Results 1 to 6 of 6
    Aperture Science lennardseah's Avatar
    Aug 2002
    Cyberspace
    13,843
    READ FIRST! - common solutions to common problems/questions
    in my years of experience this always fixes 99% of common problems:
    1. always try installing latest drivers / bios / windows update
    Why?
    Because new drivers and bios and windows updates ALWAYS fix stuffs
    Video Cards drivers (especially for game problems):
    Nvidia cards - Drivers - Download NVIDIA Drivers
    ATI cards - Drivers & Support | GAME.AMD.COM
    2. system cannot boot/funny beeping sound/no display
    reseat video card (make sure the gold connectors below sit flush into the slot of the motherboard)
    reseat rams (the clips on both side must go in fully) - USUALLY THE MAIN REASON
    reseat cpu and heatsink
    check whether motherboard is being shorted by any metal
    3. not stable/crash/stuttering/always blue screen of death/mysterious restarts
    try 1. and 2. first.
    up voltages of ram (usually called vdimm/vram) and northbridge (yea even unoverclocked systems sometimes need that extra bump to be stable)
    if overclocked, save your settings first and then set everything back to stock and see the errors come out again - if yes means bad overclock
    reduce ram timings/divider
    to test memory/cpu stability, run intelburntest (IntelBurnTest v2.3 download from Guru3D.com) - if it lasts 5 minutes on full burn its probably ok
    4. OHOH why my cpu/video card so "hot"
    There has been a lot of misinformation around mainly due to outdated knowledge (the thresholds of older cpus/gpus last time were lower) . These are the acceptable temperatures of modern day stuff:
    Idle - anything below 60s degree celcius (i'm serious)
    load (gaming) - anything below 80 degree celcius
    load (intelburntest/furmark/every core 100%) - anything below 90 degree celcius
    anybody who tells you otherwise is still living in the AMD Althon/Geforce 2 MX era.
    "Wouldn't a hotter cpu mean die faster" - not really unless you mean you want it to last 100 years. only overclocked extreme voltages will cause electron migration (aka something really nasty) and a fast death
    5. why my internet so slow/game ping so laggy or spikey
    follow step 1
    scan your computer for maalware/spyware/adware (i find this one the most effective - Malwarebytes.org)
    have you secured your wireless network against unauthorized access/cheapskate neighbours leeching your bandwidth?
    are you running BT/p2p applications (TVU, sopcast,... also counts), if yes reduce upload speed if possible to 10kB/s.
    follow my other guide (for xp): http://forums.vr-zone.com/networking...n-xp-only.html
    you live in a congested neighbourhood. get another isp
    6. Whats the best AV to use? Do I need a software firewall?
    Antivirus - http://www.microsoft.com/Security_Essentials/ (its free, made by the same people who made your operating system, is light on resources, and havent misfired yet - I am a "ahem" heavy user)
    Software Firewall (zone alarm and all that) - not quite neccessary if you are behind NAT/internet gateway (for nubs: your computer not plugged directly to the modem). usually it is a resource hog and more often than not cripples legitimate applications
    Aug 2002
    Cyberspace
    13,843
    post here if you read my FAQ and it solved your problem!
    Feb 2009
    West
    4,843
    Bro you forgot something.
    - Check whether the RAM is mounted Correctly.
    Some people (especially me) sometimes blur blur , too eager to start the computer then anyhow put the RAM but didnt realise that its the wrong side :p. Happens many time
    If wrong side, it shouldn't even be able to fit.
    If it does, means you forcefully push the rams in, damaging both the motherboard and the socket. (unless you using SODIMMs)
    CPU: Intel i7 2600k cooled by ID Cooling Frostflow 240L
    Mainboard: Asus Maximus IV Gene-Z
    RAM: G.Skill Ripjaws X DDR3 1600mhz CL9 4x4GB
    GFX: Palit GTX 1070 Super Jetstream
    PSU: FSP Aurum Platinum 80+ 550W Semi Modular
    HDD: Internal Zotac 120GB SATA3 SSD , 2TB Samsung F4 Spinpoint , 1TB Seagate Barracuda 7200.10, Toshiba 2TB 7200RPM, 1TB 3.5" WD elements (convert internal), 320GB 2.5" WD elements (convert internal)
    Chassis: NZXT S340 Elite BLack/Red
    Speakers: Swans M50W
    Keyboard: Royal Kludge Electrostatic capacitive keyboard TKL; Topre Typeheaven
    Mouse+Peripherals: Logitech G102; Razer Naga
    Monitor: Dell U2312HM + Benq Zowie XL2411Z
    can AV and Malwarebytes run together in a system?
    AM3 Athlon2 x3
    MSI 880GMA-E45
    2GB Kingston DDR3
    XFX HD 5670 512MB
    Seagate 500GB
    Samsung SATA 22xDVDRW
    Andyson Silent 480W
    CM 341
    Newbie of Past & Present yantronic's Avatar
    Nov 2004
    Paid Accomodation
    22,892
    Memory "Lost" on Intel CPUs With Integrated Memory Controllers (IMC) residing on LGA1156/LGA1366
    You will have to re-seat the RAMs, and in some cases, the CPU as well. Clean the contacts on the CPU and reinstall it.
    The opinions expressed above do not represent those of VR-Zone (VR Media PTE LTD Singapore) or any of their affiliates.
  1. WTS: many many things>>come see
    By 11qwerty in forum Singapore Marketplace / Garage Sales
    Last Post: Aug 22nd, 09, 07:02 PM
  2. [CLOSED] Things!!
    By MarcusG in forum Singapore Marketplace / Garage Sales
    Last Post: Jul 27th, 09, 10:50 PM
  3. Things you did not know about AK-47
    By ultimaboy in forum Chit Chatting
    Last Post: Feb 17th, 09, 05:25 PM
  4. 50 things that everyone should know, or....
    By limyc in forum Chit Chatting
    Last Post: Sep 4th, 07, 10:54 PM
