Results 1 to 15 of 22
    spookz
    Project : Black Box
    Hey guys!
    This is the first case i'm going to be modding! The case i'm going to be modding is a Cooler Master Centurion 5.
    As Cooler Master have taken every respect to design a very simple, yet sexy case! It had one con which everyone has noted.. the 80mm fan on the front panel.. As the Centurion 5 was the first of the "Centurion" Series of Cooler Master Cases, Cooler Master was aware that the 80mm fan was not providing enough airflow, as well as adding the noise factor. So every Centurion afterwards (530,531,532,533,534) all had a slightly different chassis allowing a 120mm fan to be added to the front panel.
    I plan to redesign the Centurion 5, through mixing a Centurion 5 and a 534. As i love the design of the Centurion 5, yet would love to give it better airflow and countering it's 'cons'. Ladies and Gentlemen, I present to you the birth of..
    Project : Black Box
    So let's begin with some pics! =P
    ..:: Updates ::..
    The Beginning : Some pics of C5 & 534, and some minor modding.
    Update 1 : Completed cutting out holes for cable management.
    Update 2 : Parts Arrived, Modded Nexus Fans.
    Update 3 : Sprayed case with Cold Galvit n Etch Primer.
    spookz
    As you may all know the C5 and 534 are extremely similar, only difference are the mesh'd areas are reversed.
    Left - C5 , Right - 534
    I thought they were both exactly the same until..
    you see a problem?
    Here.. take a closer look..
    Uh-oh! The front I/O panel was a few millimetres higher in the 534.. so the front panel didn't fit on properly..
    So I did some modding today.. drilled a few holes and tada.. fits on like it came straight out of the factory! =D
    Well that's all for today! There's heaps more modding to come.. this is just the beginning! =P
    - Spookz
    nice; keep it up.
    Intel E6600 @ 2.5ghz |ABIT AW9D MAX |4GB Kingston DDR2 (800mhz) |Leadtech 7900GTX (512mb) | 2x DVD-RW, 1x CD-R |2x 320GB Seagate Barracuda's , 2x 160GB Maxtor DiamondMax 11 |FSP Epsilon 700w | 2x Dell 19" Ultrasharp | CoolerMaster COSMOS 1000 |Microsoft Vista Ultimate, Microsoft XP Pro|
    Intel Pentium D 830 @ 3.2ghz | ASUS P5LD2-Deluxe | 2GB Kingston DDR2 (800mhz) | EVGA GeForce 8600 GT (256MB) | 1x DVD-RW |4x 250GB Seagate Barracuda's| FSP Epsilon 600w |1x Dell 19" Ultrasharp |CoolerMaster Stacker 810 (Silver) |Microsoft Server 2003, Fedora Core 8,Red Hat Enterprise Linux 4.5|
    Registered User jason6142004's Avatar
    May 2006
    Choa Chu Kang, Singapore
    2,677
    very clean mod...
    lol is it possible to just get a 80mm to 120mm fan adaptor? or are adaptors onli downwards(ie from 120 to 80)?
    spookz
    you mean something like this?
    http://www.pccasegear.com.au/prod561.htm
    You can use fan adapters like that, but it wouldnt fit in a Centurion 5 due to the harddrive cage being in the way! That's why im doing such mod =P
    yea sth lyk dat.. hmmm no smaller ones? (unsure myself).. btw that is the nexus real silent 120mm fan right??
    spookz
    Quote Originally Posted by PizzaBoy
    Yep sure is! =P
    spookz
    Finally had time to do more~
    Started drilling holes for cable management~
    Testing rubbing lining around bends~
    And tada! completed cutting all the holes~ need to line them all with Rubber lining later~
    Front:
    Rear:
    All cuttings done with my new toy~ a Dremel 300 Series~ =)
    More to come tomorrow!!~ =D
    ur holes on ur casing looks interesting..i wonder wat r u going to do with so many holes drilled on ur case.
    more pictures!! xD
    AMD Althon II 620 | Asus M4A785TF-M EVO | Team Elite 2X2GB | Radeon HD 5750 | Hitachi Deskstar 160GB SATA II | Asus Xonar Essence STX with Aego M | Samsung SH-S203B | Dell E228WFP | Andyson F500 | Centurion Master 360 | Windows XP Pro - SP3 |
    cable management prolly
    Hello.
    spookz
    Look at what arrived in my mailbox today~ =P
    I modded the Nexus fans - removed the molex connectors.
    Modded my SilverStone ST60F with a Nexus fan~ re-wired the black n red wires, n shortened the cable length~ =D
    From the inside..
    And the full ST60F put back together~
    Also primed my case.. will those pics up soon.. =P
    enjoy!
    XProfessionalX ...
    Jun 2006
    Asia
    13,952
    You are modding the CM5 or CM 534 ?
    nice work keep it up
    spookz
    @ XProfessionalX - Haha kinda modding half half.. Gonna have a CM5 with a CM534 Chassis.. 'Cause that's what i believe CM should do with their CM5's. They should think about revising it` ahahha =)
    @ S8NIST - Thanks! =P
    @ evolution_7 - Yep all the holes gnna be used for cablemanagement~ to run cables from behind mobo. I've drilled some that are extras so it can cater for future mobo upgrades, as diff mobos have diff port placements~ so i don't have to drill more holes.. =P
