Results 1 to 3 of 3
    Need help for laptop upgrade!!...
    i am using a ASUS laptop A3AC (around 1 yr old) with the below specs....
    WinXP SP2
    Pent M750 1.86GHz
    512 RAM
    80GB HDD
    Intel 915GM
    What are the upgrades that i can do on my machine which will speed it up a little, as i find it a bit lagging..
    Usually i use it for P2P, internet surfing and photo editing...
    And also another problem is that i experienced "white out" screen... the whole screen go white with everything running normal in background... What happened? Is it because of gfx overheat?... it usually "white out" during idle...
    Pls advise... Thanks...
    upgrade to 2GB RAM. That's it.
    where can i get the best price for a 2gb ram?... will it be sufficient to make my com move faster with tis upgrade?
