It does look big, but i think their ok.
My only concern is
1. the extra price ( i am already way over budget. Instead of spend like MYR20 on a cheap keyboard, i'm spending MYR450 @[email protected]: I know i am a vain person, but the prices bring me back to reality. I can only go so far with my plans for perfection. )
2. is it my imagination or is the control key bigger than the Duckies ? Is it gonna fit alright o_O:
3. Since Ducky uses function key, the F9 etc have a see through gap in the key so you can see the light LED. If you replace them with this new key set, it will block out the led light :{
By the way what plastic are they using ? abs or pbt :d the thread did not mention.
