Page 2 of 5 FirstFirst 1234 ... LastLast
Results 16 to 30 of 74
    places that sell alum sheet should be able to. what sort of precision (tolerance do you need)?
    Slacker... Eslayer1990's Avatar
    Jan 2007
    North
    112
    if i want to make a all arcylic casing then i should go to "Yeo Soon Hin signcraft" iszzit?
    XProfessionalX ...
    Jun 2006
    Asia
    13,952
    Quote Originally Posted by Eslayer1990
    But with measurements ..
    NOOB drozaxx's Avatar
    Woodlands
    1,300
    where can i find acrylic spray? which sip in into plastic. not sit on top of the plastic only.
    ~ You laughed at me cos im different, I laughed at you cos youre all the same!
    Proud Father Kiern's Avatar
    Oct 2006
    Khatib
    2,330
    Quote Originally Posted by drozaxx
    u're gonna find me weird... but if i remember correctly... tamiya spray cans does that job...
    My Trusty Rig...
    FX60 + Thermaltake Ruby Orb | Sapphire Pure Innovation | Sapphire X1950XT | Hiper Type-R 580W Red| WD Raptor 74gb 16mb | Seagate 500gb | Maxtor 120gb*2 | ESI [email protected]
    http://img515.imageshack.us/my.php?i...sc03304qk2.jpg
    Soldam XR-1 WPM | Samsung 931BF | Xion MultiCard + Thermal Panel | Razer ProClick Set |Logitech Pearl White Keyboard | JBL Creature II
    http://img101.imageshack.us/my.php?i...sc03293sh7.jpg
    My Son/Wife's Rig...
    E6750 + Zalman Fatal1ty | Abit Fatal1ty F-I90HD | OCZ Fatal1ty 2*2gb kit 800mhz | WD 320gb 16mb | Asus EAX1600PRO | LG Dvd Writer 20x Sata
    Soldam FC300 WPM | Logitech Pearl Light Keyboard | Logitech Optical Mouse White | Icemat
    Jan 2007
    4,914
    hey guys the sin bun trading is at which block ah?
    I wanna win one of this
    http://img.vrforums.com/asusrog_sig_banner.jpg
    its not in one of the kelantan lane blocks but out on jalan besar, unit 123. they have another shop further down jalan besar (sorry, can't remember the unit #)
    Jan 2007
    4,914
    huh so they have 2 shops?
    can roughly tell me where is it? like opposite kelantan lane all the HDB blocks? the unit 123 is ???
    its at one end of kelantan lane where the mirror and framing shop is, near a 7-eleven store.
    Jan 2007
    4,914
    ok thanks.. will go down soon.
    Wire mesh
    Guys... anyone of you know the price for 1 foot of stainless steel wire mesh??. Tks & rgds.
    P4 2.4ghz Gigabyte PE667 Ultra2 Kingston 512mb x 2 Inno3d TI4200 Maxtor Diamond Plus 80gb Onboard 5.1 Sound System Philip CRT 107X4
    Jan 2007
    4,914
    Sin Bun Trading/Hardware
    wah i have a hard time finding it, thought it was closed when i saw it. but there are actually 2 shops of the same name? one is beside the 7-11 at kelantan lane.. the other is opp slt.. i bought lots of sand paper .. average is about 50 cents each.
    where to buy sleeves? black color de
    Aug 2007
    woodlands
    112
    Quote Originally Posted by xKeL
    anywhere to get aluminium cut?
    Blk 1 Yishun St 23 #06-36 YS ONE, u can get loose material and all sort of cutting services, bending and welding etc
    Alot of things can get or can be done at this YS ONE. It is a HDB ramp -up factory providing all sort of trade.
    u can get plywood, steel sheet, glass sheet, holesaw, fasterner, paint,hardware etc
    just take bus 811, next to service 854 berth at Yishun interchange to get there. alight right infront of the building. Its near to Yishun ITE
    another place is Techlink next to Seagate at AMK Industrial pk 2. It is also a HDB ramp-up factory providing same type of trade
    Aug 2007
    woodlands
    112
    Quote Originally Posted by liquidthots
    Hey guys... sorry but where do u find H linings?
    Try Garlin or Huat rubber at Blk 101 Towner road
