performance phono preamplifier. Selectable gain settings and input loading allow any MM or MC cartridge to be used. Ultra high-spec components along with our laser engraved walnut and aluminium enclosure achieve high-end sound and build quality but without the price tag.
Any Cartridge, Any Amp
Domino has four switchable gain settings: 40, 49, 58 and 67 dB. This allows virtually all cartridge, from high output MM to low output MC, to work with any amp. Particularly handy if you’re also using our Mini Passive Preamp, as you won’t have to worry about system matching.
Passive RIAA Equalisation
RIAA equalisation is achieved with a passive filter located between two separate gain stages. This configuration gives the best of all worlds: low noise, high accuracy, and exceptional sonic performance. 0.1% thin film resistors and 1% polypropylene film capacitors result in an exceptional 0.2 dB RIAA accuracy.
Linear Power Supply with Off Board Transformer
Domino’s power supply uses an off board 15 V AC transformer (not to be mistaken for a switch mode DC adaptor, it won’t work with DC) keeping electrical noise away from the sensitive gain stages. This gives hi-fi grade, linear regulated power rails in a small package, without having to worry about hum or ground loops.
Handmade in England
Our products are designed, made, and tested in our London workshop for true British quality hi-fi.
Technical Specifications
Gain setting: 40 dB 49 dB 58 dB 67 dB
Sensitivity for 300 mV out 3.0 mV 1.0 mV 0.38 mV 0.13 mV
THD, 1 kHz at 1 V out <0.001% <0.001% 0.003% 0.004%
Noise, A-weighted -91 dBV -88 dBV -74 dBV -70 dBV
Crosstalk at 1 kHz -103 dB -97 dB -77 dB -76 dB
Overload margin at 300 mV out 30 dB 30 dB 30 dB 28 dB
RIAA accuracy ±0.2 dB, 20 Hz – 20 kHz
Input capacitance 220 pF
Input impedance Selectable 100 Ohms (MC) or 47 kOhms (MM)
Output impedance 82 Ohms
Maximum output voltage 9 V RMS
Enclosure Laser engraved American black walnut and aluminium
Size D x W x H 139mm x 105mm x 60mm
Power supply 15 V AC 500 mA adaptor. Do NOT use with DC adapters.
Reviews
“The Domino exceeded my expectations, and then some… It’s a quiet, balanced and superbly competent performer – and just downright enjoyable to use. For the price, it’s an amazing accomplishment.”
Read the full review at wallofsound.ca
“The Tisbury Audio Domino is a rare thing, sounding like it was built up to a quality target, not down to a target price. It will outlast turntable, arm and cartridge upgrades.”
Read the full review at tnt-audio.com
“By far the best phono I’ve heard anywhere under 200, and I’d be happy if I’d spent 400. Friends who side by sided it with me have been amazed by what it can do.”
Read more customer reviews at ebay.co.uk
You can google your own for more
Musical Paradise
MP-301 MK3 mini tube amplifier
The MP-301 series is the most popular Canadian Musical Paradise tube amp which was first released in 2008. In 2011, the MK2 was introduced to the market with many improvements. The enhancement process has never been stopped. Today, we want to introduce you the new MP-301 MK3, the third generation of the MP-301 series. After collecting large amount of users’ feedback and recommendation during the past years, we bring the MP-301 series to a new high performance level.
Headphone can be the perfect push AKG 701,702,712, Sennheiser HD600,650,700,800, Bayer dynamic DT880, DT990, T90, T1, HIFIMAN HE560, HE6, Audeze Austrian Emperor hereby LCD-2 etc
Features:
- One amplifier supports 6L6 (6P3P), KT66, 5881, EL34, KT77, KT88 and 6550.
- Default tube: Shuguang 6L6 (6P3P) x 2, Shuguang 6J8P x 2
- Topology: Class-A Single Ended
- Output Powe:6.5W(6L6,KT66) / 7W (EL34,KT77,KT88) (Speaker), 2W x 2 (Headphone)
- Output impedance: 4Ω- 8Ω(Speaker), 32Ω-600Ω(Headphone)
- Auto biasing design that eliminates manual adjustment.
- Class A single ended; Zero negative feedback.
- Built with high grade genuine components.
(US Military Vishay Dale resistors. RIFA 450, Rubycon, Philips BC and Nichicon capacitors.)
- 24K gold plated input and output terminals.
- Transformers are made with oxygen free copper wire and Japanese Z11/M6 silicon core.
- 2 oz. thick copper PCB.
- Proven by many audiophiles. Excellent sound quality guaranteed.
Tube Replacement Guide:
V1 V2 6SJ7, 5693, 717A, 713A, 6SH7, 6SD7, 6J8P, 6*8
V3 V4 6P3P, 6L6, KT66, 5881, EL34, 6CA7, KT77, KT88, 6550
Review can be see here:
https://littlemart.wordpress.com/201...ube-amplifier/
Selling at $535
Musical Paradise MP-701 – 6SN7 Tubes Pre-Amplifier (Latest Arrival New model)
Musical Paradise offer this new MP-701 6SN7 tubes pre- amplifier as an add-on upgrade to their existing product range. MP-701 help to improves sonic details, dynamic and imaging.
Highlight:
– Remote: IR Volume Remote Control
– 3X RCA input, 2X RCA output
Specs:
•Output voltage - 6V Max depending on gain settings.
•Signal tubes - 12AU7 (stock), 12BH7, E80CC
•Rectifier tubes - 6.3V series: 6Z5P (stock), 6X5.
5V series: 5AR4, GZ34.
Selling at $899
Musical Paradise D2 MK2 Tube DSD Balance DAC - Latest Model New arrival
We are excited to announce Musical Paradise MP-D2 MK2 DAC. The first DAC in the world supports user changeable DAC modules. At this moment, it can support AK4490 and AK4497 DAC modules. ES9038Pro DAC modules will be available soon in September 2017. Since MP-D2 MK2 is a future proof modular design DAC, we will continuously develop more new DAC modules in the future. In addition, MP-D2 MK2 has built-in headphone amplifier. It can drive low sensitivity and high impedance headphones quite well, such as AKG K701 and Sennheiser HD650.
Musical Paradise fans around the world were anticipating MP-D2 for a long time. We put in our best effort to pursuit the excellence of MP-D2. The moment you listen to MP-D2, you know you have never experienced anything like it. With native DSD support, it brings you the most high definition listening journey in a powerfully vivid way. Take a deeper look, you will find more innovation.
Highlight:
- 4 pre-amp tubes + 1 rectifier tube, 4 capacitors with detachable design, allow you to roll the tubes and caps for better sound quality.
- It also supports DSD (support PCM 44.1kHz-768kHz, DSD 64-256.) natively and fully balanced XLR output to release the potential of your HiFi set up.
- 2 pieces of modular AK4490 / AK4497 / ES9038Pro (1 pieces for each channel) which is strong at both musical and technical part.
