Page 2 of 7 FirstFirst 1234 ... LastLast
Results 16 to 30 of 95
    Long Lasting enegizer's Avatar
    Jan 2005
    SG - MY - CH
    3,509
    PM u on this better .. here is guide chat mah .. hehe
    Retired from IT
    SFFMadness
    Not completed leh.... 20/24pin ATX connector removal guide? :confused5
    Newbie of Past & Present yantronic's Avatar
    Nov 2004
    Paid Accomodation
    22,891
    Good one man!
    Haha everyday pass by your block never go grab AVC
    The opinions expressed above do not represent those of VR-Zone (VR Media PTE LTD Singapore) or any of their affiliates.
    Dead Man Walking
    Sep 2005
    British Columbia, Canada
    483
    Quote Originally Posted by SFFMadness
    I cut off the 24pins connector and manually transfer than to a 20pins connector and a 4pins connector I bought from Chamoxa.
    CPU: X2 4600+ Windsor Mainboard: Gigabyte GA-MA785GM-US2H Graphics : AMD 785G ATI Radeon HD4200 Memory: Kingston DDR2 667MHz 4 x 1GB HDD: Seagate Barracuda SATA2 1TB Optical: Liteon IHOS104 4X BLU-RAY Reader Case: Silverstone Sugo SG02W-F White Power Supply: SuperFlower Modular 550W Display: Samsung LCD TV 32" Audio : Kilpsch CS-500 (HTIB) & Promedia Ultra 2.0 Input Devices: Gigabyte GK-KM7500 Wireless Keyboard & Mouse Combo O/S : Windows 7 Ultimate X86
    hey just to double check ar, the black wires in the molex can be connected interchangably right?
    Jan 2005
    SG - MY - CH
    3,509
    ok will up 20/24pin atx connector removal guide soon tonite..
    gonna take pictures & show u all later. no need tool, just the good old staple tricks
    Retired from IT
    Smile
    Hi folks...found another way to shrink those heatshrink..
    Found this at my work place so decide to try...
    The flames it spews out is not the same as the lighter one...with red flames..this only spews out blue one...and its adjustable..check it out..
    So far so good for my d.i.y...needs to be careful though not to 'over cook' it.. ...Hopes this helps...Cheers!...
    PEACE!...BOOM!
    AMD Phenom II X3 720 BE @ 3.1Ghz | MSI 790GX-G65 | Team Elite 1333MHz DDR3 4GB kit | Powercolor HD4890 PCS+ 1GB @ 1000/1100 | WD green power 500GB | Samsung DVDRW | LG W2343T 23" LCD | CM 620W Modular PSU | CM 690 Pure with side window mod | Windows XP Hm - SP3 |
    twister089
    nice!...i would love to get my hands on one of those lighters....but dun seem to find it anywhere
    Jan 2005
    SG - MY - CH
    3,509
    updated .. today, July 8th 2006.
    Guide on ATX Removal.
    and types of Sata connectors. Which type can remove & which type cannot be removed.
    Retired from IT
    zaifry
    enegier...look here
    can you pm me on your charge for sleeving up psu antec....
    Hearing Is Believing kvm's Avatar
    Jun 2006
    3,386
    Can pm me the charge for modular PSU?
    bro, can check with y0u..?
    Seasonic S12 and Coolermaster full sleeving shld be fine right..?
    esp the SATA connectors...
    think it's not like Antec's factory sealed ones...
    lo0king to get either 1 of these followed by full sleeve..
    regards, cheers..
    upper
    Nov 2005
    1,140
    for the ATX 20/24 pins, i was thinking of using masking tape to tape up the position of the wires leading to the connector, should be easier plug back afterwards
    Intel i7 2600K | Asus P8Z77-I Deluxe | 16GB Crucial Ballistix Tactical LP | Sapphire RX480 | 128GB Crucial M4 | 512GB Samsung 830 | Silverstone ST45SW-G 450w |NCASE M1 Black | H80i CPU | H75 GPU
    Jan 2005
    SG - MY - CH
    3,509
    use camera to remember the positions of the wires ..
    Same colored wires can jump around.
    Except : when some psu come with thinner "orange+brown" cable then cannot swap around with other orange.
    Except : when u find 2 orange wires, 1thin, 1thick. Then better put back the same spot.
    Retired from IT
    XProfessionalX ...
    Jun 2006
    Asia
    13,952
    Can those 4pin molex got 2 black and 1 red and 1 yellow, can the 2 black jump about ? Thanks
