Page 3 of 3 FirstFirst 123
Results 31 to 37 of 37
  1. #31
    Quote Originally Posted by reddevil0728 View Post
    Might want to use PoE so need to get either PoE injector or PoE switch
    actually, that cable is a POE injector.
  2. #32
    Quote Originally Posted by Del_CtrlnoAlt View Post
    Hmmm? Then where is the power source coming from if I am just gonna use a normal switch?
    Whatever floats your boat...
  3. #33
    This will give u a clear pictures....
    DIY Projects – How To » How to wire POE camera CCTV
    As for TRENDnet , a little print from its manual ""* A power adapter (sold separately) can be used instead of PoE switch""
    For Geek @ http://www.ubnt.com/edgemax/edgerouter-poe/
    24/7/365 Powered By :
    (>'-')> Sophos_UTM + fq_codel <('-'<)
    ┏(°>°)┛ RIPE Atlas Probe ┗(°<°)┓
    /˚>˚/ PRTG ...etc \˚<˚\
    ^-(ツ)-^
  4. #34
    1 is the ethernet plug, the other will come with an adaptor with voltage for the camera.
    so just plug and play from there.
  5. #35
    Quote Originally Posted by w0wb0w View Post
    What I mean is I know the camera provides an alternative to PoE. But I am looking at using the PoE option so I need to get either PoE injector or PoE switch.
  6. #36
    viralcameras
    Hi,
    You can do both.
    You can buy a regular ip camera (not the one which is connected to USB on laptop for skype and other things). Or you can get cctv/ survilance camera. Just remember to open your firewall port on the router in order for the cam to stream on internet/outside your home. Otherwise you will be able to control only within your local network. You can check here different kind of cameras streaming live online with different brands:
    http://www.viralcameras.com/0/posts/...-linksys-.html
  7. #37
    You must have static IP from your ISP...
  1. WTS Wifi Surveillance Camera for your home. Watch your baby/maid from anywhere! $125
    By romz1983 in forum Singapore Marketplace / Garage Sales
    Last Post: Jun 29th, 11, 10:35 PM
  2. CAR/HOME Smart Surveillance CCTV/DVR Camera CHEAP!
    By PhiBer in forum Cameras Garage
    Last Post: Aug 5th, 09, 01:42 PM
  3. CAR/HOME Smart Surveillance CCTV/DVR Camera
    By PhiBer in forum Miscellaneous Garage Sales
    Last Post: Aug 5th, 09, 01:41 PM
  4. Surveillance Camera / Home Security
    By zechraffie in forum Networking & Broadband
    Last Post: Jun 1st, 06, 06:44 PM
  5. Surveillance Camera
    By bliondi in forum Singapore Marketplace / Garage Sales
    Last Post: Aug 4th, 04, 09:59 PM
