Page 1 of 14 12311 ... LastLast
Results 1 to 15 of 209
    Registered User rEe_TaN's Avatar
    Dec 2005
    West Area
    1,238
    Water-Cooling Issue on new rig..
    Hi bros,
    Have an issue with newly install water-cooling rig.. Default temp is around 54 which is something not right with a water-cooling setup.. This is my specs:
    Mobo: Asus Crosshair V
    CPU: 1090T
    BIOS: 1503
    RAM: Transcend DDR-3 2000 (4GB)
    GFX: 7970
    PSU: Seasonic Gold 760w
    And 1 more thing is after i shutdown.. there is some empty space in the tube that is near to my reservior.. Should i fill to the full?
    My Game Rig~ :
    Processor: Intel 7700K
    Mobo: Sabertooth TUF Z270 Mark 1
    Memory: 32GB DDR4
    Audio: Onboard Realtek
    Storage: Intel 600p Nvme, Mushkin Scorpion Deluxe 480GB SSD, OCZ Revodrive 3x2 480GB SSD
    Graphic: Titan Xp Star Wars Galactic Empire Edition
    PSU: Silverstone 800w Modular
    Optical Drive: NIL
    Casing: Phanteks Enthoo Evolv ATX
    Monitor: 2x Dell U2410 IPS
    Cooling: Corsair H100i & 7 Fans
    A World of Endless Love.. Thanks to Delun (Photographer) & Rachel (Model)
    Registered User terence52's Avatar
    Mar 2009
    Bedok
    14,009
    Specs of your loop?
    - What goes around comes around -
    bro, for the res its normal cause of ur placement, as for the temperatures, the temp contributing to 50+ C is the rams/gfx/cpu.
    example,
    cpu - 38C
    ram - 36C
    gfx - 70C
    average temps, = 144C rad is able to take away 90C of heat, therefore circulating around will be 54C. each individual component u put under water will be contributing to the heat built up unless u can go for 2 loops. this is just an example.
    btw is ur top rad fan intake or exhaust?
    Take note :
    1]Please confirm with me for Warranty/Box/Receipt/Condition if u want to purchase any item
    2]Item without warranty will be given 3Days personal warranty
    3]Any defects after the 3Days personal warranty will not be entertained
    4]Please check item before dealing or u can test it at my house
    5]Dealing location will be at [BOONLAY MRT or MY HOUSE]
    6]Priority will be given to those who purchase in bulk
    7]Any Bids below Starting Bid will be ignored
    8]Once Confirm any dealings please pm me your contact
    Case Modding Service
    Black Dragon Case Mod
    WTS many pc components
    Dec 2005
    West Area
    1,238
    My rad is XSPC EX240 and MCP655 pump and my top rad is exhaust.. Ken bro, do you mean my loop setup is totally wrong?
    My Game Rig~ :
    Memory: 32GB DDR4
    Optical Drive: NIL
    Quote Originally Posted by rEe_TaN View Post
    loop is fine but i dont think the rad is enough to take heat away, btw what u res model?
    Take note :
    Dec 2005
    West Area
    1,238
    Bitspower Water Tank Z-Multi 150 - POM.. I tried to reseat my cpu block and reapply thermal paste.. It does help but it still goes ard 50Celsius ..
    My Game Rig~ :
    Memory: 32GB DDR4
    Optical Drive: NIL
    Real World Overclocking! MacClipper's Avatar
    Sep 2004
    In His Majesty's Service!
    13,748
    So many big air columns seen in this shot... bleeding not done properly?
    'He is no fool who gives what he cannot keep to gain what he cannot lose' - Jim Elliot
    Click on the pic to download a free pdf sample of the bestselling book!
    Science the new God - till now, Science has not been able to determine precisely even the size of the universe.
    By what yardstick then does Science hope to use in measuring the Creator of the universe? Think again.
    ★ Asrock-Asus | FX-9590 | Corsair Vgn Pro | NiCu HK 3.0-GTX360 | Vapor-X 280X | Corsair RM1000 ★
    My 24/7 Real World Overclocking! Blog
    Dec 2005
    West Area
    1,238
    Quote Originally Posted by MacClipper View Post
    shld i fill to the max? this is wat look like after stop..
