Page 6 of 8 FirstFirst ... 45678 LastLast
Results 76 to 90 of 113
  1. #76
    Quote Originally Posted by ericlin81 View Post
    Hi, Do you have and business plan price?
    Yes, you can PM me your contact/name card =). or email me at [email protected]. I will get a CSO to contact you .
  2. #77
    will be there from 1pm till closing. Apple tv will be given to first 50 customer of the day
  3. #78
    Hi,
    Can the ONT be replaced with our own kit? I have a Cisco Catalyst running the ipservices image which should be able to interface directly with OpenNet fiber if I install the right SFP (GLC-BX-U20/GLC-BX-D20)
    DF
    Durian Dragon Dranyago! See this Dragon Meow!
    Views expressed are my own and are not representative of that of VR-Zone.
    Posts made when executing moderator duties after 20150301 will be in bold purple
    Note that Friend requests will be declined without exception. Do not send me any.
  4. #79
    Quote Originally Posted by DragonFire View Post
    Hi,
    DF
    Yup. =).
  5. #80
    Promotion extends till Dec 2.. Contact me asap if u want to sign up!
  6. #81
    KencanaNET FTW!! wenasong's Avatar
    Jan 2010
    *Near Resort World Sentosa*
    7,072
    Quote Originally Posted by magickiller9 View Post
    Yup. =).
    Are you sure about this. GPON and AE is totally different, it is not compatible with each other. So, try to ask your technical team first. What we are talking here is, replacing the Zhone router as a whole. So, connecting it directly to the Catalyst using a off the shelf SFPs is possible?
    Bzzzzzzzzzzzzt Blitz.
    Cert : #1212NA195 , #1404TCE008 , #1404WE064 , #1405RE146 , #1405INE010 , #1604UME060
  7. #82
    The dumbass
    Oct 2004
    Beside VR-Zone server
    8,661
    omg .. sure a not.. can directly go to SFP? i never know can leh.. waiting for confirmation
  8. #83
    Quote Originally Posted by wenasong View Post
    Ah sorry. must have misunderstood.
    The zhone will be present. And convert the signal from open net box using the zhone, the zhone can bridge to the switch.
  9. #84
    Still need the Zhone lol.
    On the bright side, Finisar has recently demoed a SFP ONT. Not on market yet tho.
    DF
  10. #85
    Any updated promotions? Thanks.
    Motherboard - Asrock 990FX Extreme 9
    Processor - FX-8350 w/ Havik 140 [Vertical Config]
    Chassis - Fractal Design R4 Black Window
    GPU - MSI R9 290 Gaming
    Powersupply - Superflower 1000W Platinum
    HDD - -Samsung 840 Pro 256GB | Seagate 2TB
    Ram - Samsung Low Profile 1600Mhz 16GB
  11. #86
    See Wat See!! abrams1975's Avatar
    Cantoment
    3,026
    Hi VQ, I am thinking whether any promotion coming say in March 13? As I am moving to Tanjong Pagar area (Old estate) and would like to have my home wire up wih fibre. I also notice that openet box at my new home is located rite outside my flat unit corridor. Is this consider connected?
    My Rig (Aug 2015) & Device: Iphone 6S Plus 64Gb Rose Gold:
    MOBO: Gigabyte Z710X-UD5 mobo
    CPU: Intel i7 Core 6700K 4.0ghz + CM Hyper 212 HS
    Ram: Corsair Vengeance LPX DDR4 2400 C14 2x8gb Dual kit ram
    OS: Window 10 Pro X64
    GFX:Gigabyte GTX 1070 8GB DDR5 G1 Edition PCI-E (DP)
    HDD: Samsung 960 EVO 500gb M2 NVMe & Samsung 850 Pro 512gb + WD Black 1 Tb HDD
    Audio: AUNE T1 24bit/96kHz Tube Amplifier USB Decoder USB DAC(Black Version) w/ KimberKable - B Bus CU USB Cable
    Speaker: Swan M50W 2.1 Speaker system W/ X-7 Leopard – 3.5mm to 2RCA
    Optical Drive:LG 12X BD writer
    PSU: Seasonic X series 650Watt Gold Plus
    Casing: Silverstone FT02 Black Casing
    Mouse: Logitech G602 Wireless Laser mouse + Razer Goliathus Speed (Extended version)
    Keyboard: Corsair K95 Platinum RGB Keyboard
    Monitor:Philip BDM4065UC 40" 4K VA Monitor
    Network: ViewQwest Fibre Raptor + Asus RT-AC87U Gigabit Router
  12. #87
    Nope, you will need to pay for OpenNet to run the fibre cable into your home and install the wall mounted fibre termination point (small box with 2 sockets facing down, with OpenNet logo) before VQ is able to connect you.
    The installation is chargeable by OpenNet and price is just under $300 (could be more if you require a longer fibre run)
    Infinite Monkey @ ViewQwest
    Nikon FM2n ∙ Nikon D610 ∙ Nikkor 50mm f/1.2 AI-s ∙ Fujichrome Provia 400X
  13. #88
    DF
    Well, the other end of your fibre is plugged into an SFP too
  14. #89
    Cantoment
    3,026
    Thank for the advise bro. Haiz had to burn few hundred dollar to fixed the TP...Guess till then just LL liao
    Quote Originally Posted by &d00 View Post
  15. #90
    am using UNoTelly now with my VQ subscription, over 2 Apple TVs, two desktops, and two laptops. IT'S AMAZING can share so many streams over one Hulu Plus subscription at only US$8/mth! Screw you ST and SH Only reason why i still have ST is for BPL soccer.
  1. WTS: <strong>WTS:</strong> <strong>WTS:</strong> Clearing Sale - All Good Working Cond
    By techsonix in forum Other Hardware Components
    Last Post: Jul 25th, 13, 12:24 AM
  2. MWTS: <strong>MWTS: </strong> <strong>MWTS: </strong> Razer Naga Molten Special Editi
    By ly5265137 in forum Other Hardware Components
    Last Post: Aug 1st, 11, 12:05 PM
  3. [CLOSED] <strong>WTS:</strong> <strong>WTS:</strong> 3 phones iphone 3g 16gb, lg kc910,
    By trygon in forum Singapore Marketplace / Garage Sales
    Last Post: Apr 23rd, 11, 11:31 PM
  4. WTS: <strong>WTS:</strong> <strong>WTS:</strong> Lenovo X200 (warranty till 2011)
    By coffee_junkie in forum Notebooks/Netbooks Garage
    Last Post: Aug 2nd, 10, 07:29 PM
  5. Replies: 71
    Last Post: Mar 10th, 10, 06:34 PM
