Results 1 to 5 of 5
    noobie
    May 2012
    Singapore, Singapore
    27
    Need help with audio for Rampage III gene mobo
    I just changed to a new Rampage III GENE IntelĀ® X58/ICH10R mobo.
    I used the front panel I/O audio connector [HD Audio] as recommended in the mobo guide book, and installed the driver. Back panel digital audio connector was also used. But the audio still doesn't work.
    On desktop, it shows the sound icon as available and when I play music, the bar actually has movement. However no sound are produce.
    Initially I thought it was speaker's wire problem, so I tried with ear piece. Unfortunately even with ear piece, there is still no sound. Tried with both front panel and back panel socket to no avail.
    Is there anything that I've miss or require to do? Like setting jumper etc, as the guide book never state anything on it.
    Let me know if there are any possible place where I might have gone wrong and any extra information that you might need to derive at your solution.
    Thanks in advance - DOMO
    P.S - The system is working fine with all parts (cpu,ram,graphic etc). Only the audio is not working.
    noobie
    May 2012
    27
    BUMPS, help appreciated. T.T
    by right, using windows dafault audio driver already can give u sound. just plug into normal speaker jack at the back of mobo and play music. if cant, prob audio chip gg.
    Need a specially built PC rig that gives the most performance for a given budget? Looking for the fastest and cheapest options to repair up or upgrade ur PC rig or laptop? Look no further!
    The Repair Lab
    noobie
    May 2012
    27
    ooh, will check it up later when i go home. any more possible issue/solution?
    noobie
    May 2012
    27
    hoho... turns out isn't audio chip problem. Re-download a new driver from mobo website and it's working fine now. thanks tamjinhang
  1. HELP! Asus rampage gene iii n ocz vertex 3
    By waikong86 in forum Troubleshooting Zone/Technical Enquiries
    Last Post: May 1st, 11, 04:48 AM
  2. [CLOSED] ASUS Rampage III Gene X58 Mobo + Intel i7-950 CPU + Thermalright Venomous X Cooler
    By cr33d0 in forum Motherboards, CPUs, RAMs
    Last Post: Feb 15th, 11, 09:28 PM
  3. Resolved: i7 950 with Rampage Gene III random shut down
    By extr3mus in forum Troubleshooting Zone/Technical Enquiries
    Last Post: Dec 7th, 10, 10:20 AM
  4. anyplace selling asus rampage iii gene
    By cyrix12001 in forum Hardware Depot
    Last Post: Aug 18th, 10, 11:21 AM
  5. Motherboard: ASUS Rampage III Gene
    By bianco in forum Hardware Depot
    Last Post: May 31st, 10, 07:47 PM
