Results 1 to 15 of 18
    Anyone knows what speaker cable plugs Swan M200MKIII is using?
    I'm planning to upgrade my speaker cable (the one that connects my left speaker to my right speaker), but I'm not too sure what plug/connector is suitable for the speaker. Anyone knows?
    I've attached the photo of the stock cable for your reference. Thanks
    Back of the speaker
    does your speakers come with RCA inputs?
    You can run 1 RCA Red to right and 1 RCA Silver to white, no need to get interconnect
    Audio & DIY PC Enthusiast
    If I'm not wrong, it doesn't sound like both the speakers have amps, that's why there's such a cable.. in this case, he can't use direct RCA inputs.
    The cable doesn't look like any standard I'm aware of. Should not be difficult to custom though.
    Questor is right, only one side has amp that's why the side that has amp is heavier.
    Is it possible that it is a female to female 4 pin mic cable?
    Possible that it's a 4 pin mic connector, but depends how they wired the cable.
    Shouldn't take it for granted that the pins are directly corresponding to each other at both ends. Maybe you should write in to ask.
    *Meow.* nst's Avatar
    Jun 2005
    Simei
    1,429
    dropped you a pm
    *~*Hell on my left, Paradise on my right, and the Angel of Death behind*~*
    For value for money audio products, please visit Aural Indulgence.
    | Intel I7 920 | MSI X58 Eclipse | 3 x 2GB Geil DDR 3 | Leadtek GTX275 | Auzentech Prelude w/ Klipsch GMX A 2.1 | BenQ 1640 | Gigabyte CD-RW | 2 x 500GB WD Caviar Black | CM690 w/ Corsair HX620 |
    By the way I'm buying an upgrade cable online that's why I need to know what connector M200MKIII is using
    Quote Originally Posted by Questor View Post
    You mean write to tech dynamics?
    Thanks to nst, I got the answer already. Its a 4-Pin female microphone plug used for ham or CB radios. Some people know it as a "CB plug". (Fyi to other M200MKIII owners)
    Quote Originally Posted by capri87 View Post
    Write in to Swan.
    Jun 2005
    Simei
    1,429
    its direct. unless they've changed it since the last time i worked on them
    I hope you're not paying more than 50 bucks for the cable
    Registered User terence52's Avatar
    Mar 2009
    Bedok
    14,010
    I am quite keen to see what kind of improvements it might have tbh.
    The stock cables seems to be pretty decent to me.
    - What goes around comes around -
    So Capri...did the cable upgrade work??
    Live To Eat t258jgn's Avatar
    Mar 2009
    BPP
    70,258
    how long is the original cable?
  1. Is Rega DAC good for my Swan M200MKIII PC Speaker?
    By capri87 in forum Audiophile's & HTPC Corner
    Last Post: Feb 1st, 14, 01:38 AM
  2. [CLOSED] A good DAC for my Swan M200MKIII PC speakers
    By capri87 in forum Home Theater & Audio Equipment
    Last Post: Jan 22nd, 14, 05:18 PM
  3. I think i'm sold. Where to buy Swan M200MKIII?
    By Kai2810 in forum Audiophile's & HTPC Corner
    Last Post: Dec 18th, 13, 10:50 PM
  4. WTS : Swan m200mkIII
    By benste in forum Home Theater & Audio Equipment
    Last Post: Jan 6th, 13, 12:23 PM
  5. New: Belden Speaker Cable/Wire, Banana Plugs
    By lvsfqcam in forum Miscellaneous Garage Sales
    Last Post: Aug 24th, 09, 08:28 PM
