Page 3 of 5 FirstFirst 12345 LastLast
Results 31 to 45 of 74
  1. #31
    Aug 2007
    woodlands
    112
    Quote Originally Posted by sudeen
    Guys... anyone of you know the price for 1 foot of stainless steel wire mesh??. Tks & rgds.
    price depend on type and gauge and foreign exchange rate and it come in width of 1m, the smaller pitch is 12mm x 12mm. How u fasten it?
    u should go for perforated sheet - 1mm thk sheet with 3mm to 10mm dia hole but edges very sharp like knife, remember to debur and sand it.
    Hardware shop normally sell in 4ft x 8ft , 5ft x 10ft
    small piece can get at BLK 1 Yishun #06-36 where they have the shearing machine to cut, drill hole or blow hole to diameter 150mm and can buy screw or paint over the shop there.
    As for fastener like screw, best go to Tat Eng industries at Shun Li Building.
    visit their www.tateng.com.sg
  2. #32
    Nov 2006
    Serangoon
    72
    Metal sheet cutting hole stamping!!
    Precision sheering machine cutting metal or stainless steel sheets and stamping Sheets!! hole etc or diff sizes or shape!! can pm Mi
  3. #33
    SELLING: CCFL,Sound Controller,UV Fan,Rubber Fan screw,UV Sleeve,UV Molex,UV Cable tie & more..
    FOR MORE PRODUCTS & ORDER DETAIL
  4. #34
    Hi,
    i would like to know what is the shop name at Seagate at AMK Industrial pk 2.
    Quote Originally Posted by gladyslim2 View Post
    Blk 1 Yishun St 23 #06-36 YS ONE, u can get loose material and all sort of cutting services, bending and welding etc
    Alot of things can get or can be done at this YS ONE. It is a HDB ramp -up factory providing all sort of trade.
    u can get plywood, steel sheet, glass sheet, holesaw, fasterner, paint,hardware etc
    just take bus 811, next to service 854 berth at Yishun interchange to get there. alight right infront of the building. Its near to Yishun ITE
    another place is Techlink next to Seagate at AMK Industrial pk 2. It is also a HDB ramp-up factory providing same type of trade
  5. #35
    Aug 2007
    woodlands
    112
    Quote Originally Posted by slug88 View Post
    Hi,
    Just to share that cutting services can be found at AMK pk 2.
    Look around for metalwork shop to enquire
    I learnt a lesson not to provide any contacts as some people will not appreciate your information and repost the same question with no xxx co. which I refer.
    No reply when I ask what happen. To me, some are my vendors/contractors. I posted their services without informing them, unfavourable remarks do affect so if I know if it is their poor service, I'll try to get them to improve.
  6. #36
    Exactly where can i find c- lining ? pls anyone?
    Q6600, DFI X38, PC 3870PCS, GSKiLL-4GBPQ, TR Ultra120Extreme, Hitachi 2x500GB, Hanns.G 22"
    Singapore is Number 1 !!!
    Watchout! Evolution Gaming @ SLS beat up customer
    Watchout! A SOB aka Reiben in the forum handphone 81094961 ... Beware!!!
  7. #37
    Quote Originally Posted by AllanDelon View Post
    Try This:
    Garlin Pte Ltd
    101 Towner Rd #01-220/1 S(322101)
    Tel: 62961877
    www.garlin-rubber.com
    [email protected]~ Rig
    Intel Core 2 Duo E6420 w/ Scythe Ninja Rev.B | MSI P35 Platinium | 4 x Kingston 5300 DDR2 1GB | MSI GeForce 8600 GTS OC ed | Samsung SM 931BW + Sony SDM-N50 | Seagate Barracuda SATAII 320GB(16MB), 2 x 500GB(32MB), Freeagent Pro 500GB, WD 1TB My Book Essential | LG GSA-4167B & Pioneer DVD-Rom (Slot-in) | Auzentech Prelude 7.1 w/ Cambridge Soundworks DTT2200 | Logitech Cordless Desktop MX3200 | CM eXtreme Power 650W | CM Centurion 5 | NZXT Sentry LX + 120mm ACRyan BlackFire4 Kameleon, 120mm Scythe, 80mm UVnium fan, OCZ Mem Cooler
    Road warrior: Mac Book Air 11"| Xperia Z | HTC One X Other: Project Wooden HTPC | (MWTS) PIV 1.7gHz on MSI 850 Pro 2
  8. #38
    Rules of eQ.™ heartykid's Avatar
    Jan 2008
    yew tee!! / SP
    2,232
    o.. where to find reinforced cutting disks?!! cut till no more disk no cut.. haha
  9. #39
    Its &a mp; a mp; amp; amp; a mp; a mp; amp; amp; amp; amp; quot ;Zed &a mp; a mp; amp; amp; a mp; a mp; amp; a mp ;amp;amp ;quot ; not &a mp; a mp; amp; amp; a mp; a mp; amp; amp bczd's Avatar
    Aug 2006
    628
    Quote Originally Posted by heartykid View Post
    For your dremel?
    Most home-fix sells dremel accessories like disks and such.
  10. #40
    Jan 2008
    yew tee!! / SP
    2,232
    bo leh.. they sell lyk bosch powerdrill type.. the hole damn big 1.. cannot fit dermel.. even if they sell dremel stuff is also a whole kit.. den inside onli 1 reinforced cutting disk. 50 bucks
  11. #41
    Aug 2006
    628
    No no, confirm got 1, at least for all the Home-fixes i've been to. =x
    Next time call up before you go, ask if they sell dremel accessories.
    I know Tanglin mall/marina Sq confirm have.
  12. #42
    Jan 2008
    yew tee!! / SP
    2,232
    Quote Originally Posted by bczd View Post
    haha ok.. i went to cck lot 1.. the home fix buanged.. lol he say smallest is
    he bosch 1.. i nearly died.. nvm i shall go down to marina sq someday to check out the homefix there.
  13. #43
    try home fix northpoint basement, beside cold storage. they should have it...
  14. #44
    Jan 2008
    yew tee!! / SP
    2,232
    Quote Originally Posted by zechraffie View Post
    haha ok.. tnx bro.
  15. #45
    Guys am new here.. hehe anyone knew where can i buy a rubberized electrical tape? Or is it quite expensive? just want to use it to completely stealth the sleeving of my PSU..hopefully near toa payoh, amk or sls..
