Page 2 of 2 FirstFirst 12
Results 16 to 26 of 26
    Register User spyboy48's Avatar
    Dec 2005
    Pasir Ris
    14,748
    nice work there, real Cool!
    Blacklist: Biff73
    Often criticism is experienced as a narcissistic injury(Narcissistic personality disorder), low self esteem, cannot except but take offence.
    ~~~ A good name is rather to be chosen than great riches!!! ~~~
    i7 980X OC with Ex58 UD3R thread.
    http://forums.vr-zone.com/overclocke...processor.html
    My MystiQue CM case : http://forums.vr-zone.com/showthread.php?t=262828
    System Specs 1 & 2: (SNiper3/3770K/G.Skill 4GBx4 2400MHzCL9/AmD6870/SevenTeam1400W/Open Rig (M5G/3770K/Samsung4Gbx4 2400MHz/470GTX/320Gb/Acebel 550w/Samsung2333sw)
    My New world record:
    http://www.futuremark.com/pressreleases/60363
    My Past & present Toys : Intel 630/830/940/4300/E6300/E6600/Using2140/6750/8400/E3110/E2160/E7200/E8400 Q816A275/E8400Eo Q827A429/E8500Eo Q820A713/E8500Eo Q822a720/Q6600Go/i920Co/i920Do3848/i980x 3003A957/i750/3960X/3930K/3770K x 3/3570K
    Quote Originally Posted by akerue View Post
    Nice work and mods...
    This just give me some ideas for my next build(hopefully)
    Me too! But its a quick and lazy version, waiting for some parts to come in atm.
    Jul 2011
    singapore
    239
    thanks..
    all e the best for your build..
    Quote Originally Posted by elbryan03 View Post
    Didn't want to start another thread as its nothing much but here's my quick and lazy version of an external waterbox to cool my spare pc. Thanks to inspiration from highslide
    mATX Case: used Xigmatek Gigas
    PSU: spare unused 500w Antec psu for testing waterloops
    Pump/Res Combo: XSPC D5 dual bay Pump/Res
    Radiators: 1 spare XSPC EX 240mm and 1 new Alphacool 240mm Monsta
    Fans: 2 spare Silverstone AP121 and 2 new Corsair SP120 PE fans
    Fittings: Spare XSPC and Bitspower barb/compression fittings and 2 set of Koolance QDCs
    1 8 way 3pins PCB for the fans
    The Xigmatek Gigas suits my purpose perfectly, 1 dual bay slot for the pump/res and space for 2 240mm rads (can even fit 2 monsta rads in push or pull if you want to), if I decide to use the power from my spare pc, I can give up the antec psu and mount another 240mm rad too.
    Note: There's only screw holes for 1 240mm rad so I had to do some drilling to mount the other 1 or 2 rad.
    Pictures:
    Unfortunately I can't close the top of the case unless I do some more further mods as the top of the alphacool rad is protruding out
    The in/out tubes connected to my Corsair 550D through the Koolance QDCs.
    Club VR Member simways's Avatar
    Dec 2009
    Yishun Chong Pang
    4,276
    this technology is called "outsourcing"
    Jul 2011
    singapore
    239
    elbryan03, you could get a piece of acrylic cut for the top.
    any colour or c-tru if u want lighting. ez to do..
    nice simple solution to add on extra cooling u have there
    Quote Originally Posted by highslide View Post
    Thats a good suggestion. Thanks!
    Jul 2011
    singapore
    239
    New update Coolbox ver 1.21
    Touch screen fan controller added to adjust fan speed/noise
    dual 655 for extra head press & to run both at lower speed.
    Jul 2011
    singapore
    239
    reroute tubing & wiring exit
    pass tru front tube for maybe flow indicator..
    Jul 2011
    singapore
    239
    & thats it...
    maybe gona sell it now.
    new ideas time...
    thanks for checking tis out..
    Damn cool
  1. WTS: Corsair External water cooling system (Nautilus 500)
    By Nexus in forum Other Hardware Components
    Last Post: Jul 22nd, 12, 05:50 PM
  2. Project [E] - Water cooling a HAF X
    By mav2000 in forum Case Modding & Project Logs
    Last Post: Nov 19th, 10, 07:28 AM
  3. Water Cooling Project
    By Static-X in forum Case Modding & Project Logs
    Last Post: Dec 29th, 06, 09:50 PM
  4. Water Cooling External?
    By Cytoplasm in forum Hardware Depot
    Last Post: Oct 30th, 06, 09:35 PM
  5. Prince's Water Cooling Project
    By JustRaied in forum Case Modding & Project Logs
    Last Post: Jan 16th, 06, 11:45 PM