    My Game Rig~ :
    Memory: 32GB DDR4
    Optical Drive: NIL
    Sep 2004
    13,748
    You should not have any air columns in the loop at all cos physics lessons tell us that unlike water (a fluid, incompressible), air (a gas) is
    1. highly compressible, waste of the pump pressure with loss of heat removal capacity
    2. conducts heat very poorly, lagi jialat
    Besides air in the loop also makes lots of unnecessary noise when water cooling is supposed to help you cut noise. So even air bubbles are not quite welcome either which is where bleeding the loop comes in.
    Google
    hmm some issues i see:
    1. tubing from your res to your pump does not look like it will feed your pump with fluid consistently. if i'm not wrong, we might think that gravity will push the water into the pump but because it's a closed loop, there is the problem where a vacuum will not allow the water to displace (or something like that). i used to have a similar setup where the feeding of water was parallel to the inlet of the pump. there were a lot of frequent gurgling sounds because of the air bubbles going into the loop.
    2. i don't think a 1 x 240 rad is enough to take the heat load off the cpu, gpu and ram.
    Intel i7 980X | EVGA X58 E760 Classified | 6GB Corsair Dominator | Sapphire HD5970 2GB | Asus Xonar D2X | Logitech Z-5500 | 2 x Intel X25-M G2 160GB RAID-0 | 2 x WD Velociraptor 300GB RAID-0 | WD Black 1TB | Pioneer BDR-S05J | Corsair HX850 | Dell 2408WFP | MM Pinnacle 24 | Filco Black w/ Cherry MX Brown KS | Razer Imperator
    Swiftech Apogee XT WB | Swiftech Epsilon 5970 FC WB | EK X58 Classified FC WB | 2 x TFC XChanger 360 w/ 6 x Scythe GT | MCP 655 w/ BP Mod Kit & Koolance Pump Nozzle Base | DD Rad Res | BP 7/16' ID 5/8' OD Compression Fittings | Koolance QDCs | PrimoFlex LRT 7/16 - 5/8 | DW w/ PT-Nuke w/ Silver KC
    Dec 2005
    West Area
    1,238
    Hmm yeah i hear some gurgling sounds when i power on my pc.. but there are no bubbles on any tubes and that part on the photo, is it i never completely fill the coolant? Btw i make a mistake on the rad.. it is a 360 rad
    My Game Rig~ :
    Memory: 32GB DDR4
    Optical Drive: NIL
    Dec 2005
    West Area
    1,238
    My coolant on res reach to the max already but when i switch on my pc, the coolant drop to half.. from there, shld i remove the filling port cap to remove some air?
    My Game Rig~ :
    Memory: 32GB DDR4
    Optical Drive: NIL
    weird, the air-trap should be in your res instead of partially going to your tube b4 res.
    have u tried tilting your whole casing to allow the bubbles to enter the res?
    Dec 2005
    West Area
    1,238
    Quote Originally Posted by K-Dash View Post
    Yeah i did that before.. But i suspect is it due to i never fill enough coolant to the reservoir and that why the tube got this air columm?
    My Game Rig~ :
    Memory: 32GB DDR4
    Optical Drive: NIL
    Club VR Member simways's Avatar
    Dec 2009
    Yishun Chong Pang
    4,276
    maybe can try to reverse the tubing on your ram block.
  1. Water cooling issue
    By Mormor in forum Hardware Depot
    Last Post: Sep 18th, 12, 07:51 AM
  2. New water cooling rig
    By EpicGear in forum Case Modding & Project Logs
    Last Post: Nov 14th, 11, 05:15 PM
  3. My first water-cooling rig.
    By greenarrow2k4 in forum Hardware Depot
    Last Post: Feb 22nd, 10, 12:57 PM
  4. water cooling rig
    By angel90210 in forum Hardware Depot
    Last Post: Aug 5th, 07, 01:37 AM
  5. Getting a Water Cooling Rig in S'pore
    By Mo21 in forum Hardware Depot
    Last Post: Nov 12th, 03, 09:52 PM
