Results 1 to 6 of 6
    **PC Keeps Restarting but no BSOD or errors logs!** HELP
    Hi guys,
    Was wondering any tech GURU here may be of assistance would really appreciate it very very much and thank you to those who respond.
    I'm currently facing an issue where my PC restarts every time I play a game call PUBG and stream at the same time etc this usually happens when the PC is stressed it will just restart into black screen and windows boots up again with a log stating (do you want to start windows normally) no error log no BSOD reports just plain restart.
    But when i play other title games and don't stream it will be fine, even for this game itself PUBG if i turn of SLI on my TitanX and do not stream the game runs fine.
    Pior to this i had a problem with my MOBO bios monitor settings as you can see i'm using the ASUS x99-deluxe so before i turned off (Monitor Power Surge) & (Monitor chassis intruded) if those two settings were turn on my in the bios the computer would also restart after a few mins into the windows desktop after that it will notify me why either one of this reason in the bios.
    Really hope somebody can help me solve this problem, i've also tried windows memory test everything is fine.
    My only suspect i feel is the Power supply.
    PC Specs:
    Intel - Core i7-5960X
    Asus - X99-DELUXE
    Corsair - Dominator Platinum 64GB (8 x 8GB) DDR4-2400 Memory
    2x EVGA - Titan X 12GB HYBRID Video Card SLI
    Corsair - AX1200i
    Custom Water Cooling Build for GPU & CPU
    Windows 7 64bit
    Asus ROG User HKSPower's Avatar
    May 2007
    A.M.K
    5,433
    out of sudden and restart pc?
    _________________________
    Main PC:
    Intel Core I7 3960X/Asus ROG Rampage IV Black Edition/Corsair DominatorGT 1866 32gb/Samsung EVO 850 250GB SSD/SP 240GB SSD/Samsung EVO 850 500GB SSD/Gigabyte GTX970 G1 Gaming/Creative SB X-FI Fatality/Kamameter/Corsair HX850i/Corsair 760T
    Banned lowballer:
    Tablet_crazy (989777xx)
    My PC also have same problem anywhere in sim lim that you guys recomended for a system service.
    I will advise people to never do liposuction. I know that it is the easy way out but there is no point. You will never find permanent benefits from short-cuts. I know that losing weight may seem hard but with a little dedication and hard-work you can acheive it. Cardio is the best exercise.
    Please do the following:- open Event Viewer (run eventvwr.msc from the "Run" dialog)- expand the Custom Views category (left click on the > next to the words "Custom Views")- right click on Administrative Events- select "Save all Events in Custom View as..."- save the file as Admin.evtx
    Senior Member habeeb's Avatar
    Serangoon Central
    1,837
    The behavior at first glance seems like overheating cpu/gpu and pc restart to prevent damage to the chip. Alternatively could be power issue or motherboard power management.
    CPU: Intel i9 9900K | Cooler: Corsair H115i RGB Platinum | Motherbaoard: Gigabyte Z390 Aorus Master
    Ram: G.Skill Trident RGB 3200Mhz C16 16GB | SSD: Samsung 960 Pro 1TB
    HDD: 4TB WD Black, 3TB WD Black, 3TB WD Red | Case: Phanteks Evolv X
    Power Supply: Seasonic X850 | GPU: Gigabyte GTX1080 Ti Aorus Extreme 11GB
    Display: Dell U2715H | Speakers: Logitech Z623
  1. First look: iPhone 6, iOS 7 detected in app logs
    By bigsale in forum News around the web!
    Last Post: Jan 2nd, 13, 01:15 PM
  2. BSOD in Windows XP, Clean Install to Windows 7, BSOD still exist.
    By Destiny in forum Troubleshooting Zone/Technical Enquiries
    Last Post: Apr 26th, 10, 02:00 PM
  3. Nashaz' Project Logs...
    By Nashaz in forum Case Modding & Project Logs
    Last Post: Feb 13th, 09, 07:38 PM
  4. Replies: 0
    Last Post: Feb 8th, 09, 03:23 PM
  5. Restarting Windows Without Restarting Your PC
    By hellspawn_one in forum Chit Chatting
    Last Post: Aug 18th, 07, 11:59 AM
