Results 1 to 11 of 11
    Can a HD3870 fit inside a Lian Li PC-V350?
    集中精神, 闭关修行 booest's Avatar
    Feb 2004
    109,464
    pm ahmoo..
    Life is a Gift, Never take it forgranted
    | i5ooest:i5-4690S cooledby Kozuti | Maximus VII Impact mini-ITX | 2 x 8GB DDR3 | Extreme PRO 480Gb |
    | 1TB Veloci | MX800 | M12 II-620W | Jonsbo W1 |2707WFP (16:10) |
    ahmoo says it will fit.
    Quote Originally Posted by ahmoo
    yup it can, thats some of the reason y i got a v350 instead of a v300. v300 has one move extra bay directly under the 5.25" bays, while a v350 does not. its all clear to put in.
    Feb 2004
    109,464
    ahmoo says can means can lor
    Can't wait for the weekend to come. Where got the cheapest PC-V350?? Anyone? $199 at uvnium's website...
    Feb 2004
    109,464
    Quote Originally Posted by matthewchng View Post
    PM ahmoo to order for you hahahahaha
    What do you mean? He can get it cheaper than $199?
    Feb 2004
    109,464
    ai yo.... PM him lah
    just don't be a pilot can riaoz.
    Will do just that... PM him I mean.
    Feb 2004
    109,464
    help you sms
    Thanks, danke, terima kasih, 谢谢, GrÃ*cies!
    Now I see. Heh. Thanks ahmoo.
