Page 1 of 3 123 LastLast
Results 1 to 15 of 34
    Registered User Zenator's Avatar
    May 2015
    AUS
    132
    The POWER CELL by Zen-Modz "Completed"
    Proudly Sponsored By. ASUS
    PC Build Specs:
    Height up to 600mm.
    Width: up to 400mm.
    Case Shape: cylinder. One base, One top, 3 Pillars, 3 clear windows. Being build ATM.
    Case Colour: Grayish/white, with some black & red.
    MoBo: Asus H97I-PLUS Mini ITX LGA1150 Motherboard That will mounted to the bottom and the case.
    GPU: ASUS TURBO GEFORCE GTX 960 OC Edition 2GB-GDDR5. Staying air cooled, This will be mounted to one of the 3 case pillars.
    Running on a PCIe cable. The TURBO GTX 960 with the exhaust out the bottom of the case,
    And the intake for the TURBO GTX 960 will come from the pillar it is mounted to.
    CPU: Still needed.
    RAM: Still needed.
    PSU: Still needed, Will be mounted in the base.
    Water Cooling, One custom 60mm x 400mm res. (2x 120 slim rads, CPU block, 1x Pump, fittings, still needed.) ( 6x90mm W 20x20mm H,D clear blocks running 9x5mm Round 500mm L tubing.
    that will be on the out side of the case as part of the loop. being built ATM)
    Lighting: Black Light, and some white LED's.
    Fluid: Neon Green, Still needed.
    Loop fittings: Still needed.
    Even though this is only my second Case Mod, I have been using ASUS Motherboards for many many years. I have always found them to be well priced and having lots of great features.
    And today is no exception. ASUS continue to add all the goods to there Motherboards and GPU's, Even for there low to mid range hardware you still feel you are getting more for less.
    As you will see below "Small" can still make a big impact and still play hard. And "Colour" is not Black or White its a shade of what your Imagination can do with it.
    Below are two of ASUS products that I will be using for this build from ASUS who I thank for helping me with my second case mod.
    The Asus H97I-PLUS Mini ITX LGA1150 Motherboard and the ASUS TURBO GEFORCE GTX 960 OC Edition
    This will be the first time using a board of this size. I find it hard to believe that something so small can still deliver so much. Just thinking of the doors for case modding this Motherboard has opened up for the different kinds of build that can now be done, that would have been imposable before.
    Unbeknown to me was this White TURBO GTX 960 OC Edition. The staff at ASUS could see what my new build was all about. And this White Knight is the perfect look for this build.
    I would love to go deep into the specs of this GPU. But I will leave that to the pro's at ASUS.
    here is where you will find all you need to know about the ASUS TURBO GTX 960 OC Edition.
    http://rog.asus.com/428182015/gaming...ecial-edition/
    May 2015
    AUS
    132
    Project: POWER CELL is a go!
    Hi again every one, Going to be starting on some of the smaller parts first.
    To start off with im doing the out side water blocks/res there will be 6 in all three at the top and three at the bottom. All 6 will be part of the cooling loop.
    They will be fitted to the out side of the case, The three on top will be linked the one's on the bottom. So one top one will link to one bottom one, with 3x 5mm clear tubes and so on. on the back of each block will be one fitting that go's to a stand 1/2 mantel bent loop. back to one of the other blocks and keeps going. Lets just call the outer blocks (Loop rails.)
    So below I have started a quick step by step.
    for the blocks, after ill be adding the 3x 5mm tubes to the 2x blocks to make one (Loop Rail.) and this will be done 3 times.
    Will add more soon for the Loop rails. Still working hard on the Vector files for the case parts as well. And still working my full time job. Sleep! what is that I ask. But I have 10 days off after next week. For more Modding.
    Again as always thanks for stopping by.
    Cheers, Ken.
    May 2015
    AUS
    132
    Hello again everyone. Ive put the 5mm tubing for the rails on hold for now as I well get a better idea of the length of them once the case starts going
    together.
    So what I have been going is working on the Motherboard armor and the back plate IO shield that will lock onto the Motherboard armor, Still need to make a hole for the CPU. but still not sure what CPU block will be used.
    Hope you can see where I'm going with what I have done so far.
    Thanks for stopping by.
    May 2015
    AUS
    132
    Lots more still to come.
    May 2015
    AUS
    132
    I have started working on the center res mount. So far I have made the casing, added some blue LED's, put some steel mesh around it. Still need to add a small electric motor to turn the black cover at the bottom. to create a rotation of light in side the case. Once that is done i will starting working on the rest of the res mount. And then add the rest of the trimmings.
    May 2015
    AUS
    132
    The CNC parts are now done, And are now being put together.
    Along with some of the hardware that will now be test fitted to the case.