- Pre-amp RCA output, can connect with power amplifier directly.
Default tubes (6z5p x 1,6n11 x 4). Other compatible Tubes :
Rectifier tube: 6Z5P,6X5,5AR4,5U4G,274B,5T4,5R4,5Y3,GZ34,5Z3P,5Z2P
Pre-amp tube: E88CC,6922,6DJ8,6N11,6H6n,6H30Pi,12AU7,12BH7
Selling at
– $1350 (AK4490)
– $1650 (AK4497)
– $1850 (ES9038pro)
Musical Paradise MP-B1 APT-X Bluetooth Receiver
MP-B1 employs Qualcomm APT-X Bluetooth 4.2 stereo audio receiver and Hi-Res ES9023 24Bit DAC to provide the audience high fidelity Bluetooth audio listening experience when playing music from a smart phone or tablet. Further more, it has two USB quick-charge ports. Both USB ports support Android QC3.0, Apple and Huawei quick charge technology. Each port can deliver up to 3A current, so it can charge your phones and tablets much faster to save you valuable time. MP-B1 is not only for home audio, but also for car audio. It adds Bluetooth wireless music playback feature to your car with AUX input. Even if your car comes with factory Bluetooth input, the sound quality is still not as good as MP-B1 can provide. MP-B1 is guaranteed to sound significantly better than car stock Bluetooth input.
Selling with the following Package Contents:
A) Car kit option: Car plug cable, 3.5mm to 3.5mm audio cable for car AUX audio input - ($95)
B) Home kit option: Premium DC 24V 2.2A power supply, 3.5mm to RCA audio cable - ($110)
C) Full kit option: Includes everything in both car kit and home kit - ($120)
MP-P1 Tube Phono Preamp
Canadian Musical Paradise we spent extensive amount of time on research and development, testing, fine tuning to final assembly. We are glad to announce that the amazing MP-P1 tube phono preamp is ready for order.
There are many kinds of phono preamps in the market, but most of them employ low cost integrated operational amplifier (OPAMP). They are based on feedback loop circuit which does not sound quite natural or musical. To design a most natural analog sounding phono preamp, we employ high quality Toshiba Audio JFET transistors and 12AX7 vacuum tubes, and use single ended Class A, zero negative feedback hybrid circuit for amplification and passive RIAA network for equalization.
It presents a thicker and warmer midrange, huge sound stage, excellent high and low frequencies extensions, natural and musical sonic performance to the audience.
Here are some highlights about it:
1. Passive RIAA network and zero global negative feedback design to provide extremely natural and musical listening experience.
2. Four 12AX7 tubes running at Class A mode for the MM amplification section.
3. Toshiba 2SK170 HiFi Jfet is employed for the MC to MM step-up section.
4. MC section can be optionally powered by external 12-24V battery supply (sold separately).
5. US military grade Dale resistors; high grade Rybycon, Nichicon, Panasonic capacitors.
6. Obligato Gold coupling capacitors.
7. Z11/M6 high grade EI transformer and chokes.
8. Gold plated PCB.
9. Gold Plated connectors.
https://littlemart.wordpress.com/201...-phono-preamp/
Selling at $750
Optional purchase
MP-U2 Linear Battery Pack For MP-P1
Designed for MC to MM step-up section of MP-P1 phono preamp to provide a more clean sounding.
Voltage: 18-21V. Capacity: 2600mAH
Comes with 24V 3A charger.
Selling at $150
Musical Paradise MP-U1 - USB Isolation
PCHIFI is quite popular today. Audiophiles always want to achieve the best USB transceiving signal quality in order to improve DAC sound quality. They change different kinds of high quality USB cables, but usually don’t pay attention to the dirty computer USB 5V power. Computer power supply use high efficient, but noisy switching power supply. It has lots of interference affecting USB DACs sound performance. You may think the mobile power packs for cell phones can help, but they are still not clean because they use switching DC to DC chip to up-convert 3.7V to 5V.
In order solve this issue, we developed MP-U1. It employs the best Panasonic 3400mAH Li-on batteries and high current low drop out (LDO) linear regulators. It puts out 100% pure 5V DC power, isolates the dirty USB 5V from computers, eliminates noise, so USB DACs can sound noticeably better.
It can be used to power other 5V devices, but make sure the device consumes less than 2.1A current.
Selling at: $150
MP-S1 MK2 high performance speakers
MP-S1 MK2 is designed for serious HIFI listeners who want to have great listening experience without paying big-ticket price. This all new MK2 version employs high end “Spider web” transparent Vienna Acoustic 5.5″ Driver Woofer (usually can found in their high end speaker eg Haydn speakers) and Norway SEAS®, 27mm SONOLEX™ soft dome tweeter (usually found in PMC series like TB2i, FB1i, OB1i….) to provide the best music playback performance. It is a good match to Musical Paradise amplifiers.
Impedance: 8 ohms with Sensitivity : 88db, the speaker is easy to drive by any amplifier in class, sounding easily comparable with speakers at price range of 1500usd and above. Recommended amplifier power : 5-100W
Cross Over:
Carefully design by Muscial Paradise Designer to fully optimize the speakers performance. US military enthusiast using wire-wound resistors, high-purity oxygen-free copper 99.9 large air inductors, Germany fever MKP capacitors, effectively enhance performance .
Sound Features:
Sound natural balance , both good analytical, but also delicate Naiting musical.
Exterior:
Finishes: Cherry
Size : 19CM wide X 29CM deep X 30CM high
Weight : 7KG
Selling at $699/pair
See the Review Here
https://littlemart.wordpress.com/201...aradise-mp-s1/
Ordering info:
SMSL
Amplifier
SMSL VMV VA2 Headphone Amplifier
VA2 mini is high quality portable headphone amplifier.It is the design for hi-fi application through state-of -the -art circuit.
If you have both low and high impedance headphones and are looking for an amp that handles both, the SMSL VMV VA2 might be just the ticket. With two different power outputs that cover the range of 32 to 600 ohms, the VMV VA2 delivers solid performance in a compact and aesthetically pleasing form factor.
High-impedance Power:
>120 mW at 600ohm
>250 mW at 300ohm
>580 mW at 100ohm
>330mW at 32ohm
Low-impedance power:
>120mW at 100ohm
>75mW at 32ohm
Selling at $185
SA-98E
-TDA7498E Class T Amp
- 2*160W big power output amp
DAC
1) SMSL M8A - ES9028Q2M DAC (new arrival)
This is one of the popular mini desktop DAC from SMSL and well talk about in many Hifi forums eg the like of Head Fi.
The new version M8A has now upgrade their DAC chip from ES9018K2M upgrade to ES9028Q2M and XMOS U8 upgrade to the second generation XMOS-XCore200 Xu208. It now can sample from 384kHz to 768kHz, DSD is upgraded from DSD128 to DSD512, and exclusive custom driver supports Native DSD, which is the industry leader. Power input to switch to 5V DC input, the user can use the matching AC adapter, you can also use the mobile power supply as well as any linear power using 5V DC input.
