Page 2 of 4 FirstFirst 1234 LastLast
Results 16 to 30 of 46
    Registered User Zenator's Avatar
    May 2015
    AUS
    132
    Hello all, Here is a small update, Added a cover to the GPU to hide the fittings
    Gone over the face panel again with with some fin detail and added some matting base paint to all the rust to make it pop a bit more. and scotched some parts of the face panel to dull it up a bit.
    Started doing some work on the cover door for the ROG base panel/DVD drive and so on.
    Also Getting the vents all painted and bent up. and adding texture too them as well.
    Have not had a lot of time to get much more done. but it's all starting to take shape.
    冬がくれた予感 YuukiHaruto's Avatar
    Jun 2014
    1,145
    FREAKING SICK FOR A FIRST BUILD.
    冬がくれた予感 きっと来る君が
    DR.X Tech - Tech Reviews, Audio Reviews
    Processor: AMD Ryzen 7 1700 on ID Cooling Auraflow 240
    Motherboard: ASRock X370 SLI Killer | Memory: KLEVV CRAS II 3000MHz C15 16GB kit
    Graphics: Zotac GTX1070 on ID Cooling Frostflow 240G | Display: Dell U2713HM
    Sound: 5.5" Bookshelves + FX Audio BL10A, Aquarius AK4495 XMOS, HA5000 Clone + AKG K7XX/Hifiman HE400i Storage: OCZ Vector 180 480GB
    Power: FSP Aurum PT 1200 | Chassis: Phanteks Enthoo Pro
    Peripherals: Tecware Phantom RGB 104 Keyboard, Logitech G403
    May 2015
    AUS
    132
    Hello again,
    I've been adding the details to the front frame door, And starting to add the textures. then will be adding the mesh to it.
    Thank you for looking.
    May 2015
    AUS
    132
    A bit more progress, Added screws to the side panel, finished the 2nd door. And working on some more weathering textures on the grill to make it look like water has been running off it, that's still work in progress. And added hinges to the grill as well, so I can open it to clean the fan filters.
    Input and feedback is welcome.
    Cheers, Zen.
    May 2015
    AUS
    132
    Cats out of the bag.
    I did not want to say want I'm trying to build till I knew if I could pull it off. Being this is my Fist try at Modding a PC. I needed to make sure I could make it happen.
    May 2015
    AUS
    132
    Working on some red and blue caps.
    Fun little things. I think, :
    May 2015
    AUS
    132
    First Tag plate done.
    May 2015
    AUS
    132
    Hi This one is a bit bigger. 520mm x 180mm.
    Been playing on the CNC.
    I'm going to be painting it as well but the font Fallout 4 will be lit with LED's
    from the bottom. and the rest will be painted to match the case.
    the plan is to frame it and mount it to the top of the case like a billboard.
    Hope you like it.
    Again thank you for looking.
    May 2015
    AUS
    132
    I have been using the Dremel at work so far. So was thinking it's about time I got one, And here it is my first ever Dremel.
    I have been working on the Fallout logo. so have not had the time to do much on the case. but here is where I'm up to with the case. Such slow progress. But I guess in saying that there is a lot to do.
    Thank you again for looking.
    Cheers, Zen.
    May 2015
    AUS
    132
    Hi again have not had much mod time this week. But here is what I have done so far.
    Here is a small step by step on the mounts for the billboard for the top of the case. will have two holding it up. I just need to work out the best way to make it work.
    Here is the back of the Fallout sign, still need to add weather marks but not until the mounts are fitted to it.
    Here is the face door, its just about done now. Added a spring to the left side to keep i closed. will add a pic for that later as I forgot to take one.
    Cheers, Ken.
    May 2015
    AUS
    132
    And the rust just keeps going. I going to start calling my self the Rust converter. I think my next build will be cleaner.
    Thanks for looking.
    May 2015
    AUS
    132
    Thanks again for following this build. Would love to know what you think of it so far. All feed back is welcome as always.
    Cheers, Ken.
    May 2015
    AUS
    132
    Hi again, Ok I'm going to be scratch building the Vault 111. the last photo. is the placement of where it is going. This build is all about fallout 4 so adding it to just needs to be done.
    Going to mach the texture true too the game.
    Sorry about the super shit photo's Will add better photos later. Just updated to windows 10 and now photobucket. is not working for me.
    Will be adding more to it then what you see here. And will still be painted in high detail.
    this is just a Photoshop overlay to show you all where it is going.
    Thank you Again for stopping buy.
    Cheers, Ken.
    May 2015
    AUS
    132
    Progress report
    I made a template in Photoshop and printed it to the size I need.
    Then comes the blade work, there are 4 layers of PVC plastic glued together so I can cut each at a time. Then once done will be sanded and then putty filled and sanded again. No CNC. for this part. all old school.
    Zen.
    May 2015
    AUS
    132
    One more for the day, Got it all cut out. and routed out the center with a Dremel with a circle tool. Fist time trying this and I think it work well.
  1. WTS: "Secret Live in Singapore" & "Venus in Fur" Tickets For Sale Cheap!!!
    By deve2545 in forum Miscellaneous Garage Sales
    Last Post: Mar 27th, 13, 12:12 PM
  2. WTS: HOT TOYS 12" IRON MAN MARK IV SECRET PROJECT 1/6 STGCC
    By WRCfan in forum Sports & Hobbies Garage
    Last Post: Sep 26th, 11, 11:49 PM
  3. WTS: HOT TOYS 12" IRON MAN MARK IV SECRET PROJECT 1/6 STGCC
    Last Post: Sep 16th, 11, 02:18 PM
  4. Top Secret Project downtown?
    By Christine in forum Chit Chatting
    Last Post: Jul 29th, 07, 11:35 PM
  5. Replies: 0
    Last Post: Jul 3rd, 07, 05:06 PM
