Page 1 of 5 123 ... LastLast
Results 1 to 15 of 72
    Schwarz Hölle, White Redemption
    Since my hardware is nothing of interest I'll be listing only the other gear
    Case : Phanteks Enthoo Pro
    PSU : Superflower Leadex Gold 650
    GPU : Powercolor R9 280X Turboduo
    HDD : Toshiba 3TB (Hitachi platform)
    SSD : Plextor M5S 128GB
    Fans : 3x AFB1212M PWM, 2x AFB1212H, 1x AFC1212DE
    RAM : Kingston HyperX Genesis 1600 OC'd to 1866
    CPU : Intel Xeon X5650
    Keyboard : CM Storm MECH
    Mouse : Logitech G502
    Headset : CM Storm Pulse-R
    WC Gear :
    XSPC Raystorm
    XSPC Razor 7970 (new style)
    Magicool 360
    Magicool 240
    Hard acrylic tubing (10x14mm)
    Compression fittings for acrylic tubing, Black acrylic reservoir
    D5 Vario w/ EK X-Top Rev.2
    No fan controller as this build doesn't need it. It's sometimes cool but nah.
    I must thank eugene @ hydra for helping with the RMA.
    View my original link of this log :
    Project Log : Fall Of Schwarz/The White Hölle
    DaveLT on OCN
    Fly Limpei Aeroplane: Radeon_Freak(829867xx)
    Thanks alot to razroid for "manufacturing" a right angle aluminum "bending tool"
    Bitspower users ... Does this look familiar to you?
    DaveLT on OCN
    Nice one bro. The aluminium bending tool looks good. Will make your work done easier.
    For watercooling products
    Visit:www.xtremecooling-pc.com
    Beware!!!
    Aeroplane Flyer: Radeon_Freak(829867xx)
    Quote Originally Posted by adeep91 View Post
    Thanks bro! When are you going to complete your rig :X
    DaveLT on OCN
    MuhamMAD
    Dec 2012
    Irvine
    3,371
    Lmao, Barrows fittings.
    Top Gun Pilot:Quadra1978
    Barrow fittings.... copied version of bp. Heard that quality is different. Btw whats a d.lt control center
    |Processor: Intel i7 3930K,|Mainboard: Asus Rampage IV Extreme, |Memory: Corsair 8 x 4 GB DDR3 1600, |Graphics: 3 X Gigabyte 780TI Tri SLI, |Storage: Seagate 3TB Baracuda, 128GB ADATA PXG SX900, 2 X Kingston HyperX 3K 120GB |Audio: Aktimate Maxi, Matrix Mini I DAC, |Fan Controllers: Aquaero 6 Pro, Aquaero 5 Pro, Poweradjusts 2 Ultra, USBPower Supply: Seasonic X1250, |Casing: Caselabs STH10, |Monitor: Samsung S27A850D, |Keyboard & Mouse: Ducky Shine White, Razer Ouroboros, Cyborg RAT 7|System Fans: 8 X AP15 Gentle Typhoon, 7 X Enermax Magma|
    Custom Watercooling Parts: Bitspower Summit Plexi, AQC Acrylic Glass 780TI X3, Koolance MB-ASR4E Rampage 4 Extreme Block, 2 X Bitspower Universal Nickel Clear Plexi 4DIMM, Swiftech MCP655 X 3, EK Multioption X2 250, 480 Monsta, 360 Monsta, 360 Phobya G Changer
    Portable Audio Rig:
    Sony ZX2, Whiplash V3 IC, UM Miracles, Whiplash TWAG V2 Ecilpse
    OEM of bitspower? I last heard from bryan that indeed there are differences in quality comparing to bitspower.
    And their tubing OD is 14mm not like bp which are 12mm.
    Portable Audio Rig:
    Quote Originally Posted by kaiqi07 View Post
    I believe Barrow is not BP oem although they look similar. Quality slightly less than BP but it is decent enough considering that they are cheaper. Still value for money.
    Video of my Caselabs Mercury S5 with Pedestal. Click Here.
    Build Log of my SM8 + Pedestal. Click Here.
    Hahahaha..
    So its a case of I think u thought who confirm. ..
    Good luck on the build
    Quote Originally Posted by elbryan03 View Post
    MUCH cheaper. I'm going for them because I'm you know, broke. But comparing their 45d rotaries and BP is like a Lexus LFA and a Chevrolet Corvette (bad quality) in terms of quality because BP is so much better, BP is smooth and the barrow 45d is nearly cannot rotate (ask terence52, i'm the one who bought the rotaries for him)
    Me thinks copycat nia. and ya, 14mm.
    Redo of the control center I last did on H&H
    Quote Originally Posted by akerue View Post
    Hahahaha..
    Thanks! How is business at your shop
    Quote Originally Posted by KnightRaven View Post
    Very sharp eye la you ... or you spend too much time on ****** like I do.
    DaveLT on OCN
    Anyone got white or black dye?
    DaveLT on OCN
    Sorry for the potato pics.
    3tb yeh.
    Made some PWM splitters last week
    Of course, a look at my current state of rig
    Testing LED strips I made for terence(52)
    Of course this will go into my rig!
    DaveLT on OCN
    Switching the res for this one :
    Rewired my D5 and added RPM monitoring
    CF'd also. Not a very good job but good enough for me.
    You know I've been tempted to use this for a long time to control my motors
    I'll be using something much smaller than the first one I used with H&H anyway
    Changing switch 810 for phanteks enthoo pro. time to redo build log picture! Stay tuned!
    DaveLT on OCN
    Changing switch 810 for phanteks enthoo pro. time to redo build log picture! Stay Tuned!
    DaveLT on OCN
  1. Project Log: Water Cooled White CaseLabs SM8
    By kiwi_kczt in forum Case Modding & Project Logs
    Last Post: Aug 25th, 13, 11:18 PM
  2. Replies: 94
    Last Post: Jul 25th, 13, 01:11 PM
  3. [SOLD] Project Log: NZXT Switch 810 - The White Lightning
    By ahweng38 in forum Whole Systems (Desktops)
    Last Post: Jun 20th, 13, 04:56 AM
  4. [Project Log] Phantom White
    By oakenfoldsg in forum Case Modding & Project Logs
    Last Post: Aug 2nd, 09, 10:02 AM
  5. [Project Log]***PROJECT KURO***