- Upgraded version of SMSL M8
- DAC chipset upgraded to ES9028Q2M. the chip's signal to noise ratio up to 129dB, while the distortion was -120dB;
- The clock system uses independent ultra low clock jitter, ultra low phase noise crystal as the audio clock;
- USB receiving chipset upgraded to new XMOS- XCroe 200 Xu208
- Support sampling rate up to 768kHz, DSD512
- High quality power supply design, the use of multiple low-noise LDO power supply, so that the sound more pure;
- Customized driver , supports Native DSD
- Using audiophile grade components
- User-friendly operation, decoder sound style and digital filter can be set;
- High precision CNC aluminum alloy shell;
- Operation set up automatic memory;
- 100V-240V global universal voltage range.
Selling at $345
2) Sanskrit SK6 Wolfson DAC (upgraded version)
- DAC Optical/Coaxial/USB input(upgrade version)
- CM6631A+WM8740+JRC2114MD
- Support 44.1kHz-192kHz
- Support 16bit-24bit
- USB support: Windows, Mac OS, iOS (need purchase connector), Android4.0 or more (most models).
- Available in Black / Silver
Selling at $150
3 ) VMV Magic
MAGIC USB DAC is a high quality PC-USB DAC (External sound card) for hi-fi
-Using CM6631A and AK4390 chip
-USB (2.0) asynchronous (asynchronous) transmission
-support up to 32bits/192kps
-Supports ASIO, WASAPI and other drivers
-power by USB port from PC/Laptop for input
-Coaxial & linear output (RCA).
- Available in Black / WSilver
Selling at $190
4 ) TV-DAC
A TV-DAC for LCD TVs or set-top box. TV-DAC is set in one of the mini-fiber coaxial decoder, connected via an optical or coaxial signals to the TV-DAC decode, TV-DAC output analog signal can be an external headphone or amplifier, multimedia speakers achieve powerful sound.
- Input – mini OPT, COA
- Output – 3.5 MM headphone jack
- Support up to 192Khz/24Bit
- Power by USB Input
Selling at $50
5) SMSL B1 APT - X Bluetooth Receiver with independent DAC
SMSL B1 HiFi Stereo Audio Bluetooth CSR 4.2 Receiver DAC with NFC Black
SMSL B1 is stereo bluetooth receiver DAC, using CSR bluetooth 4.2, supports APT – X transmission format and NFC
Independent of the DAC and the ear of the independent design, let the sound quality is better
Abundant output interface easy to use on different devices, outputs:Optical,Coaxial,RCA,3.5mm headphone port
Internal battery provide up to 24 hours of long-distance wireless reception
Equipped with external bluetooth antenna, the stability of the transmission distance up to 10 meters above
Description:
SMSL B1 digital NFC-enabled Bluetooth receiver allows you to wirelessly play music from your phone on your A/V receiver, home stereo system or powered speakers. High-quality audio streaming from your phone or other Bluetooth audio transmitter in CD-quality sound through your speaker. Freedom to move freely in your house as you listen, conveniently control and stream music from up to 33 feet/10 meters away. Provides output through Optical, Coaxial, RCA and 3.5mm headphone ports
Selling at $89
GEK (GAOERKE)
Amplifier
1) GEK GA-50 (new arrival)
- TI Class D TPA3123 chip
- 2 x 50W output power
- Texas NE5532 Ops preamp
- Using high performance hi fi grade capacitors PHILIPS, ELNA, nichicon, EPCOS, DALE etc
Selling at $85
2) GEK GA-98 (To Replace SMSL 98E)
GEK’s GA-98 use a Swiss STMicroelectronics Ltd. (STMicroelectronics) of TDA7498E core. The circuit and design is similar to SMSL 98E with except it has addition pre op amp inside.
All using high quality components to create the best quality performance, use EPCOS, PHILIPS, TOCOS, Panasonic, DALE, ALPS, WIMA, ELNA ‘s high fever accessories and components, it’s high quality exquisite HIFI digital amplifier
TDA7498E power is 160WX2 (power supply = DC36V maximum measured) power is very powerful. Can push dual 8-inch big box with no pressure
2X OPA2604 (not available in SMSL 98E and standard GEK98) – It is designed specifically for audio -specific op amp , sound mellow, Thick and smooth. It has neutral warm which is known as the operational amplifier that has a tube sound.
Good in low frequency control , Soundstage and separation as well
Selling at $145
Currently available in Black / Silver
Ordering info:
Topping
Amplifiers
1) PA3
Ideal for driving bookshelf speakers, PA3 is a compact power amplifier equipped with ST’s class-D TDA7498E amp chip. It delivers 80 watts per channel at a 4-ohm load—enough to drive 10-inch speakers—and has a curved, screwless front panel design that looks sleek in any setup. Two LEDs indicate the input status, while an MCU monitors issues like overload, overheating, overvoltage, and low voltage. On the rear panel, you’ll find two RCA inputs. Additional components include an ALPS potentiometer, EPCOS film capacitors, a Nichicon hi-fi capacitor, and an OMRON relay.
Selling at $145
2 ) TP22
- Using Tripath TK2050
- 30W*2 output power
- Supply 2 way RCA input
Selling at $140
3 ) MX3
A digital amplifier with a built-in Bluetooth receiver, DAC, and headphone amp, the Topping MX3 does it all. This versatile, compact unit can be used to power your passive speakers or headphone amp. And in systems that already have a discrete headphone amp (like Topping’s conveniently stackable A30), the MX3 can function as a DAC or preamplifier. It outputs an impressive 247 mW of power at 32 ohms in the headphone amp section—a 190 percent improvement over its predecessor, the VX3, and enough to power demanding headphones like the Massdrop x Sennheiser HD 6XX. MX3 it’ll deliver 38 W per channel at 8 ohms to your speaker.
Selling at $185
4 ) Topping TP32EX
A multi-function amplifier with excellent sound, meeting the need of users who need a integrated amplifier.
-Using Tripath TK2050, supporting 50W*2 output power.
-Built-in 24bit 192k coaxial DAC
-24bit 96k / 16bit 192k USB DAC
-Built-in Headphone-AMP
-USB support auto On/Off.
-Come with a remote control
Selling at $230$180
5 ) Topping NX1A (new model)
The Topping NX1A (NX1 upgraded version) has been designed for MP3/MP4/mobile phone/computer that can not get best effect of high impedance from the headset due to the low power.
NX1A keep same circuit and component of NX1 to keep a same sound. But after modifying other part to save power, IT playback time up to 150h, that’s 50% improvement of NX1. It takes less than 3 hour to fully charge the battery. Even 5 minutes charge could provide 10 hour playback.