    Then all the side pillars cut to size and will be added for the height, The Pillars will be box like to hide all the things you gust don't want to be seen running from the top of the case to the bottom. MOBO tray has been made as well but still needs to be vented on the back.
    Hope you like it so far, Would love to know what you think.
    Rad's & all 6 fans are fitted as well as the Res, It's now hanging from the top as well.
    Here are some progress pic's of the top cooling disk.
    Again thanks for stopping by.
    Cheers, Ken.
    May 2015
    AUS
    132
    Hello again.
    Just a quick update of where I'm up to.
    The Power Cell is coming along nicely.
    I have been working on the base and the pillars one of the pillars will hold the GPU, The GPU will take air in from the outside of the pillar as well as the inside.
    Ive cut out and mounted the GPU and all is good. Still making the Pillars stronger by making them two layers thick in side the two layers will be a 20mm space to run wires and such to the top and back.
    MOBO and Pump are new in there places as well, Once all the hardware is fitted, and the case is complete all the hardware will be removed again so I can start painting the case. inside & out.
    Here it is so far. Yep its talllllllllll: And might I say Different. (H-700mm )
    As always thanks for stopping by.
    May 2015
    AUS
    132
    Hi here are some more Photo's, Will have some more again in a day or so.
    Outer Loop tubing.
    GPU from the out side of the case, will have mesh over the face. and a filter that slides in from the side.
    Inside the case,
    I have made 3 mounts to hold the center Res Light, And to strengthen up the case a bit more. One of then needed to be change to work with the GPU space.
    My work shop or should I say my Wife's dining table. She loves ME!
    The bottom of the case with PSU filter.
    Again thank you for stopping by. more again soon.
    Cheers, Ken.
    May 2015
    AUS
    132
    Hello again.
    Today I fitted a flow indicator into one of the back pillars so it cans be seen from the inside of the case, I also added 2 micro switchers to the bottom front of the case, One switch has a green LED, and the other is blue, One switch will be for the power and the other will be the reset, the blue LED will be the HDD drive light, and the green will be the power light.
    Thanks again for stopping by and following the build.
    May 2015
    AUS
    132
    Hi All
    The I-beam has been test fitted, here are some photo's of where they are going.
    What do you think ?
    Cheers, Ken.
    May 2015
    AUS
    132
    Hello again everyone, Just a small update I have made a dust filter for the GPU as well, That slides out for the side of the pillar for cleaning. And added the mesh. I have done more to the GPU mount. But will have some updates on the weekend.
    I have also change the logo it needed redoing the old one was bugging the crap out of me, and the new logo can now be easily made on a CNC or laser cutter if need be.
    May 2015
    AUS
    132
    Hello Again,
    Still progressing on the Power Cell. I have been adding more details to the outer rims of the case, Still a lot more to do there. I have now also added the lower I-beam arms. As well as the outlet for the GPU. I will be doing all the side covers for the top and bottom base over the next week. Getting much closer to having it ready for paint.
    Thanks again for stopping by.
    May 2015
    AUS
    132
    Hello again.
    Starting to add some lighting to parts of the case. before I start looking at the painting things I need to make sure it's all working and fits. And once all the painting is done. I will fit all the light FX to it again.
    This bit is for any one that likes playing with electronics. I have not done this for some time my self. But it's time to do some soldering again. The top dish of the case will have a ring around the outside edge. The plastic around the outside is a translucent white. So the light can be seen the rest of the case is made of a solid white, and will be backed with black paint. This part of the case will pulsate with light behind it.
    LED string,
    Jaycar kit.
    May 2015
    AUS
    132
    Power Cell Light test.
    I ended up changing out the PCB's to RGB LED tape. I just made up a inner ring to run the tape. Still need to blacken out the inside to stop any light bleeding out.
    https://www.youtube.com/watch?v=6Dz2...ature=youtu.be
    May 2015
    AUS
    132
    Hello again time for a new update,
    Below is the curving process I used to get the sides done, I placed the inside a thin sheet of alloy that will hold the curve that's needed and heat it up with a heat gun till it forms the same shape then let it cool. After this I have cut a window out and added mesh to it. Still work in progress.
    I have also fitted a HX1000i PSU.
    Finished the front Start/reset.
    The MoBo armor cover is now done as well.
    Hear is the Colour theme I'm going to be doing on the out side of the case.
  1. Replies: 0
    Last Post: Aug 15th, 13, 11:35 PM
  2. IE 8 beta 1 test build coming soon
    By newzhunter in forum News around the web!
    Last Post: Feb 25th, 08, 06:04 PM
  3. First Opera 9.5 build coming Tuesday
    By Marduk25 in forum News around the web!
    Last Post: Aug 30th, 07, 11:37 PM
  4. Cell processor coming to IBM mainframe computers
    By bbmf in forum News around the web!
    Last Post: Apr 27th, 07, 01:10 PM
