Results 1 to 2 of 2
    Register User spyboy48's Avatar
    Dec 2005
    Pasir Ris
    14,749
    AORUS P850W 80 Plus Gold Modular Power Supply (10yrs warranty)
    Gigabyte is launching the ALL NEW AORUS P850W and P750W PSUs, with certified "80 PLUS Gold" above 90% efficiency at 50% load and silent operation, as well as modular customisation, and enhanced durability for gaming enthusiasts, especially with multiple GPU builds for VR gaming, and stability in Overclocking too.
    The better power efficiency leads to less wastage of power, less heat and fan noise.
    As I type on my PC with Aorus P850W PSu installed. It Boots up and run smoothly!
    There are lot of PC hardwares you can invest in but the heart of the PC is the PSU, Reliability, Durability, Stability and above ALL, the Performance of 10 yrs warranty with 80 PLUS GOLD Certified!
    It won't go wrong of an investment for a 10 yrs warranty down the road, and with a very good track record of after sales service support from a local distro (CDL). (I am not promoting it but it is a fact!)
    Features
    Fully Modular Design
    High quality 100% Japanese Capacitors
    135mm 2 ball bearing smart fan with fan stop function
    80 PLUS Gold certified: above 90% efficiency at 50% load
    Single +12V rail
    OCP/OTP/OVP/OPP/UVP/SCP protection
    10 years local warranty (Adjusted according to different regions)
    https://www.gigabyte.com/Power-Supply/GP-AP850GM#kf
    Blacklist: Biff73
    Often criticism is experienced as a narcissistic injury(Narcissistic personality disorder), low self esteem, cannot except but take offence.
    ~~~ A good name is rather to be chosen than great riches!!! ~~~
    i7 980X OC with Ex58 UD3R thread.
    http://forums.vr-zone.com/overclocke...processor.html
    My MystiQue CM case : http://forums.vr-zone.com/showthread.php?t=262828
    System Specs 1 & 2: (SNiper3/3770K/G.Skill 4GBx4 2400MHzCL9/AmD6870/SevenTeam1400W/Open Rig (M5G/3770K/Samsung4Gbx4 2400MHz/470GTX/320Gb/Acebel 550w/Samsung2333sw)
    My New world record:
    http://www.futuremark.com/pressreleases/60363
    My Past & present Toys : Intel 630/830/940/4300/E6300/E6600/Using2140/6750/8400/E3110/E2160/E7200/E8400 Q816A275/E8400Eo Q827A429/E8500Eo Q820A713/E8500Eo Q822a720/Q6600Go/i920Co/i920Do3848/i980x 3003A957/i750/3960X/3930K/3770K x 3/3570K
    Dec 2005
    Pasir Ris
    14,749
    The Aorus P850W and P750W power supplies not only have built-in OVP, OPP, SCP, UVP, OCP and OTP circuit protection designs but have also undergone rigorous testing of various safety regultations of various countries.
    AORUS has design flat cables for better cable management, so that your gaming rig will look awesome with improve thermal performance/more air flow to having thick chunky cables hanging everywhere.
    Plus the capacitors at the cables for better power quality, to reduce noise and ripples.
    GIGABYTE taps high quality 100% Japanese capacitors on the new AORUS PSUs, with a single +12V rail ensures better power efficiency output with stability for your hardware, and a huge 10-yrs warranty depending on your region.
    80 Plus Gold certified ensures to deliver 90% efficiency at 50% load. The better power efficiency leads to less power waste, less heat and less fan noise.
    Thus, saving you electricity bills in the long run.
    Blacklist: Biff73
  1. WTS: Seasonic PSU Power Supply S12G 750w Non Modular 80+ Gold with Warranty
    By yellowduck in forum Other Hardware Components
    Last Post: Jun 14th, 15, 06:35 PM
  2. Replies: 4
    Last Post: Mar 7th, 14, 01:21 PM
  3. WTS: Corsair AX-1200W Modular Gold PSU (Power Supply AX1200)
    By ordway in forum Other Hardware Components
    Last Post: Jan 24th, 13, 10:48 PM
  4. WTS: Seasonic x1250 Modular 80+ Gold Power Supply PSU (1250W)
    Last Post: Oct 4th, 12, 10:51 PM
  5. [CLOSED] Seasonic Gold X750 modular power supply
    By zmwang in forum Other Hardware Components
    Last Post: Oct 16th, 11, 09:13 AM