Its USB charging port has been enhance to be able to use standard Micro Usb cable for charging
- 100mW*2 output power.
- Built-in rechargeable lithium battery, approx 150 hours playback time.
- Selectable gain (H & L)
- Use high quality components to get better performance. WIMA capacitance, EPCOS capacitance and ALPS potentiometer
- Small size
Selling at $75
6 ) Topping NX3
Following the very popular NX1 portable amplifier, Topping launch another value for money portable amplifier NX3. Internal amplifying chip using TI TPA6120A2.
- TI TPA6120A2 amplifier chip
- OP Amp - OPA2134
- Mega bass
- low Battery LED reminder
- USB intelligent Charging
- 2400mAh large-capacity battery
- 25hr playback time
- Come in Black/Silver Color
Selling at $110
7) Topping NX4(New Model)
TOPPING NX4 is a high-performance HIFI portable USB decoding headphone amplifier. Built-in a high capacity rechargeable lithium battery for its easy to carry out and long life; Analog and Digital signal input choice. Output of 307mW * 2 , enough power to drive whatever headphones. (Lighting Port, Type-C Port, Micro Port…) No matter what kinds of playing devices (IOS/Android/PC/MP3) can find the right accessories to connect NX4, easy for you to listen to beautiful music. Moreover, NX4 can be connected to the computer through a USB cable as a high-performance external sound card, the maximum specifications to support 192kHz / 32bit.
Selling at $170
Currently available in Black / silver
8 )Topping NX5(New Model)
AD8610+BUF634 high performance combination
Every sound channel of Topping NX5 use low noise HIFI Operational amplifier AD8610 of American ADI as Signal amplifier.
Every channel use one piece of BUF634 as output buffer of output circuit.
- Mega bass
- low Battery LED alert
- 30hr playback time
Selling at $170
8 ) Topping A30 - Desktop Amplifier(New Model)
Overview:
- Two outputs for different impedance of the headphone: 3.5MM and 6.35MM headphone port, can be used for a variety of headphones and earbuds.
- Two kinds of operating voltage mode and three kinds of gain (0dB / 9dB /18dB) selection mode.
- A30 uses the high-performance TI HIFI chip OPA161, OPA2134 (changeable) and TPA6120.
- Maximum output power of A30 can reach up to 1551mW * 2.
- Aluminum body, each part is through high automation, high-precision machining creating (Laser engraving).
- Power by a special customized three-way high-performance linear power supply
Most competing products use 1x15V or etc adapter to the amplifier, this 1x15V will be convert inside the amplifier and cause noise and interference. But we use linear power adapter to provide 2x15V and 1x8V to A30, which help A30 avoid these problem. 2x15V used for high fidelity headphone amplifier circuit. 1x8V used for MCU, LED and relay. Less noise, less interference.
- Using Hi-fi grade NEC relay, WIMA capacitance, Nichicon FW series HIFI electrolytic capacitor, ALPS potentiometer etc
Specifications:
Analog input 1 x RCA (L + R)
LineOUT 1 x RCA (L + R)
Headphone output 1 x 6.35 headphone jack; 1 x 3.5 headphone jack
The recommended load impedance range: 16-600Ω
Maximum output power:
1551mW x 2 (PO = Hi, 6.35 headphone port, RL = 32Ω, THD + N = 1%)
291mW x 2 (PO = Hi, 6.35 headphone jack, RL = 300Ω, THD + N = 1%)
152mW x 2 (PO = Hi, 6.35 headphone jack, RL = 600Ω, THD + N = 1%)
757mW x 2 (PO = Hi, 3.5 headphone jack, RL = 32Ω, THD + N = 1%)
258mW x 2 (PO = Hi, 3.5 headphone jack, RL = 300Ω, THD + N = 1%)
143mW x 2 (PO = Hi, 3.5 headphone jack, RL = 600Ω, THD + N = 1%)
Selling at $170
Come in Silver
DAC
1) D30 - DSD DAC(New Model)
Receiving good impressions on Head-Fi as a great value DAC, Topping D30 valuable for money for its performance. It features the highly regarded CS4398 DAC chip—along with Hi-fi grade WIMA, EPCOS, and Nichicon FW capacitors and the OPA2134 high-fidelity op-amp: and supports DSD64, DSD128, and PCM formats up to 24 bit/192 kHz. Its front panel fitted with two LED indicators and two switches: one for on/off and the other to switch between optical, coaxial, and USB.
D30 can build a suit set with A30 and other mini speaker amplifier (other products and the shelf need to be purchased separately).
This can be a good alternative to the Schiit Headphone Amplifier + DAC bundle.
Highlight:
- D30 supports USB ,Coaxial and Optical Fiber. Input range 16-24bit/44.1-192KHz
- Two switches,two light indicators
- Aluminum shell
- XMOS asynchronous interface
- Cirrus CS4398 decoding chip
- Japan KOA resistance
- Genmany WIMA capacitor
- Germany Siemens capacitor
- HD audio OP AMP OPA2134
Selling at $180
2 ) C1
- Using TE7022L
- LED display frequency
- USB input
- SPDIF RCA+Optical output
- 32kHz-96kHz, 16bit and 24bit
- Very small size
Selling at $90
Others
1) Mini Desktop Hi-Fi Acrylic Rack(New)
The mini acrylic rack not only well organize your equipment on your desk and looks even more neater then before. Good to hold up to 3 equipment eg (mini amplifier, mini headphone amp, mini dac). This mini hifi rack is specially design for Topping D30 (DSD DAC) + A30 (Headphone Amp) + one more mini amplifier.
Dimension:
Size: External <17.2cm(L) X 15.8cm(D) X 11.2cm(H)>
Size: Internal <(13.2cm(L) X 11.8cm (D) X 4.3cm x2 (H)>
Max Weight: 3KG (each layer 1KG)
Selling at $50
Ordering info:
Creates a magic audio system for you. A good alternative to Sonos Connect Products as well as Chromcast Audio.
Access to music resources
Music streaming
With the iEAST Play application, you can stream music from
1) Cellphone memory;
2) USB flash driver and USB mobile HDD;
3) Home NAS network;
4) External analog audio Source input to SoundStream/StreamAmp and re-transmitted to other room by multi-room control;
5) Popular online music services of millions of songs and thousands of radio stations, such as Spotify, Qobuz, Tidal, Pandora, vTuner, Napster, TuneIn, iHeartRadio etc.. (note: the online service availability varies by regions)
This gives you a totally different experience without turning on computers in traditional way.
Audio system control
Control all your music with your smartphone, tablets
Free iEAST Play applications for Android, iPhone, iPad and Mac let you comfortably control your audio system from the palm of your hand. Download the iEAST Play application of iOS version from App Store and Android version from Google Play.
Multi-room control
1) Play the same song in every room in perfect sync.
