Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 55
  1. #31
    Quote Originally Posted by hell007 View Post
    It been a very long time since I update, Thank to R104 make me very busy with ROS....
    Some change was make for mine system, new hardware was added.
    1st of all MB change
    Together with new chip to match the MB
    After think decide to go for 690 SLI, 1 Asus, 1 giga
    Fix up to test the system 1st before mount the WC block
    Temp test run all working fine, Quad SLI detected...
    Heatkiller GPU waterblock up time
    Heatkiller learn now backplate all come with spacer
    Thx to Kaiqi for the screw mount the backplate look alot nicer now.
    That how it look for 1 gpu now
    Last pic after some housekeep found how many asus boxes i have...
    Will try to take more better pic during the weekend when the lightning better as for now all pic take with mine iphone at night time only.
    Swee la!
  2. #32
    chiong ah~ finish soon
  3. #33
    Venom sio. Where is spidey! Chiong arrrrrr!
    |Processor: Intel i7 3930K,|Mainboard: Asus Rampage IV Extreme, |Memory: Corsair 8 x 4 GB DDR3 1600, |Graphics: 3 X Gigabyte 780TI Tri SLI, |Storage: Seagate 3TB Baracuda, 128GB ADATA PXG SX900, 2 X Kingston HyperX 3K 120GB |Audio: Aktimate Maxi, Matrix Mini I DAC, |Fan Controllers: Aquaero 6 Pro, Aquaero 5 Pro, Poweradjusts 2 Ultra, USBPower Supply: Seasonic X1250, |Casing: Caselabs STH10, |Monitor: Samsung S27A850D, |Keyboard & Mouse: Ducky Shine White, Razer Ouroboros, Cyborg RAT 7|System Fans: 8 X AP15 Gentle Typhoon, 7 X Enermax Magma|
    Custom Watercooling Parts: Bitspower Summit Plexi, AQC Acrylic Glass 780TI X3, Koolance MB-ASR4E Rampage 4 Extreme Block, 2 X Bitspower Universal Nickel Clear Plexi 4DIMM, Swiftech MCP655 X 3, EK Multioption X2 250, 480 Monsta, 360 Monsta, 360 Phobya G Changer
    Portable Audio Rig:
    Sony ZX2, Whiplash V3 IC, UM Miracles, Whiplash TWAG V2 Ecilpse
  4. #34
    Nice!
    CPU | i7-4790K | i7-4960X | i7-5960X | i7-6950X | i7-7700K
    Mobo | Asus VII Impact | Rampage IV Black Ed | Rampage V | Rampage V Ed 10 | Strix 270I
    GPU | AMD 295X2 | Titan (3-Way) | Titan X (3-Way) | Titan X Pascal | Titan Xp (2-Way)
    RAM | TridentZ (16GBx8) | Ripjaws4 (8GBx8) | TridentX (8GBx2) | Corsair Dom GT (4GBx8) | TridentZ (16GBx2)
    Display | Acer Predator XB321HK | Dell U2414H x3 | Samsung UE32F6400
    Storage | 840Pro/850Pro/840Evo | SM951 | 950Pro 512x2 | 960Evo 500x2 | 960Pro 1TB/2TB | Intel 750 400GB/1.2TB
    Case | CaseLabs S3 | Bullet BH2 | SM8 + Dual Peds | In Win D-Frame
    PSU | Corsair AX1200i x2 | AX1500i | Silverstone SX800-LTI
    Water Cool | Aqua Computer | Bitspower | EKWB | NZXT
    Audio | OPPO HA-1 | Asus E1 MUSES Ed (DSD Upg Kit) | Yamaha HS50M + HS10W / HD800 / JH16pro
  5. #35
    Nice! Hurry finish your build!
    Video of my Caselabs Mercury S5 with Pedestal. Click Here.
    Build Log of my SM8 + Pedestal. Click Here.
  6. #36
    MuhamMAD
    Dec 2012
    Irvine
    3,371
    Wdf, my favorite cpu block, backplate and motherboard
    Top Gun Pilot:Quadra1978
  7. #37
  8. #38
    Ok Project Log forum quite too long, also to force inoran81 hurry up...
    Some of the stuffs will done sometime back but lazy to update and get fk by all those that come mine hse and ask me hurry finish it...
    Some change been done, thx to black friday, ssd change and due to the intel logo i decide to find way to mount the SSD infront of the system and want to keep the design simple...\
    Fitting been done months back but lazy to post those pic..
    ROS shall have soild bridge for SLI.....
    SM8 seem very tight not much space...
    CPU 4960X
    MB Rampage IV Black Edition
    GPU GT 690x2
    RAM Corsair Dominator Platinium 4 x 4 GB 1866MHz CL9
    HDD Intel 730 480GB x 2 (Raid 0)
    PSU Seasonic X Series Platimun 1000W
    Case Caselabs SM8 Black
  9. #39
    Try to mount the front rad with demciflex, but it seem to big..
    Off it go...
    Simple fan grill design
    CPU 4960X
    GPU GT 690x2
  10. #40
    Stolen the idea from a Project log in Bit-tech...
    CPU 4960X
    GPU GT 690x2
  11. #41
    Same design for the top rad with Demiflex but extra been cut and remove...
    Last fan for the casing with Demiflex too....
    Have been thinking why light box need to be below and shine up, due to the space for SM8 there no way for me to build a light box to be put at the bottom, so i make a 2 in 1, light box + res mount on the rad not sure anyone have done before anot....
    Light up test
    That all for now going for mine holiday and think how to do the rest when back...
    CPU 4960X
    GPU GT 690x2
  12. #42
    jin swee and satki, finally u are back to pc/wc - support u dip dip!
    don like that leh... pang chance for me....i going HK ict soon liao...
  13. #43
  14. #44
    MuhamMAD
    Dec 2012
    Irvine
    3,371
    how come the floor so mess...???
  15. #45
    Quote Originally Posted by KnightRaven View Post
    Becaz testing and lazy to clean up before take pic...
    CPU 4960X
    GPU GT 690x2
  1. Project Log: Ascension
    By Ar3s in forum Case Modding & Project Logs
    Last Post: Oct 15th, 13, 11:00 AM
  2. [Project] Venom
    By Milliardo in forum Case Modding & Project Logs
    Last Post: Dec 21st, 11, 01:56 PM
  3. [Project Log] ???
    By sabe in forum Case Modding & Project Logs
    Last Post: Jul 12th, 10, 01:33 AM
  4. [Project Log]***PROJECT KURO***
  5. Personal Log: Deep, Deep Poison... (Aka Red Venom) ^^
    By Nashaz in forum Case Modding & Project Logs
    Last Post: Dec 12th, 08, 11:25 PM
