Page 2 of 2 FirstFirst 12
Results 16 to 24 of 24
    Tech Dynamic Pte Ltd
    514 Chai Chee Lane #04-11
    Singapore 469 029
    6717 3000
    www.tech-dynamic.com
    www.facebook.com/techdynamic.sg
    Register User spyboy48's Avatar
    Dec 2005
    Pasir Ris
    14,747
    nice!
    Blacklist: Biff73
    Often criticism is experienced as a narcissistic injury(Narcissistic personality disorder), low self esteem, cannot except but take offence.
    ~~~ A good name is rather to be chosen than great riches!!! ~~~
    i7 980X OC with Ex58 UD3R thread.
    http://forums.vr-zone.com/overclocke...processor.html
    My MystiQue CM case : http://forums.vr-zone.com/showthread.php?t=262828
    System Specs 1 & 2: (SNiper3/3770K/G.Skill 4GBx4 2400MHzCL9/AmD6870/SevenTeam1400W/Open Rig (M5G/3770K/Samsung4Gbx4 2400MHz/470GTX/320Gb/Acebel 550w/Samsung2333sw)
    My New world record:
    http://www.futuremark.com/pressreleases/60363
    My Past & present Toys : Intel 630/830/940/4300/E6300/E6600/Using2140/6750/8400/E3110/E2160/E7200/E8400 Q816A275/E8400Eo Q827A429/E8500Eo Q820A713/E8500Eo Q822a720/Q6600Go/i920Co/i920Do3848/i980x 3003A957/i750/3960X/3930K/3770K x 3/3570K
    Very nice indeed.
    DaveLT on OCN
    Fly Limpei Aeroplane: Radeon_Freak(829867xx)
    Cooltek W2 Review - Page 8 of 8 - Play3r
    After a very enjoyable experience building inside the Cooltek W2 it is now time to sum it all up and let you know my final thoughts. Let me just start with saying while I don’t like to pick favorites, this case would definitely be near the top of the list if I did.
    Buy the full range of Jonsbo casings online!
    http://www.lazada.sg/catalog/?q=Jonsbo
    Singapore 469 029
    6717 3000
    Is the windowed version in already?
    Intel i5 760 | Asus P7P55-P | GSKILL RipJaws CL7 4 x 2gb | Pioneer A12 | Samsung 203B | MSI ATI5850 | CM Stacker 832 | TT ToughPower 750 Modular | Dell 2407WFP-HC | Auzentech Prelude 7.1| Creative T3 2.1
    Hi there, it should reach by end of this month.
    Sorry for the long wait.
    Singapore 469 029
    6717 3000
    Ok. Thanks.
    A review of the Jonsbo W2 by TPU:
    Cooltek W2 Review | techPowerUp
    The Cooltek W2 goes for around 105 euro including taxes.
    Excellent construction
    Solid aluminum shell
    Compact cube dimensions for an XL-ATX chassis
    Three 140 mm fans included
    Easy to keep things clean
    Can hold up to 280 mm radiator in the front
    Fan controller built right in
    Dust filter on all intake areas
    Magnetic dust filter for PSU
    5.25" drive bay in the rear
    Can easily hold 120 mm tower CPU coolers
    High quality construction of buttons and I/O, on separate PCB
    Available in black or silver
    9.6/10
    To Cooltek W2 can be considered a direct competitor to the Corsair Carbide Air 540. Both feature a cube layout and can hold large motherboards. While the Air 540 scores with its two front 5.25" drive bays, the W2 fights back with a better mix in terms of hard-drive space. And while the Air 540 is more flexible when it comes to liquid-cooling setups, the W2 offers its own unique feature with a built-in fan controller. But enough of the comparison as both cases target a very similar crowd, but with quite the different approach. Mostly staying clear of plastic, though there is the side window, the Cooltek W2 impresses with its material mix. And the three 140 mm fans packed into the chassis right out of the box, will put a smile on your face since you essentially won't have to fork over any more money for additional cooling units. Cooltek has done an excellent job in creating a clean-looking, understated chassis with a great balance between external and internal storage options, support for large components, and great cable management possibilities—even though the rear 5.25" drive bay slot may take some getting used to. With a price roughly 20 euro below the Corsair Carbide Air 540, the Cooltek W2 is more than just a really enticing alternative if looking for a full-sized cube chassis.
    Singapore 469 029
    6717 3000
    http://www.pcgameware.co.uk/reviews/...2-case-review/
    When unboxed, the Cooltek W2 is certainly a case to be admired. The satin black and brushed aluminium panels not only look stunning, but very well finished and meet up together perfectly. The case design clean and sleek, aesthetically the W2 simply oozes with class. Then by simply popping off the pin held side panels, we find a surprising amount of space for a case measuring 385(H)mm x 278(W)mm x 395(D)mm. We find plenty of space in the reverse chamber for an ATX PSU of up to 250mm in length, 3x 2.5″ storage drives, then either 2x 3.5″ drives or a 3.5″/5.25″ combo, made all the better for the huge expansive space left over for easy cable mismanagement. Then of course the main chamber offers plenty of space for even an XL-ATX Motherboard and Graphics Cards up to 320mm. The W2 may only allow for air CPU Coolers of a maximum height of 163mm, but with enough space for a 120mm radiator in the rear, 240mm radiator on the floor or even a 280mm radiator in the front, it would seem clear to me that the W2 would be ideal for an expansive AIO or custom water cooling.
    Design/Quality
    Singapore 469 029
    6717 3000
  1. Discuss: Jonsbo W2 (Dual Chamber ATX Aluminum Case)
    By Tech-Dynamic in forum Hardware Depot
    Last Post: Jun 20th, 14, 09:54 AM
  2. [SOLD] Cooler Master CM SGC-1000-KWN1 STORM ENFORCER WINDOW ATX Casing Case Chassis
    By loongyh in forum Other Hardware Components
    Last Post: Jun 16th, 14, 06:46 PM
  3. [Mini Review] Jonsbo V4 Micro ATX Aluminum Case
    Last Post: May 29th, 14, 10:57 AM
  4. [SOLD] LIAN LI PC-7FN Aluminum ATX Window PC Case USB 3.0 READY.
    By swiftee in forum Other Hardware Components
    Last Post: May 10th, 14, 03:47 PM
  5. WTS: Black Jonsbo V4 Micro ATX Aluminum Case
    By XiaoDongDong in forum Other Hardware Components
    Last Post: Nov 4th, 13, 12:58 PM