If you have multiple speakers that connect to SoundStream/StreamAmp, You can easily group the devices and stream the same song to all rooms in perfect synchronization.
2) Stream different songs to every room, at the same time
You can tune into a radio station in kitchen, play a song from online music service to bedroom, stream local music from cellphone memory to living room in simultaneous way.
Other amazing features
Multi-zone control
You can group different devices to different zones, each zone can play different songs.
Choose channels
You can choose left channel, right channel and stereo mode on the application, which can make you
Preset content
Six buttons to preset playlists or radio stations, you can play the preset contents using the remote controller, even not necessary to open the application on you smartphone.
Sleep timer
You can set the time on the application to turn off the streaming automatically in case you fall asleep or you only want to listen to music for certain time. This also makes your life more energy-saving.
Alarm clock
Set the alarm to wake up your favorite music or radio station automatically in one room or all rooms.
Firmware upgrade
New features and music services automatically delivered for free
iEAST Play application will automatically notify you If there is new firmware with new features and music services. Globally, you can freely upgrade your firmware to the latest version. You only have to click one button, the system will update itself, and you will see on-screen prompts and hear voice prompts.
iEast SoundStream Pro– M30 (new USB version)
Selling @ $199
Popular -
See the Review:
iEast SoundStream Pro Wireless Streamer Review | StereoNET
Demo is possible but have to arrange a convenient time as my time pretty occupied by my family. However i still encourage to get 1 back (get a couple more later if you want to setup multi-room to room streaming) and start to explore your own. Is really fun and cool! Full of functions and features and many possibility on the setup.
iEast StreamAmp – AM160 (Wireless Multi-Room Stereo Amplifier)
Selling @ $325
AudioCast M5 (Alternative to ChromeCast Audio)
Airplay receiver Wireless Music Streamer WIFI Music receiver Streams Wireless Audio & Music to Speaker System through Wi-Fi Network From Mobile Device
Wireless Multi-Room & Multi-Channel Audio Streaming features, providing easiest multi-room control system. Allow you to play the same song or different songs synchronously throughout different rooms, meeting different demands at the same time
Audiocast M5 wifi audio receiver is a small device that plugs into your speaker for steaming music through WIFI.Once Set up, simply use your smart phone and tablet and laptops to cast your favorite songs to the best speaker in the house.
Never been so easy to play your favorite songs from music streamer.Choose the streamer from AudioCast apps to stream the music instantly to your speakers. Search,play,pause queue songs and change the volume right from your phone - control anywhere in your house.
Control all you want via one APP.With AudioCast APP, you can stream music , tunes from your smart phone memory,NAS,UPNP network, Internet. Besides that, AudioCast offers useful functions like music alarm ,sleeping timer ,stereo pair.
Massive Music and tuners resources.AudioCast wifi speaker adapter includes massive music and tunes resources ,such as music ,internet radio ,talk show...you can find all you want from here
Selling @ $59
Ordering info:
APPJ
APPJ PA1501A – Mini Class A Vacuum Tube Amplifier with NOS 6AD10 Tube
PA1501A tube amp is the latest tube amp from APPJ in 2015. It’s upgraded version of PA0901A.
PA1501A using imported tube 6AD10, there are many other tubes can instead 6AD10 on the market, such as Amperex, RCA, Sylvania, Westinghouse, GE,Chief, Tung-Sol, Admiral, Arcturus, Raytheon, Zalytron, Aladdin, Zenith, IEC Mullard and so on.
6AD10 composed of amplifier performance is much better than the amplifier performance with 6BM8, ECL805, ECL82,6F3 composed in three aspects, noise, frequency response, and power, especially power, 6AD10 output 3.5W power is what the 6BM8, ECL805, ECL82 and 6F3 cannot compare. Sound wise is much more nicer than EL84 and 6V6.
- Tube: NOS 6AD10
- Power Output: 3.5W+3.5W @ 8 ohms (Equivalent to 12W solid state power amp)
- it can also be use as Power amp with a Pre-tube amp in front. You will get an excellent result.
Selling at $285
Currently available in Black / Silver (Note: Standard Package does not come with any power cord)
APPJ HPA Headphone Amplifier Adapter
Convert your speaker tube amp to a headphone tube amp. Direct solution instead of getting another tube headphone amp.
This matching is widely used, can be used in 6F3 EL84 6V6 6P3 EL34 KT66 KT88 2A3 300B or the equivalent power of the single ended, combined into a headphone amplifier, strong drive ability good special effects, can drive HD800 and other high-end headphones.
Parameters:
Input: 4.0mm Banana Jacks
Output:High/low-impedance headphones,3.5mm and 6.35mm stereo headphones
Support:8ohms-600ohms all headsets
Processing power of 8W +8 W
Support: 6F3 EL84 6V6 6P3 EL34 KT66 KT88 2A3 300BGewith the same power single-ended tube amp
Selling at $110 (Note the amplifier is not included)
APPJ PA1502A – Mini Class A Headphone Amplifier
Class-A single-end triode,100% tube amplification.Designed for resolution of fine musical details, expansive sound stage presentation, and lush tonal quality.
Full aluminum enclosure/chassis
Tubes: 1PC 6N4 – (Changeable to 12AX7; ECC83; ECC803)
2PCS 6P6P – (Changeable to 6V6)
- Input: RCA Jacks
- Output: 6.3mm Jacks
- Output Impedance: 8 to 600 (Japan Z11-EI48*24 Output Transformers)
Selling at $315
Currently available in Black / Silver (Note: the standard package does not come with any power cord)
Timester Audio
TMS T-300MK5 – mini EL84 Vacuum Tube Amplifier
TMS mini tube amplifer has nick name call “小甜甜” – Sweet and Elegant looking & High End Quality Built , has received widely praised by enthusiasts ! Rich, Detail Sounding. Musical and natural fine sounding with tone balance and strong three-dimensional sense is its sound characteristic.
It can drive well even with 86dB sensitivity speakers.
Headphone output Anti- range, can be used as advanced headphone amplifier , very resistant to listen , and listen for a long time not tired .
Sample video : https://youtu.be/XhpXCzlHfRA
Performance parameters:
Output impedance (speaker : 4 ohm- 8ohm headphones : 32O-600O)
Output power: 6W * 2 – (equivalent to 20w Solid State amplifier). Headphone : 600mW
TI Burr Brown PCM2704 chipset which support 16bit/48kHz
Frequency Response : 10Hz-30KHz (-1dB)
Signal to noise ratio :> 89dB Distortion : <1% (1w) Power supply voltage : 220V, 50-60Hz
Power consumption : 38W
Tube Type : 6J1 x 2 (5654, 6AK5) , 6P14 x 2 (EL84/6BQ5) - Stock Tubes are available for upgrade also
Weight : 5.5kg
Volume : 238x138x148mm (LxWxH) - Surprising the Size is slightly smaller then Tp60 !! Small enough for Desktop Room space
Selling at $459
Ordering info:
Racoon
SG-100 - Multifunction amplifier with USB DAC/Headphone Amp
Strong thrust, easily drive all headphones. Provide a high level audio resolving power and give a very sweet and warm sounding that will let you enjoy this little amp alot. Trust me !!!
