Results 1 to 5 of 5
    Registered User terence52's Avatar
    Mar 2009
    Bedok
    14,009
    [Review] ID-Cooling Frostflow 120L.
    Of something. Write up incoming.
    Hint: Nothing really that special but seems promising on paper, and yes, some blink blink of the colours I like. lol.
    This time,
    I am reviewing the ID-Cooling Frostflow 120L.
    Yes it is another 120MM AIO.
    (Box Pictures)
    Front:
    Rear: (Writeup)
    Left: (Dimensions)
    Right side: (Features)
    Top: (Specification)
    - What goes around comes around -
    Mar 2009
    Bedok
    14,009
    Reserved - First Looks (Not really)
    Inside the box:
    Pretty standard packing as far as AIO goes.
    Opening it up: (Manual on top)
    Cooler in question, all nicely wrapped:
    Mountings, I like how they painted the brackets black, if only the mounting threads/nutss were also black, it would be a perfect match in a full black system:
    Manual on how to mount the cooler and accessories.
    Mar 2009
    Bedok
    14,009
    With Intel mounting mounted, not sure of a single screw approach but it secures it well enough as the brackets does not bend unless a lot of pressure is applied on it.
    Not a polished based but at least its free of marks and relatively flat.
    The tubes are 29CM, rather conventional for most AIO
    Rad width is 28mm and its a standard thin AIO width
    Fan is a 11 blade, 120mmx25mm fan which spins at 2200rpm, sadly a sleeve bearing.
    With fan, it would be 53mm.
    Fan mounted into the frostflow
    Mounted into test system:
    LED effects looks good. Sadly it only run clockwise at all times.
    Mar 2009
    Bedok
    14,009
    Reserved: Testing.
    Happened to have a system that popped up for troubleshooting so used it instead.
    CPU: I7 2600
    Motherboard: MSI Z77MA-G45
    Ram: KVR 16GB
    GPU: MSI GTX660 Gaming 2GB
    SSD: Kingston V300 120GB
    HDD: Samsung F3 1TB
    PSU: Seasonic P-1000W
    Casing: Lancool K62 (1x 140mm fan intake, 1x 120mm exhaust)
    Cooler tested: Intel stock cooler, Cooolermaster Hyper 212+/Evo and well above.
    It gives a baseline performance figures from the stock cooler to a decent aircooler to the AIO.
    Test used: IBT (2 runs at maximum).
    Results:
    Idle:
    Stock Cooler
    Hyper 212+
    Frostflow 120L (1000RPM)
    Frostflow 120L (Fan at max speed)
    Load:
    Stock HSF:
    Hyper 212+
    Frostflow 120L (fan at max speed)
    Chart:
    Its not too bad as a entry level AIO but I feel that the fan is rather ill-suited to the application.
    Mar 2009
    Bedok
    14,009
    Conclusion:
    It a pretty nice AIO for those who want a red theme AIO, I do recommend a better static pressure fan for it so that you can extract more performance out of it.
    Pros:
    Bigger tubing compared to others at its pricepoint
    Black mounts
    Build, none of the plastic creaks when pressed and it feels rather solid
    Cons:
    Rather hard to change the rotary connector as its very rigid.
    Make the screws black as well.
  1. Motherboard: windwithme’s Core i7 review Part 11-MSI X58M Micro-ATX OC Review
    By windwithme in forum Hardware Depot
    Last Post: Aug 5th, 09, 07:40 AM
