Its been 9 years since the BLACK OPS II mod. [Project Log] BLACK OPS II
There was a 2.0 version when i upgraded the hardware. Wanted to change the casing then but front hard disk access is like non-existant
Anyway, a user recommended me a case when asking for recommendation for hard drive hotswap bay accessible from the front of the casing.
3-4 days later, Lazada delivered to my house back in January. The Silverstone CS380
Actually completed transferring the hardware over with basically an upgraded graphic card (there is a reason why the previous one CMI)
Although still waiting for PSU cables to be ready & tidyingup the cables.
So this will just be a log for version III. I am although less ambitious then the previous due to time & other commitments.
So finally we have the BLACK OPS III
The Core ideas will be the same:-
Black
I love this colour. Sent to David for powder coating as usual. He told me he has not done PC case for 10years already.
I am likely the first & only person to powdercoat a NAS casing
Covert
Added some insulation form, hopefully to, help however minimal, minimize noise but actually more to prevent the metal case to be less clanky but ultimatly less noisy overall.
Conceal
Cable management.
The plan is still to route most of the wiring/cables such that it stays hidden from view.
Unlike the P182, this CS380 is 1/4 smaller & much more challenging.
So this time round, I opted to not spent too much time to route the sata/psu cables & fan wires into the nook & cranny of the case.
To make it easier, also ordered custom sleeve cables for the psu to give it a neater, clean & minimalistic look. So this part is a work in progress
Operative
Apart from minimal concealing of the wiring/cables, it need to provide ease & flexibility for upgradability & change of hardware.
Due to not hiding the psu cable & custom sleeve cable, any future psu upgrade should be a breeze.
With front hard disk access, I do not need to take the casing apart. (Unfortunately most casing do not have this feature so I am limited to silverstone CS380)
I have many frustrations previously in this area so really glad for this feature to be available. The P182 is not designed to but partially works but I had to sacrifice 1 front intake fan.
So basically I have to mod/route it efficiently to minimize the effort when removing or upgrading parts.
To be continued......