- NXP TFA9815T high-efficiency Class D digital power chip supporting up to 25W*2 output power.
- TE7022L USB support 24bit/96kHz, using an CS4398 DAC chip to decode.
- TPA6120A2 Headphone-AMP support impedance range from 8-1000 ohm
- Built in Power supply
Selling at $165![]()
(FREE adapter – US to EU Pin plug for Local customer)
SG-300 - PSVANE Tube Pre-AMP with USB DAC/Headphone Amp
This is a Tube Pre-amp with USB DAC + Headphone Amp. Naiting sweet sound all thanks to the high quality PSVANE tube. Thick solid low-frequency, low-frequency powerful. Naiting sweet sound all thanks to the high quality PSVANE tube. Thick solid low-frequency, low-frequency powerful. Prefect match with Miu Tech MKP-1 mini as well as to all other mini integrated amplifier of your choice
- Using CS4398 DAC, TI TPA6120A2 (headphone amp)
- USB, AUX input
- Tube output
- Tube use - Premium GOLD PSVANE 12AT7-T II (贵族之声)
- 2 headphone amp slot (6.25mm/3.5mm) and can support impedance range :8-1000 ohm
- Support 32kHz-96kHz
Selling at $195 (FREE adapter – US to EU Pin plug for Local customer)
Currently available in Black / White![]()
Sense Audio
SENSE G1 – Tube Pre-Amp/DAC/Headphone Amplifier
A very Versatile mini Tube Pre-Amp/Headphone Amp with up to Coax/Optical/USB DAC function. Using pcm5102 decoder chip and many foreign crew were using this chip. USB input part of the upgrade is asynchronous 192KHz / 32bit receiver chip CM6631A, to facilitate access to other digital devices , increase fiber and coaxial digital inputs, retained line input and output analog signals, so can also be used as a STANDALONE DAC (For Headphone only) or Pre-Amp.
- Class A Hybrid, Tube(preamp) + VMOS (power Field Effect Transistor chip)
- OPT, COAX, USB, AUX input
- AUX as Pre-Amp or DAC
- USB using CM6631A, DAC using PCM5102
- USB Support mobile OTG for Android 4.3 and above
- Tube use – Beijing’s 2P2J
- Headphone amp slot 6.35mm and can support impedance range :32-300 ohm
- Support up to 196kHz
- Support 16bit-32bit
Supports tube rolling (changeable with 1S4 /3S4 / DL92 / CV820 / 2P2 / 2N2N). Upgrade Tubes are available here
Selling at $200 (Note power cord is not included)![]()
TAKAS
TAKAS A50 (Enhance Version)
Probably one of the most versatile Class D high power amp which I have came across. It has full of function that at least is worth to take a glance on how this amplifier looks like and performance.
Follow the successful of the last Takas A50 model which run on Tripath chip, due to the run out of tripath chip, the current Takas A50 model now has upgrade to use with TDA7498E 120W high power amplifier chip. Not only it has inherit the functions of the last model, the current A50 model has further enhance and exceed what it last model has possess.
In a glance A50 has the following functions and features:
– High Power (120W) TDA7498E Class D amplifier
– 32bits up sampling features. All thanks to the high end CS8421 chip which normally can be found in high end audio products.
– Beside it has AUX in connection, It has built in DAC (Texas Instruments PCM5102A) with optical/coaxial/usb input. It however can be use
as a standalone DAC. The output DAC can support active subwoofer as well.
– USB support Android OTG and Iphone/Ipad as well
– It has built HIFI headphones amplifier module with LM4881
– A50 (Enhanced) allow rolling of Opamp to give different taste of sound. This can be easily replacing the Opamp IC onto the gold-plated IC
op-amp socket. Currently the ops amp installed is LM4562NA
Selling at $200![]()
MiriDIY
Miridiy Class A Hybrid Headphone/Pre-Amplifier
ou can have a powerful, dynamic and sweet TUBE SOUND from your headphone ! You’ll be astounded at the improvement in sound quality, dynamic range, meticulous transparency, completely demonstrate its high performance and analytical ability, it can also connect with power amplifier such as a high performance pre amplifier to improve your Hi Fi system.
Prefect match with Miu Tech MKP-1 mini as well as to all other mini integrated amplifier of your choice. Pre-amp helps to give extra gain to the power of your amplifier should you think their power is not enough
Pure Class A Headphone Amplifier & Pre Amplifier
Hybrid ! Valve & MOS-FET in Use!!
Without any OP amp IC inside!!!
Audiophile Performance Design Absolutely!!!
G3, it has improve from last version which was OEM to Indeed-Hi Fi (G2 Valve Class A Hybrid Headphone/Pre-Amplifier). And alot of copy and similar product following them, so they are also keep a distance with our technical skill.We have modified to generation III now, so that we call it G3.
Easy to change the tubes with jumper on PCB (bias adjust is necessary), 6 series for 6DJ8/6922/ECC88/6N11/6N23P; 12 series for ECC82/12AU7/12AT7/6N4……
Selling at $150 (with standard EH6922 Tube, $165 (with Gold EH6922 tube)
MiriDIY B5 Tube Buffer
Transform your CD player to be a Tube CD player! Transform your DAC to be a tube DAC! Give the extra warmness to the sounding. Affordable Tube buffer and Fun to play!
Connection : CD / DAC / other audio source -> B5 Buffer – > Amplifier
B5 tube buffer / gall preamp gain is approximately equal to 0dB.
It has very low distortion , so that your system has a very clean sound and better dynamic range
Can effectively filter out the remaining digital audio signal and give comfortable smooth sweet and mellow warm sounding
a) Changeable with series for 6DJ8/6922/ECC88/6N11/6N23P (plug and play);
b) 12 series for ECC82/12AU7/12AT7/6N4 (with changing of jumper and need professional equipment to adjust the voltage if change to 12 series)
Selling at $145 (with standard EH6922 Tube, $160 (with Gold EH6922 tube)![]()
Ordering info:
AIBBC TA-100 - Tubes Sabre 9018 DAC/Pre-amp/headphone amp/Bluetooth 4.0 (new arrival)
TA-100 is a very complete ES9018S advanced decoder with XMOS (U8) + Headphone Amp + Bluetooth 4.0 (CSR BC8670) + Preamp Output. Having the highest level of decoding with built-in XMOS USB (U8) to support DSD hardware solution, using high end grade ops amp on amplifying circuit, the latest Bluetooth 4.0 CSR BC8670 programs to support lossless transmission APTX (I2S input receiving a digital signal decoding after ESS9018 preamp output) and a unique patented technology on tube hybrid system with full discrete between the core elements and the pre-amplifier circuit output.
