Page 1 of 5 123 ... LastLast
Results 1 to 15 of 74
    Modding Supplies Directory
    Ok, here're my contributions to modding. Feel free to add to it for everyone's benefit:
    Case Modding Supplies Directory
    • Wire Mesh :
      • Lai Xin Feng & Sons Hardware Pte Ltd (112,Jalan Besar/62941140)
    • Spray Paint
      • Sin Bun Trading/Hardware (123, Jalan Besar /62962729)
    – RJ London Spray Paint
    • Sand Paper
    - up to 2000 grit wet and dry sand paper
    • Bolts, Nuts and Screws
      • Poey Huat Hardware (Blk 31, Kelantan Lane, #01-20/62948898)
    - socket screw heaven
    • Acrylic/Plexiglass
      • Yeo Soon Hin signcraft (Blk 633, Veerasamy Road/62949771)
    • Aluminum Sheets/Angle Bars
      • United Hardware (Blk 28, Kelantan Lane)
      • Thung On Industries (Blk2, Toa Payoh Ind'l Park, #01-1395/Tel: 62511285 (they list computer casing as one of their business activity!)
    Projects Underway Nashaz's Avatar
    10,239
    good job... if anyone got other places to get stuff pls add... btw, dun forget Enegizers shop... great place for wc-ed stuff, fans, foam ect...
    Thanks here's what i like about each place:
    @ Lai XIn Feng, you can find most types of commonly used wire mesh - certainly more than enough for your case modding needs, such as steel, galvanized, aluminum, welded, woven mesh. mininum purchase is a foot but you may ask them for loose pieces if they're lying around.
    @ Sin Bun Trading, they have a very good selection of RJ London spray paint (chrome, gold, flourescent). what's most attarctive is they have the hard-to-find wet and dry sandpapers of 1500, 2000 grit. You can also find Bondo and spray on primer and aluminum polish there.
    @ Poey Huat Hardare, you gotta know what you're looking for as they're usually quite busy and they have a HUGE STOCK OF NUTS, BOLTS AND SCREWS for industrial purposes. they're socket screw collection is unparalleled and reasonably priced too. price estimate 1.5cm M4 socket screw is about 35 cents/pc
    @ Yeo Soon Hin signcraft, Li Jun, the proprietress, can be quite helpful. but mind you, they're not technical or design-oriented. so if you go and ask them to make you a Plexi case, you better have detailed drawings. They're selection of Acrylic is good, with many colours and thickness. Price estimate - 6 ft x 8ft x 2 mm is $52.
    @ United Hardware, its a mom & pop store and have no advance cutting machines so don't go expecting too much on precision. But their price is reasonable, i'll provide another contact in Tuas next week if you need precision cut aluminum pieces for case building.
    All these shops are near SLS, kelantan lane area.
    @ Thung On Industries - with CNC and milling machines, so they certainly can do better if its precision and refinement you want. Interestingly, they list computer cases as one of the products they do.
    XProfessionalX ...
    Jun 2006
    Asia
    13,952
    Any other mod stuffs shop needed in this list ? WC can ? Eg Barbs and tubes ?
    yep, why not? so long as its casemoddng materials related...
    Hey guys... sorry but where do u find H linings?
    XProfessionalX ...
    Jun 2006
    Asia
    13,952
    Quote Originally Posted by liquidthots
    What is H Lining ? I only know where to get C Lining
    HardCore case Pimper
    Aug 2006
    Pasir Ris/ KL
    428
    h lining is the basically like 2 c linings stuck back to back ....
    u can use it to mount windows one side on the case the other side u slot the window in ....
    it leaves a nice clean finish plus u dont need to use double sided tape or screws
    ya thats wat it is...but dun koe whereto find leh.....
    Proud Father Kiern's Avatar
    Oct 2006
    Khatib
    2,330
    any place to find those uv marker pens?
    My Trusty Rig...
    FX60 + Thermaltake Ruby Orb | Sapphire Pure Innovation | Sapphire X1950XT | Hiper Type-R 580W Red| WD Raptor 74gb 16mb | Seagate 500gb | Maxtor 120gb*2 | ESI [email protected]
    http://img515.imageshack.us/my.php?i...sc03304qk2.jpg
    Soldam XR-1 WPM | Samsung 931BF | Xion MultiCard + Thermal Panel | Razer ProClick Set |Logitech Pearl White Keyboard | JBL Creature II
    http://img101.imageshack.us/my.php?i...sc03293sh7.jpg
    My Son/Wife's Rig...
    E6750 + Zalman Fatal1ty | Abit Fatal1ty F-I90HD | OCZ Fatal1ty 2*2gb kit 800mhz | WD 320gb 16mb | Asus EAX1600PRO | LG Dvd Writer 20x Sata
    Soldam FC300 WPM | Logitech Pearl Light Keyboard | Logitech Optical Mouse White | Icemat
    XProfessionalX ...
    Jun 2006
    Asia
    13,952
    Quote Originally Posted by Kiern
    Highlighter ?
    Oct 2006
    Khatib
    2,330
    highlighter uv reactive meh?
    My Trusty Rig...
    XProfessionalX ...
    Jun 2006
    Asia
    13,952
    Yes leh .. but not lasting
    Oct 2006
    Khatib
    2,330
    oic, thanks, didn't know about that
    My Trusty Rig...
    xKeL
    anywhere to get aluminium cut?