TA-100 (Standard version) is using IPF MUSES8820 + IV MUSE8920 ops amp and pairing with Psvane 12AT7
TA-100 (Premium version) is using IPF MUSES8820 + IV MUSE8920 ops amp and pairing with Psvane (贵族之声T系列典藏版) 12AT7-TII gold tubes
Function:
- DAC chip ES9018S, having 32BIT HyperstreamTM DAC patent structure, and the time domain jitter removal, as well as having a 135dB
dynamic range and distortion of -120dB, the industry's highest level of performance for today. TA-100 has fully utilize the function of this chip,
to satisfy the most demanding audiophiles.
- COAXIAL input straight into ES9018S decoding, support for external high quality digital audio.
- USB digital interface XMOS (U8) with the industry's highest level of 32BIT / 384KHZ ES9018S DAC decoder IC design, support DSD
hardware solution, XMOS U8 decode the benefits of integration and DAC built-in USB digital interface is the shortest distance to get the best
transmission sound quality.
- The machine supports Bluetooth playback, with the highest levels of CSR8670 audio-specific Bluetooth chip, CSR8670 is the industry
supports digital output of a high-quality 4.0 Bluetooth chip, the signal straight into ES9018S decoding, and support for APTX lossless
transmission, powerful, excellent sound quality.
- Input Select: CD / AUX / BT / USB / COAXIAL five audio input selections.
- Output options: Headphone output / can control volume preamp outputs (balanced and unbalanced RCA outputs).
- Fully discrete power amplifier configuration of high-fidelity headphone amplifier design, strong thrust, rear gain switch, 8-1000Ω impedance
completely adapted.
Selling at $499 (standard version), $599 (premium version )
AIBBC HF-2050 (3rd Generation) – Balanced Amplifier
AIBBC HF-2050 is a class AB amplifier and now currently is the 3rd generation with few major improvement. , using the tube taste MOSFET power tube design, four large capacitor storage for the main filter design to ensure bass dive deep, pragmatic, powerful; Overall three sound dimension, clear and transparent, solid and steady, sweet and charm. It has a Balanced connection, probably is hard to find a balanced amplifier below 500 range as balanced connection usually found in high end equipments.
Premium Edition: the input signal by new Japan Radio JRC hifi Dual OP AMP MUSES8820 offering finest sound to audio fans more widely, MUSES8820 inherit the sound signature of flagship MUSES02 , in term to pursuit high quality sound with a fraction of lower cost is most suitable for high-end audio equipment. Signal amplification driven by two BB flagship op amp OPA627AU with high resolution and excellent dynamic bass, smooth mid, vocal delicate.
- High Power: 130-160 watts X2 (4Ω), 80-90watts X2 (8Ω)
- Pre-amp circuit with power supply completely independent, adjust and optimize the parameters of the parts,
remove overheat resistor. This help the amplifier to produce low heat, better stability, better sound quality, treble
more balanced. The Pre-amp connection can connect to an active subwoofer to provide more bass to your music.
- Relay using Japan’s OMRON which is excellent quality, stability and enhance the reliability of the machine
- Volume potentiometer using Japanese RK16 ALPS double potentiometer, help to make the key components to
become more reliable.
- Balanced 1/RCA2/RCA3 three analog audio signal input.
- Balanced input upgrade to independent power supply, audio + / – input differential signal, making the audio signal
restore to be more delicate, resulting to reproduce the high resolution and analysis, the BB opa2228pa balanced
input and bottom with low noise, sound quality is more delicate, more sweet.
- Op-amp decoupling capacitor all independent regulated power supply, will decouple the affected op-amp that
affect the sound quality, Loopback capacitor upgrade using Nichicon Muse Series – the flagship KZ Series, Nichicon
KZ series high frequency capacitance which has a gorgeous and charming mid, good low which is sweet and
delicate. The op amp input decoupling of Japan ‘s Top Chemical AVF audio capacitors which is small in size and
using high quality oxygen-free copper pins. Crisp and clear high-frequency , low dive with good speed and big
sound stage , very different from the traditional Japanese capacitors sound. Op amp input decoupling using Elna
silmic2 matte version hi-fi audio capacitors, silmic2 very natural, the highest quality audio capacitors (third
harmonic distortion) SILMIC improved version. This series not only natural in characteristics, the low is thick, the
mid and high suffer from less distortion. Very ideal coupling and decoupling capacitor. The sound quality effect
maximum signal coupling transmission after repeated testing comparison, we promise to ensure the stability of the
power amplifier performance, the final choice of straight lotus root method, resulting in the widening of frequency
response, high – low more excellent, sound more transparent nature. Optimize pre-amp circuit and with tuning,
use high quality audio capacitor, resulting great improves in the sounding, circuit optimization to maximize
Selling at $375 (Premium Edition)
Bluetooth Receivers
Bollo Bar-4 (Bluetooth Lossless DAC)
After the very successful Bollo Bar-3, they have finally launch the upgrade version Bar-4 Bluetooth Lossless DAC
Product features:
– Super sound quality, Comparable with any HIFI CD player;
– Integrated wireless buletooth lossless DAC and line-in DAC in one box;
– Allows you to get rid of the shackles of cable, support any Bluetooth phone, Tablet, laptop, desktop, and so on;
– Adapted bluetooth lossless technology, audio data without compression, pure PCM data stream transmission;
– Superior user experience and let the music flows with your fingertips, arbitrary;
– BAR-4 can also be used as a HIFI DAC;
– Specially optimized for Apple’s iPhone and iPad sound quality;
– Wireless operating distance up to 10 meter.
– DAC Chip: CS4351CZZ
– Audio Decode: up to 192KHz/24bit
– Digital Receiving Chip:WM8805GEDS
– BT Chip: CSR BC05 w/Lossless firmware
– Wireless freq.: 2.4~2.48GHz
– Wireless Data Transmission Speed: 2.1Mbps
– Protocol Supported: OPP, OBEX, SPP, A2DP, AVRCP,FTP, HS/HF, DUN Profiles
Interface:
– INPUT: 1 x Bluetooth Lossless, 1 x Optical, 1 x Coaxial
– OUTPUT: 1 x RCA Stereo, 1x Optical, 1x Coaxial
Selling at $190
Base Audiophile Bluetooth Audio Receiver – APTX Independent with 9023 DAC
This is a very versatile mini Bluetooth Audio Receiver. Easily deploy in various places like can be use in Car, outdoor activities, home audio, portable carry etc.... .All thanks to this receiver is very compact in size (smaller then palm size) and can be power up by Power bank.
Not all consumer Bluetooth receiver has inbuilt DAC to achieve better sound quality. This receiver using Sabre 9023 DAC and best for all it support multiple output like optical, coaxial, RCA and even 3.5mm headphone out if you like to deploy it in different needs.
BEST VALUE FOR MONEY in the market!!!
Bluetooth audio receiver features:
1) using the top Bluetooth audio module (CSR8645), support fiber, coaxial high-fidelity digital output;
2) the use of fever-level independent DAC chip (ES9023), 112dB dynamic range, source input to ES9023 to achieve hi-fi sound quality;
3) support APT-X lossless transmission (need to play equipment support), CD-level (4411kbps) sound quality to enjoy;
4) support optical, coaxial, RCA , 3.5mm headphone output at the same time, to meet a variety of applications;
5) support USB DAC function, you can use as a USB sound card, a multi-purpose machine to enhance the computer sound quality;
6) using Bluetooth 4.0 protocol stack, faster, lower power consumption, transmission distance
7) support NFC IGRS, easy Bluetooth connectivity, easy to use;
8) built-in independent brass antenna to ensure stable and reliable wireless signal;
9) 8 memory group
Specification:
1) Input – USB, Bluetooth (auto switch)
2) USB DAC – Support USB DAC
3) Sample Rate : 44.1k (Bluetooth) 48Khz(USB) / 16bits
3) Analog Output – 3.5mm (headphone) and RCA
4) Digital Output – Optical, Coaxial
5) Lossless support – APT-X lossless support
6) Independent DAC – ESS9023. Audiophile grade sound
7) NFC support – Yes
8) Power input – 5V 0.8A
9) Dimension – 56mmX 85mm X 22mm
10) Antenna – No antenna require and receiving sign is stable
Selling at $75
One Stop Audio E-storz
Portable/Desktop Amplifier, Pre-Amp,DAC, Bluetooth/Wifi Streamer DAP, Conditioner, Headphone, Cable, Accessories etc
Promotion items: https://littlemart.wordpress.com/promotion/
Ordering info:
a) Website: http://littlemart.wordpress.com (Follow my E-Store to get latest update on Group Buy Deal)
b) Contact mobile:+6597223884 <Whatapps / SMS>
c) Email: [email protected]
d) By Normal Mail /Registered Mail /Ta Q bin / AMK Pickup in evening in Weekday (timing to be arrange)
HDMI Audio Extractor
The HDMI Audio Extractor can work in three modes:
HDMI input mode
PC-USB mode
HDMI ARC mode
(Take note there are some HDMI audio Extractor in the market but does not support 4K and also only can support HDMI input mode.)
Feature:
- Support 1x HDMI input, 1x HDMI ARC input, 1x PC-USB input, the three signal source cyclic switching through the button.
- Support 1x HDMI output, 1 x Optical output, 1 x Coaxial output, 1x L/R output, all audio output at the same time
- HDMI support version - HDMI 1.4 & HDCP 1.4 Digital audio
- HDMI resolution - [email protected],1080p/1080i/720p/576p/576i/480p/[email protected]/50/60fs
- The HDMI output to HDTV support ARC audio return to the HD652A and output digital audio through Optical/Coaxial interface.
- The HDMI input audio signal, HDMI ARC audio signal, PC-USB audio signal,all support ac3/Dolby trueHD/DTS/DTS-HD/LPCM 1/7.1multi-channel audio.
Selling @ $49/pcs
HDMI Audio Extractor (3xHDMI input)
The function the same as the above except no USB input but have 3 HDMI inputs
Selling @ $59/pcs
HDMI Audio Extractor / Decoder
The 5.1 channel digital audio decoder can decode the Dolby digital AC-3, DTS, LPCM and other digital audio format source code, through the internal quality of DAC conversion output 5.1 channel analog audio. In support of the two output mode and a variety of EQ mode, can match with different power amplifier and speakers, to get a different sound effects. Optical fiber and coaxial digital audio output end is butted with DVD players, Blue ray machine, network player, set-top box, PS2, PS3, Xbox360, PC and many other entertainment equipment use.
How it can be use:
FEATURES:
1. Two-Ports SPDIF (1 x Optical and 1 x Coaxial) digital audio input, one HDMI(4Kx2K) input, one USB2.0 interface. You can switch freely between different signal sources.
2. HDMI support version - HDMI 1.4 & HDCP 1.4 Digital audio
3.HDMI resolution - [email protected],1080p/1080i/720p/576p/576i/480p/[email protected]/50/60fs
4. Support 6 channel analog audio output of RCA and 1 AV video output, can be directly with the power amplifier, active sound box or TV docking
5. support stereo seven EQ mode output selection can play mode
6. support Dolby digital AC3, DTS, LPCM, HDCD, PCM, Dolby digital, Dolby Prologic II and other digital audio format decoding
7. support U-disk multimedia player, can play 5.1 channel music, video, pictures, TXT document and other multimedia content
8. DTS/AC3 decoding and playing in support of the 2 and 5.1 channel two output modes, stereo decoding playback support 2 and 2.1 output options, according to the number of flexible configuration of sound box
9. The key to switch input source, convenient operation, simple operation support panel key
10. Support infrared remote control operation and prolonged 3.5MM remote control, remote control operation can be prolonged, visual settings menu interface
11.The power-off memory function, after reboot automatically switch to the last used signal channel, USB broadcast memory before the power file
12.The use of DC 12V/1A external power adapter power supply, wide voltage can use DC (7-20V) power supply
Selling @ $89/pcs
HDMI Audio Extractor / Decoder (All in 1 Function)
How it can be use:
Features
– Support three HDMI input,one Coaxial input,one Optical input,one PC-USB input,one AUX input,one USB 2.0 input. You can switch different signal sources randomy by Button or Remote.
– Support one HDMI(ARC) output, one Optical output,one Coxial output,one 5.1ch analog audio output of RCA , all audio output simultaneously.
– All signal source(HDMI/ARC/COXIAL/OPTICAL/PC-USB/AUX/USB) can decode to 5.1ch output,it is audio decoder system.
– All signal source(HDMI/ARC/COXIAL/OPTICAL/PC-USB/AUX) but USB player can convert to COXIAL/OPTICAL output,it is S/PDIF Switcher system.
– HDMI resolution up to [email protected],support 3D
– Supported audio farmat :FLAC、APE、DTS、DTS-ES、AC3、WAV、HDCD、DSD、AAC、WMV、MP3、LPCM、M4A etc.
– Support 5.1ch/2.0ch output mode,FL/FR active when 2.0ch output mode.
– Support Button or IR switch input source ,turn on corresponding LED or display on LCD.
– Support IR control operation and 3.5mm IR extending cable port.
– The power-off memory function, automatically switch to the last used signal channel, USB broadcast memory before the power-off.
– Users can be upgraded when manufacturers have updated.
– The use of DC 12V/600mA external power adapter power supply, wide voltage can use DC (7-20V) power supply
Selling @ $120/pcs
Ordering info:
uup..................................................
Ordering info:
